Dice Game: 6-sided die vs 20-sided die
  • Thread starter Thread starter Master1022
    Dice Game
The discussion revolves around a game involving a 20-sided die and three 6-sided dice, where the objective is to determine which player has a better chance of winning based on the rules of the game. Participants explore concepts of expectation, variance, and fairness in the context of probability distributions associated with the dice rolls.
  • Participants discuss the expected values and variances of the two different dice setups, questioning how these statistics relate to the fairness of the game. Some explore the implications of winning numbers and how they affect the probabilities for each player. Others consider the symmetry of the probability distributions and whether variance plays a role in determining an advantage.
The conversation is ongoing, with various interpretations being explored regarding the fairness of the game and the significance of variance. Some participants have offered insights into the symmetry of the distributions, while others are questioning the implications of different winning conditions.
Participants are operating under the assumption that the dice are fair and are discussing the implications of different winning numbers on the probabilities. There is also mention of potential constraints if a third player were introduced into the game.
  • #31
FactChecker said:
Can you specify how the third player is involved? I am confused by this.
You have a third player with a third way of scoring. It could be anything. Absolutely anything. Then, excluding draws between two or more players, you count how often each player wins outright.
The hypothesis is that the 20-sided die is never worse than the three 6-sided dice. And, in general, is almost always better.
  • #32
Is the third player rolling another 20-sided die, or another set of three 6-sided die, or doesn't it matter?
Before I think hard about it, I want to know what I am thinking hard about. :-)
  • #33
It could be those or anything at all. They might get a fixed score of 15 every time; or scores of 5 or 10 with equal probability; or, absolutely anything.
  • #34
So, as long as the winner has to beat two others, it is an advantage to have a larger variance than at least one other (and not less than others). Is that what you are saying? I'll buy that.
(That is, given equal means.)
  • #35
Mark44 said:
NTrials = 1000000
for i in range(0, NTrials+1):
That loop will execute 1,000,001 times.
  • #36
I realized that when I counted the total wins for each set and the ties.
  • #37
Complete enumeration of the probability space for the two-way competition is way cheaper than that.
I did a complete enumeration for a 3-way competition and only needed 25,920 cases. My intuition about 3d6 beating 1d20 in a three way match against (5, 5, 5, 6, 21, 21) was faulty.
Scoring: win = 6 points, 2 way tie = 3 points, 3 way draw = 2 points each.
Code:
C:\>test.pl
Player 1 (3d6)           scores 50972 points
Player 2 (1d20)          scores 51632 points
Player 3 (5,5,5,6,21,21) scores 52916 points
Player 1 (3d6)           rolled a mean of 10.5 pips per roll
Player 2 (1d20)          rolled a mean of 10.5 pips per roll
Player 3 (5,5,5,6,21,21) rolled a mean of 10.5 pips per roll
There were 25920 combinations with a total of 155520 points available
The total points awarded were 155520
The code for this is somewhat verbose with extra sanity-checking, but is fairly straightforward.
Perl:
#!/usr/bin/perl
use strict;
use warnings;
# Points = winning points: 6 = clear win, 3 = two-way tie, 2 = three-way tie
my $p1_points = 0;
my $p2_points = 0;
my $p3_points = 0;
# Total = total pips rolled
my $p1_total = 0;
my $p2_total = 0;
my $p3_total = 0;
my $total_combos = 0;
sub scores ( $$$$$ );
foreach my $d1 ( 1, 2, 3, 4, 5, 6 ) {
    foreach my $d2 ( 1, 2, 3, 4, 5, 6 ) {
        foreach my $d3 ( 1, 2, 3, 4, 5, 6 ) {
            foreach my $d4 ( 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20 ) {
                foreach my $d5 ( 5, 5, 5, 6, 21, 21 ) {
                    my @result = scores ( $d1, $d2, $d3, $d4, $d5 );
                    $p1_points = $p1_points + $result[0];
                    $p2_points = $p2_points + $result[1];
                    $p3_points = $p3_points + $result[2];
                    $p1_total = $p1_total + $result[3];
                    $p2_total = $p2_total + $result[4];
                    $p3_total = $p3_total + $result[5];
