Designing reflector straight line lamp
Harry Logtenberg
Member warned that homework questions must include a reasonable attempt.
Who can help me to calculated a reflector for a straight light tube with a diameter of 6mm and a length of 300mm given a beam with a width of 100mm at a distance of 500-700mm?
I do not know.
:welcome: !
Did you do a little research ? Google 'parabolic optical reflector design calculator'and NASA has a nice webpage.
You of course don't want a dish but a kind of parabolic gutter. Formulas in one dimension stay the same.
And: make a sketch ! Do you want the beam to be parallel ('width of 100mm at a distance of 500-700mm') ? Or isn't that so critical ?
Likes DeBangis21
You will need to specify some things about the desired result.
  1. Do you want the output to be converging, diverging, or parallel ?
  2. What is the acceptable variation in beam profile ?
  3. Do you want a faceted mirror or a curved surface (i,e. how to construct) ?
  4. Size and weight limits
  5. Material cost limits
The simplest way to triple the directed forward output is to use a corner reflector (in 2D) behind the source. This fact will drive many of the simpler design decisions.
Likes DeBangis21
OP will need to repost this thread with their work shown if they want our tutorial help.
  • General Engineering
  • Other Physics Topics
  • Electrical Engineering
