Details of the electron cloud in a magnetron: density and size?
In summary, the magnetron has a very high Q, which allows it to store a lot of energy before it loses it.
cmb
1,128
128
In a standard kitchen-microwave magnetron, like all magnetrons, a cloud of electrons forms which whizzes around and generates GHz electric currents in an outer ring electrode.
For such a standard kitchen appliance, 800W made with ferrite magnets, what is the typical volume and density of the electron 'charge wheel' that spins around?
There is a picture at the top of this page; https://en.wikipedia.org/wiki/Cavity_magnetron
The size of the resonant cavities in a magnetron is a function of wavelength. For a 10 cavity magnetron producing 2.45 GHz the outside diameter is about 40 mm. The open central cavity surrounding the heated cathode is about 10 mm diameter. The axial length of the cavities is about 15 mm. The two rings are the “Pi strapping” that lock the phase of the cavities and increase efficiency.
Knowing the voltage is about 3 kV and the power 800 watt, the current is about 250 mA.
I think the problem here is that "250mA" would not be related to the number of electrons, which have to circulate around the cathode X(?) times to generate that microwave current.
250mA may represent 250mC of electrons entering the working space per second, thus in equilibrium the same number leaving (i.e. a current), but how long do they last in there? If they last for one second then yes there would be 250mC of electrons in the working space. If they last a millisecond then there would be 0.25mC instead.
Is that right? And if so, then how to calculate, and/or measure, that?
The cavity has a very high Q of several thousand, but it is shunted by the load, which brings the loaded Q down to a low value such as 10. The cavity then stores a lot of energy, such that the energy it loses per cycle is less than the energy stored. Q = 2 pi energy stored/energy lost per cycle. The circulating electrons seem to be equivalent to the circulating current in the cavity and the electrons leaving the system seem equivalent to the load current. So I imagine that the ratio of these two is equal to sqrt Q.
Likes cmb
When it is difficult to measure or calculate a parameter we should ask, “why do we need to know the value?”. Once that question is answered we will know how to estimate the parameter.
Very useful, it has prompted me to find some relevant and useful further links.
I had not thought about the magnetron as a device for which the 'Q' is the number of merit, but that has opened that up for me. If you have any further links or direct information on calculating magnetron Q values (if you could PM me and pdfs and such) that'd be really really super helpful.
Related to Details of the electron cloud in a magnetron: density and size?
1. What is the electron cloud in a magnetron?
The electron cloud in a magnetron is a region of space around the cathode where electrons are emitted and then accelerated towards the anode. This cloud of electrons is responsible for generating the microwaves used in microwave ovens.
2. How is the density of the electron cloud in a magnetron determined?
The density of the electron cloud in a magnetron is determined by the strength of the magnetic field and the voltage applied to the anode. These factors affect the speed and trajectory of the electrons, ultimately determining the density of the cloud.
3. What factors affect the size of the electron cloud in a magnetron?
The size of the electron cloud in a magnetron is affected by the shape and design of the magnetron, as well as the strength of the magnetic field and the voltage applied to the anode. These factors can be adjusted to control the size and shape of the electron cloud.
4. How does the density of the electron cloud affect the efficiency of a magnetron?
The density of the electron cloud is directly related to the efficiency of a magnetron. A higher density of electrons means more collisions and interactions, resulting in a stronger and more efficient microwave output.
5. Can the size and density of the electron cloud in a magnetron be controlled?
Yes, the size and density of the electron cloud in a magnetron can be controlled by adjusting the magnetic field and voltage applied to the anode. This allows for precise tuning and optimization of the magnetron's performance.
  • Electromagnetism
  • Quantum Interpretations and Foundations
  • Other Physics Topics