                    $total_combos = $total_combos + 1;
if ( $total_combos != 6 * 6 * 6 * 20 * 6 ) {
    print STDERR "Calculated total combinations is ", 6 * 6 * 6 * 20 * 6, " but this code found $total_combos instead\n";
    exit;
print "Player 1 (3d6)           scores $p1_points points\n";
print "Player 2 (1d20)          scores $p2_points points\n";
print "Player 3 (5,5,5,6,21,21) scores $p3_points points\n";
print "\n";
print "Player 1 (3d6)           rolled a mean of ", $p1_total/$total_combos, " pips per roll\n";
print "Player 2 (1d20)          rolled a mean of ", $p2_total/$total_combos, " pips per roll\n";
print "Player 3 (5,5,5,6,21,21) rolled a mean of ", $p3_total/$total_combos, " pips per roll\n";
print "\n";
print "There were $total_combos combinations with a total of ", $total_combos * 6, " points available\n";
print "The total points awarded were ", $p1_points + $p2_points + $p3_points, "\n";
sub scores ( $$$$$ ) {
    my $p1d1 = $_[0];
    my $p1d2 = $_[1];
    my $p1d3 = $_[2];
    my $p2d1 = $_[3];
    my $p3d1 = $_[4];
    # Player 1 scores 3d6
    my $p1_score = $p1d1 + $p1d2 + $p1d3;
    # Player 2 scores 1d20
    my $p2_score = $p2d1;
    # Player 3 scores pips equal to 5, 5, 5, 6, 21, 21 on a d6;
    my $p3_score = $p3d1;
    if ( $p1_score > $p2_score && $p1_score > $p3_score ) {
        return ( 6, 0, 0, $p1_score, $p2_score, $p3_score );
    } elsif ( $p2_score > $p1_score && $p2_score > $p3_score ) {
        return ( 0, 6, 0, $p1_score, $p2_score, $p3_score );
    } elsif ( $p3_score > $p1_score && $p3_score > $p2_score ) {
        return ( 0, 0, 6 , $p1_score, $p2_score, $p3_score);
    } elsif ( $p1_score == $p2_score && $p1_score > $p3_score ) {
        return ( 3, 3, 0, $p1_score, $p2_score, $p3_score );
    } elsif ( $p1_score == $p3_score && $p1_score > $p2_score ) {
        return ( 3, 0, 3, $p1_score, $p2_score, $p3_score );
    } elsif ( $p2_score == $p3_score && $p2_score > $p1_score ) {
        return ( 0, 3, 3, $p1_score, $p2_score, $p3_score );
    } elsif ( $p1_score == $p2_score && $p1_score == $p3_score ) {
        return ( 2, 2, 2, $p1_score, $p2_score, $p3_score );
    } else {
        print STDERR "No clear winner, no two way tie, no three way tie. What is going on?\n";
        print STDERR "Player 1: $p1d1 $p1d2 $p1d3 = $p1_score\n";
        print STDERR "Player 2: $p2d1 = $p2_score\n";
        print STDERR "Player 3: $p3d1 = $p3_score\n";
        exit;
  • #38
PeroK said:
PS I assigned the third player a fixed score of everything from 1-20 and there is no score that creates an advantage for 3D6.
That cannot be true: 3D6 will always beat 1 or 2 whereas D20 will sometimes lose.
  • #39
A third player score of 1 or 2 leaves the contest between 3D6 and D20 level. In terms of outright wins.
PS the third player must score at least 3 to influence the contest.
  • #40
Indeed. For non-linear problems (and you can't get much more non-linear than win/lose) Monte-Carlo methods are not in general worthwhile.
I suspect 3d6 may score better against [2, 2, 2, 36] (particularly if you only count clear wins) but I can't be bothered to fire up a Linux instance at the moment to test your Perl script :-p
Your post would have received a like if it hadn't been in Perl :rolleyes:
  • #41
You suspect wrongly!
  • #42
Yes of course, I missed that point.
Yes, because of the above, although for this case d20 and 3d6 should be equal because of the same point?
In fact [2, 2, 2, 36] will win 1/4 of the time with d20 and 3d6 each 3/8 (not counting ties)?
  • #43
If we take player 3 scores from 1 to 20 inclusive and run 100,000 games, the wins for D20 and 3D6 are:
47354 47644
47666 47388
47456 47454
47484 47313
47265 46809
46984 45773
46870 43375
45993 40052
44605 35698
42625 29718
40302 23573
37067 17194
33381 11238
28932 7031
24434 3637
19949 1559
15091 378
9910 0
5084 0
0 0
The low scores leave the contest fairly even, but from 3 onwards 3D6 loses more winning games than D20. You could actually compute the probabilities fairly easily, and prove the matter. I might try that now.
  • #44
Counting ties...
Code:
C:\>test2.pl
Player 1 (3d6)           scores 38880 points
Player 2 (1d20)          scores 38880 points
Player 3 (2,2,2,36)      scores 25920 points
Player 3 (2,2,2,36)      rolled a mean of 10.5 pips per roll
There were 17280 combinations with a total of 103680 points available
The total points awarded were 103680
  • #45
Real programmers can write Fortran in any language.
