Diffeomorphic manifolds of equal constant curvature
In summary: It's not a "general" theorem I'm working on, it's actually a derivation of the FLRW metric. So, you have a lot of additional stuff simplifying the manifold structure. There's the assumption that ##\Sigma_\tau## is the set of points ##p\in M## such ##t(p) = \tau##, and ##u = \partial / \partial t##, so the flow of ##u## carries the foliation into itself.I think that concludes the proof.
  • #36
Yes, for Riemannian flat manifolds it's easier to imagine examples that are diffeomorphic, and locally isometric, but which are not globally isometric.
Are there examples of dimension n ≥ 3 with constant sectional curvature K ≠ 0 ?
  • #37
As for surfaces, higher dimensional manifolds of constant curvature are quotients of one of three simply connected spaces by the action of a group of isometries. Positive curvature spaces are quotients of the sphere, ##S^{n}##,zero curvature are quotients of Euclidean space ##R^{n}##, and constant negative curvature spaces are quotients of the hyperbolic half space ##H^{n}##.
For negative curvature I came across this amazing theorem called the Mostow Rigity Theorem which says that if two manifolds of dimension greater than two and of constant negative curvature ##{^-}1## have isomorphic fundamental groups and also have finite volume then they are isometric. So the case of Riemann surfaces is unique.
For curvature zero you have flat manifolds and these can vary just as in the case of flat tori.
For constant positive curvature in even dimensions, I believe that even dimensional spheres are the only orientable possibility.
For odd dimensional spheres things get more complicated since finite groups can act properly discontinuously on them. Not sure of the theorems. Finite groups actions on the 3 sphere have been a source of key examples in topology.
Likes zinq and mathwonk
  • #38
Likes lavinia
  • #39
@zinq For flat Riemannian manifolds, one can ask a weaker question which is not when are they isometric but when are they affine equivalent. That is: when is there a connection preserving diffeomorphism between them? I think then one gets all flat tori of the same dimension are affinity equivalent and further any two compact flat Riemannian manifolds are affinity equivalent whenever their fundamental groups are isomorphic.
  • #40
I haven't thought about that equivalence relation and I don't have an intuition about it. (Do you?)
I have heard of affine manifolds in the sense that the pseudogroup of the transition maps of its atlas can be reduced to affine maps of Euclidean space. For instance,
M = Rn - {0} / x ~ λx
for some λ > 1. M is clearly diffeomorphic to Sn-1 x S1.
A famous unsolved problem is: Must a compact affine manifold have Euler characteristic equal to zero?
  • #41
I don't know anything about general affine manifolds. The idea of affine equivalence that I know is that there is a connection preserving diffeomorphism between the two manifolds. For flat manifolds the projections of straight lines in Euclidean space would be mapped onto each other.
There is an unbelievable example - which I don't understand at all - due to Charlap - of two compact flat Riemannian manifolds of the same dimension that are not homotopy equivalent but whose Cartesian products with the circle are not only diffeomorphic but are affinity equivalent. Their holonomy groups are cyclic of prime order.
  • #42
I wonder if that's related to pairs of flat 4-dimensional manifolds with the same spectrum of their Laplacians, I think due to Conway and Sloane. (The first such example was two 16-dimensional manifolds, due to Milnor.)
  • #43
It has to do with equivalence classes of integer representations of cyclic groups of prime order. I suppose if one extended Milnor's analysis of the Laplacian to manifolds such as these one might get some number theory out of it.
  • Differential Geometry
