Differential calculus, solve for y: 4(y''y'')+(y'y')-1=0
In summary, the conversation discusses solving a differential equation with the variables y, r, and s. The equation is given as 4(y''y'')-(y'y')-1=0=4(r^2)^2-(r^2)-1=4(s^2)-s-1 and can be rewritten as 4(r’)^2-r^2+1=0. The conversation suggests defining a new variable, r, and letting y’=r to make the problem a first-order differential equation. The equation can then be solved using the formula s=(-b±√(b^2-4ac))/2a to find the value of s, which is then used to find the value of
endykami
quadratic differential calculus
solve for y
suppose y''=r^2=s
y'=r
s=(1±√17)/8
y=∫∫sdx=∫∫((1±√17)/8) dx=(1±√17)/8)(1/2)x^2+c1x+c2
Hello endykami ##\quad## :welcome: ##\quad## !
endykami said:
suppose y''=r^2=s
y'=r
If y'=r then y'' = r', not r2
Likes endykami
You might as well define a new variable e.g. r, let y' = r to recognise you really ha e a first order d.e. To solve in the first place.
Are you sure you transcribed the problem right? - it is a bit unusual to write all squares as (x.x)
Likes endykami
Here, I’ll get you started: let y’=r => y’’=r’ and the equation becomes:
4(r’)^2-r^2+1=0
Likes endykami
Related to Differential calculus, solve for y: 4(y''y'')+(y'y')-1=0
1. What is differential calculus?
Differential calculus is a branch of mathematics that deals with the study of rates of change, slopes, and curves. It involves the use of derivatives and integrals to analyze and solve problems related to change.
2. How do you solve for y in differential calculus?
To solve for y in differential calculus, you need to use the rules of differentiation and integration. In the given equation, you can first rearrange the terms and then use the power rule, product rule, and chain rule to find the derivative of y. You can then integrate the resulting function to get the general solution for y.
3. What is the meaning of y'' and y' in the equation?
In differential calculus, y'' represents the second derivative of y, which is the rate of change of the rate of change of y. This can be thought of as the curvature of the graph of y. Y' represents the first derivative of y, which is the instantaneous rate of change of y at a specific point on the graph.
4. What are the steps to solving a differential calculus problem?
The steps to solving a differential calculus problem are as follows: 1. Identify the variables and their relationships in the problem.2. Use appropriate differentiation or integration rules to find the derivative or integral of the given function.3. Apply any necessary algebraic manipulations to rearrange the equation.4. Substitute any known values into the equation.5. Solve for the unknown variable.
5. Can differential calculus be applied in real-world situations?
Yes, differential calculus has many real-world applications, such as in physics, engineering, economics, and biology. It can be used to analyze and optimize rates of change, such as velocity, acceleration, growth, and decay. It can also be used to find maximum and minimum values of functions, which is useful in optimization problems.