  • Haha
  • Wow
  • #46
Here are the probabilities:
Player 3 scores 1, D20 wins 0.4750, 3D6 wins 0.4750
Player 3 scores 2, D20 wins 0.4750, 3D6 wins 0.4750
Player 3 scores 3, D20 wins 0.4750, 3D6 wins 0.4745
Player 3 scores 4, D20 wins 0.4748, 3D6 wins 0.4725
Player 3 scores 5, D20 wins 0.4738, 3D6 wins 0.4669
Player 3 scores 6, D20 wins 0.4715, 3D6 wins 0.4553
Player 3 scores 7, D20 wins 0.4669, 3D6 wins 0.4345
Player 3 scores 8, D20 wins 0.4588, 3D6 wins 0.4005
Player 3 scores 9, D20 wins 0.4458, 3D6 wins 0.3542
Player 3 scores 10, D20 wins 0.4271, 3D6 wins 0.2979
Player 3 scores 11, D20 wins 0.4021, 3D6 wins 0.2354
Player 3 scores 12, D20 wins 0.3708, 3D6 wins 0.1718
Player 3 scores 13, D20 wins 0.3338, 3D6 wins 0.1134
Player 3 scores 14, D20 wins 0.2919, 3D6 wins 0.0683
Player 3 scores 15, D20 wins 0.2465, 3D6 wins 0.0359
Player 3 scores 16, D20 wins 0.1988, 3D6 wins 0.0150
Player 3 scores 17, D20 wins 0.1498, 3D6 wins 0.0039
Player 3 scores 18, D20 wins 0.1000, 3D6 wins 0.0000
Player 3 scores 19, D20 wins 0.0500, 3D6 wins 0.0000
Player 3 scores 20, D20 wins 0.0000, 3D6 wins 0.0000
  • #47
I disagree. In fact, those are the situations where theoretical calculations get so tricky that Monte-Carlo methods have a significant advantage. Even if one can get an analytical answer, I would not completely trust it if it did not agree with a Monte-Carlo simulation. I have seen examples in this forum where a very complicated thread eventually (after several days) arrived at the same answer that a 10 minute Monte-Carlo simulation gave.
It is easy to install in Windows. In fact, my experience is that some tools that I used on Windows machines had Perl as part of their installation.
Boo! I have known people who have the silliest complaints about Perl. Perl has some significant advantages for many scripting applications.
  • #48
Here's a simple example of what I mean. The UK national lottery draw is six unique numbers 1..59 so the chance of a winning ticket is trivially 1 in ## {59 \choose 6} = 45,057,474 ##. How many Monte Carlo trials would you need to reliably get close to the analytic solution?
The problem in the OP is another example: the symmetry argument leads instantly to the correct 50:50 answer, and @jbriggs444's complete enumeration verifies that with only 25,920 evaluations. A Monte Carlo method would require many more trials and would be no easier to program than the complete enumeration.
Even when the solution space is sufficiently large that complete enumeration is not feasible, a divide and conquer approach will often lead to an exact solution.
But yes, when analytic, enumerative and divide and conquer and similar methods fail then Monte Carlo may be all that's left - but unless there is some smoothness to the problem you can't be sure that you haven't over- or under-estimated the frequency of 'unicorns'.
  • #49
Yes. Trivial problems are easier to solve analytically. I wish that I lived in a trivial world.
Now, suppose that every even number, n, tentatively picked, was rejected with a probability of 1/n. I can modify the Monte-Carlo simulation in a minute. How easy is the analytic solution? There are a million things that can, and do, occur like that.
  • #50
If you think about it, the only way to get any accuracy would be to calculate the probability for each individual ball using a Monte Carlo method (with only 39 outcomes with the minimum frequency (for 2) better than 1 in 78 this should be computable with very high confidence of accuracy) and then use an analytic method to calculate the probability of any given choice. If you just go looking for that needle in the haystack you are still going to need billions of trials to reliably get anywhere near.
And anlytically solvable problems can be solved analytically and feasibly enumerable problems can be solved by complete enumeration; in neither case are they better solved by Monte Carlo. Your argument is analagous to 'I have to bang in a lot of nails so whenever I need to fix a screw or a pop rivet I reach for the hammer'.
  • #51
This thread seems to have gone wildly off-topic discussing a class of methods that are not appropriate for solving the OP's question, which was easily solved in #6 :sorry:
  • Love
  • #52
Be careful. I have dealt with plenty of analytical methods in probability and statistics (although I admit that I am rusty).
  • #53
Many thanks to all for writing out the responses. It has been interesting to read about analytical and numerical ways of approaching the problem.
  • #54
Thanks @Master1022 !
This sounds like a good time to close this thread before we get busted for gambling without a license.
Thank you all for contributing here.
Closing this thread now.
  • · Replies 34 ·
