jinnkraft
- 15
- 1
What is the method to design a Non - Telescopic, Non - Linear, conical compression spring from a Force - Deflection characteristics
Thanks for your reply.Baluncore said:
jrmichler said:The procedure is a little too complex for a posting, but two good sources are:
1) Handbook of Spring Design, by SMI (Spring Manufacturers Institute). My 2002 edition has 100 pages of spring goodness.
2) Mechanical Springs by Wahl. An old book, but it has everything.
Any engineering library should have at least one of these, otherwise interlibrary loan. The current list price for the SMI book is $27.00. It's a bargain. The non-telescopic constraint makes the design more challenging than a telescopic design. I suspect that the design process for a non-telescopic conical compression spring will be iterative, especially if one of the constraints is solid height. The SMI book will get you started, you may need the Wahl book to finish.
So put stops between each of the coils. Problem solved.jinnkraft said:Non Telescopic is in a sense, that the coils of spring should not merge or immerse completely into each other.they should rather sit on each other.
So the solid length of such a spring will be sum of dia of all the coils.
In a telescopic spring, to my knowledge, the coils of spring will immerse into one, thus making their solid length equal to diameter of the coil
Baluncore said:You have not specified any constraints on the spring you need to design. That is inefficient for us, and will not be productive for you.
You have placed yourself in the position of a story teller, who will release only the minimum information, but then only when we guess wrongly.
You need to act more like a scientist or engineer, to disclose the full spring specifications and the constraints on design.
Baluncore said:Select a prototype from this catalogue entry;
https://www.lesjoforsab.com/standard-springs/51-52_en_id965.pdf
Cat. no. = 3199 or 6702 looks like it might make a good prototype for your requirement.
N = 5 turns, of wire diameter = 1.5 mm. Inner diam = 9 mm. Outer diam = 30 mm.
Uncompressed length = 30 mm. Compressed length = 1.5 mm. Compressed force = 78 N.
A non-linear conical compression spring is a type of mechanical spring that is designed to compress when a force is applied to it. It is conical in shape, meaning that the diameter of the spring decreases towards the ends. Unlike a linear spring, which has a constant rate of compression, a non-linear conical compression spring has varying rates of compression throughout its length.
Non-linear conical compression springs offer several advantages over linear springs. They can provide a more gradual and controlled compression, making them ideal for applications where a smooth and consistent force is needed. They also have a higher load capacity and can withstand more deflection without losing their shape. Additionally, their conical shape allows for more compact design and space-saving.
The design of a non-linear conical compression spring involves several factors, including the desired load and deflection, material properties, and the spring's dimensions. The design process typically involves using specialized software or equations to determine the appropriate wire diameter, number of coils, and pitch of the spring. It is also essential to consider the end types and any additional features, such as ground ends or closed ends, to ensure proper functioning.
A variety of materials can be used for non-linear conical compression springs, depending on the specific application. Some common materials include steel, stainless steel, titanium, and various alloys. The choice of material will depend on factors such as the required strength, corrosion resistance, and temperature resistance.
Non-linear conical compression springs have many applications across various industries. They are commonly used in automotive suspensions, industrial machinery, medical devices, and even toys. They are also useful in applications where shock absorption, vibration control, or constant tension is required.
