Deuterium combustion within inertial fusion schemes
In summary,I read that both hydrogen as well as deuterium can ignite/combust upon compression even in ordinary ICE engines. Hydrogen has been investigated and used as fuel for internal combustion engines. Now in a inertial fusion approach the fuel is highly compressed at a fast rate, whether it be NIF using light or other designs using a physical tamper/liner to exert force on the gas. So before fusion conditions are reached within the gas, doesn't it combust chemically first?It definitely undergoes the pressure rise and final pressure needed for chemical combustion along the way, a pressure that is easily attained in ICF approaches and also exists within piston engines.
artis
1,481
976
Hydrogen as well as Deuterium are both flammable chemically, I read that both hydrogen as well as deuterium can ignite/combust upon compression even in ordinary ICE engines. Hydrogen has been investigated and used as fuel for internal combustion engines.
Now in a inertial fusion approach the fuel is highly compressed at a fast rate , whether it be NIF using light or other designs using a physical tamper/liner to exert force on the gas.
It definitely undergoes the pressure rise and final pressure needed for chemical combustion along the way, a pressure that is easily attained in ICF approaches and also exists within piston engines.I also wonder , would it be beneficial to compress a cold gas to very high pressure and then ignite it chemically , I wonder how much pressure increase would that add and how could it benefit achieving fusion temperatures?
From ICE piston engines I know that the flame front travels faster if the density of fuel/air is higher, so in theory I'm not sure but wonder how would a extremely high compression gas under that high pressure react when ignited.
Combust with what?
Likes mfb and Bystander
Vanadium 50 said:
Combust with what?
I guess I forgot that these approaches don't have oxygen in the fuel mix.
So I should have restated my question as to whether it would combust if the fuel pellet for example had been doped with oxygen.
Sure enough it would be futile for an experiment like NIF because such combustion would most likely destroy the symmetry of the compression and ruin it before it ever has a chance of reaching fusion temperatures.
Fusion happens at temperatures of several keV. Chemical reactions are irrelevant, and oxygen would just be in the way of fusion.
Likes russ_watters
That is all true. What I was thinking is when you compress a say deuterium/oxygen mix to a super high pressure at very low temp (low so that it doesn't detonate on it's own) and then in the final stages of compression ignite it.
The pressure/temperature increase in a closed container is proportional to the gas density pre-ignition.
One could in theory calculate this and get the answer that way I'm sure, I was just wondering is it in theory possible to achieve fusion level temps with thermodynamic tricks.
The compression leads to the high temperature. That's the point of the compression.
But anyway, see above: The energy released in chemical reactions is negligible.
Where is this oxygen coming from?
And why stop there? If you are going to worry about things that aren't there, why not worry about lit sticks of dynamite in the reaction chamber? Or a pot of molasses? Or a minor Kardashian sister? Or...
Google tells me if you combust a kilo of hydrogen you get 10^8 joules, and if you fuse it you get 10^14 joules. So there's a few orders of magnitude difference and the combustion doesn't add/help much.
You are comparing a V-8 engine to the interior of the sun.:sun: !
Likes russ_watters
It hurts. If a fraction of the d collisions are with other elements, that fraction does not participate in fusion. So the effect tends to reduce energy production.
Likes artis and russ_watters
I wasn't arguing about how chemical reactions could release equal amounts of energy as nuclear because I know they can't, my point was solely about taking a highly compressed mixture of gas, igniting it in a sealed container where there is a large pressure increase, but on a second thought that's probably not enough anyway so I rest my case.
PS. An imploding "liner" pretty much does the same thing in ICF approaches - it compresses the fuel much like a piston would in the v8 engine @hutchphd mentioned only faster, symmetricaly and to higher final pressure. My thought was to have a highly compressed gas/liquified and then ignition in a fixed size container would increase the pressure inside the container similarly to how a imploding liner only in one case you raise pressure/temp by compression in the other you raise it by expansion when a liquified gas ignites and turns to a burning plasma the only question is how hot would it become.
And that is why I asked.
artis said:
I rest my case
That usually means that one stops talking, so it's unusual to see this 1/3 of the way down. Looks to me like you are continuing to argue.
The thing you seem to be missing (and everyone else is trying to explain) is that hydrogen does not burn in a chemical sense by itself. It needs an oxidizer, like oxygen. It doesn't matter what T and P you put it at - without an oxidizer there is no reaction.
Likes vanhees71
Related to Deuterium combustion within inertial fusion schemes
1. What is deuterium combustion?
Deuterium combustion is a nuclear reaction in which deuterium, a heavy isotope of hydrogen, fuses with another deuterium atom to form helium, releasing a large amount of energy in the process.
2. What are inertial fusion schemes?
Inertial fusion schemes are methods for achieving controlled nuclear fusion reactions by using high-energy lasers or particle beams to compress and heat a small target containing deuterium and tritium, another hydrogen isotope.
3. How does deuterium combustion contribute to inertial fusion reactions?
Deuterium combustion is one of the key reactions that occurs during inertial fusion. It provides the necessary energy to start the fusion process and release even more energy from the fusion of deuterium and tritium.
4. What are the challenges of deuterium combustion within inertial fusion schemes?
One of the main challenges is achieving the necessary conditions for deuterium combustion to occur, including high temperatures and pressures. Another challenge is controlling and sustaining the fusion reaction for a long enough time to produce a net energy gain.
5. What are the potential applications of deuterium combustion within inertial fusion schemes?
If successfully harnessed, deuterium combustion within inertial fusion schemes could provide a virtually limitless source of clean energy, with no greenhouse gas emissions or long-lived radioactive waste. It could also have applications in advanced propulsion systems and the production of medical isotopes.
  • Nuclear Engineering
  • General Engineering
  • Mechanical Engineering
