How Can Derivatives Determine Speed in Physics Problems?
emily-
The acceleration of the boat is defined by
a = (1.5 v^(1/2)) m/s. Determine its speed when t = 4 s if it has
a speed of 3 m/s when t = 0.
v = ds/dt
a = dv/dt
a ds = v dv
I have been trying to solve this problem for hours using the mentioned equations but no matter what I do I cannot get the correct answer, that is v = 22.4 m/s. I thought that maybe if I could get an expression where v is a function of time I could solve the problem but I don't know how to do that since they always end up being separate. Any help and guidance would be deeply appreciated, thanks!
One of your "relevant equations" is capable of solving your issue. You are given:
$$ a = 1.5 \sqrt{v} $$
Which one do you think it is?
a = dv/dt
Likes erobz
Yes, sub in the differential form for ##a##, separate variables and integrate each side.
I rewrote the equation to: dt = dv/a and then integrated both sides. When it comes to the boundaries, I wrote 4 <- 0 for dt and v <- 3 for dv/a but as a result I got 0.023 m/s
You're having some computational error. I get ##22.4 ~\rm{m/s}## when I do it. Please show your work using Latex. See: LaTeX Guide
Likes emily-
Show us the steps
Integral of dt = 4
Integral of dv/a = 2/3√v - 2/3√3
I move the numerical expressions to one side and isolate √v and square it
BvU said:
Show us the steps
I got the integral expression wrong!! It's (2√v)/1.5 and not 2/3√v ! Omg
Thanks for the help!!
Likes erobz
Nope ! What is the integral of ##{2\over 3} {dv\over\sqrt v} ## ?
Please show you work. I suspect you made a mistake when you integrated. Consider using LaTeX to post your equations. It makes them more legible and it's a good skill to have. Click on the link "LaTeX Guide", lower left to see how it is done.
Likes emily-
It should be (4√v)/3 right?
Yes. So you get ##\sqrt {v(t)}-\sqrt{v(0)} = {3\over 4} t##. Move to the other side and square.
Likes emily-
Yess, thanks!!
You are welcome. And ##\LaTeX## really is fun !
(:smile: sorry for intruding, @erobz)
Likes emily-
Don't be!
Likes BvU
The issue has been solved, but …
… this cannot be true! The units are all over the place!
Likes SammyS and erobz
Right. Should be ##(1.5 v^{\frac 12}) m^{\frac 12}s^{-\frac 32}##, yes?
Yes, if ##v## is dimensionful with the appropriate units. However, sometimes you see introductory texts introduce dimensionless quantities such as "velocity is ##v## m/s", making ##v## actually dimensionless. This looks like some strange combination, but that's how I would do it (although I would probably write it as ##(1.5~{\rm m}^{1/2}/{\rm s}^{3/2}) \sqrt{v}## or - even better - ##k\sqrt v##, where ##k = 1.5~{\rm m}^{1/2}/{\rm s}^{3/2}##).
If one wants to use dimensionless quantities here, I would have formulated it just like "##a = 1.5\sqrt{v}##, where the acceleration is ##a## m/s2 and the velocity is ##v## m/s".
Orodruin said:
Yes, if v is dimensionful with the appropriate units.
Aren't the units of v irrelevant to the correct form (as long as it has the dimension of velocity)?
Sure. With ”suitable” I only mean ”of the correct dimensions”.
