Determine the potential energy function of the charged particle
In summary, the conversation discusses the integration of f(x) and its negative, as well as the assumption of an infinitely long linear charge in determining the potential energy function. It is mentioned that typically the potential is taken to be zero at infinity, but this is not possible in this case. The conversation also suggests a possible exercise to explore the impact of finite length on the potential.
SLTH02
The electrostatic force repelling a charged particle from a long, straight, uniformly charged rod is given by
the equation F = 100 x ^ (-1) where x is the distance from the rod.
F = -(dU)/(dx)
I understand that you need to integrate f(x), and the negative of that is U(x).
But the last part of the problem says "Clearly state any assumptions you make."
And the answer is just the antiderivative of that f(x) without any constant from integrationHow does that make sense
Good observation. You might insert the actual question in the homework statement, but I gather the exercise asks for 'the' potential energy function.
Such a function is in fact determined to within a constant (we don't observe potentials, only forces ...) . Usually we take the potential to be zero at infinity, but in this case that can not be done: a consequence of assuming the linear charge is itself infinitely long.
So what would happen if the linear charge is infinitely long?
An infinitely long wire looks the same from any distance,
A better question is: what would change if the wire had finite length
(nice exercise: check that ##V\rightarrow {Q\over {4\pi\varepsilon_0 r} } ## for ##d\rightarrow \infty## )
Likes SLTH02
Got it. thanks!
Likes BvU
Related to Determine the potential energy function of the charged particle
1. What is potential energy?
Potential energy is the energy that an object possesses due to its position or configuration. It is the energy that an object has stored and can be converted into other forms of energy, such as kinetic energy.
2. What is a charged particle?
A charged particle is an object that has an electric charge, either positive or negative. This charge can interact with other charged particles through the electromagnetic force.
3. How is potential energy related to charged particles?
In the case of charged particles, potential energy is related to the electric potential energy. This is the energy that a charged particle has due to its position in an electric field. The closer the particle is to a source of electric charge, the higher its potential energy will be.
4. How can I determine the potential energy function of a charged particle?
The potential energy function of a charged particle can be determined by using the equation PE = qV, where PE is the potential energy, q is the charge of the particle, and V is the electric potential at the particle's position. This equation can be derived from the definition of potential energy and the relationship between electric potential and electric field.
5. What factors affect the potential energy of a charged particle?
The potential energy of a charged particle is affected by the distance between the particle and the source of electric charge, as well as the magnitude of the charge on both the particle and the source. It is also affected by the presence of other charged particles in the surrounding environment, as they can create additional electric fields that can influence the potential energy of the particle.
