Displacement v Time graph for a wave
In summary: No, strings can't support longitudinal waves because the stress/tension on the string will always cause it to oscillate in the direction of the applied stress.No, strings can't support longitudinal waves because the stress/tension on the string will always cause it to oscillate in the direction of the applied stress.OK so how can you get a transverse displacement without stretching the string?
trollcast
I'm given a graph with displacement in metres on the y-axis and time on the x-axis. The graph represents the displace of a particle of a spring that has a mechanical wave passing through it
The graph is just a simple sine wave.
It then asks to describe the displacement of the particle compared to the velocity of the wave and then state and explain whether the wave is longitudinal or transverse.
Since the particles displacement is changing from positive to negative periodically I'm assuming the particle is oscillating in the direction of the waves velocity so therefore the wave would be longitudinal since the particle is vibrating parallel to the direction of motion of the wave?
Well OK, but what has that to do with the task you have been set?
By "velocity of the wave", which wave do they mean? The wave of the mass oscillating that you have been given or the wave traveling along the spring? (Are you sure this is a mass moving as a result of a wave traveling along a spring and not SHM?)
Thats all the question states:
A wave of fixed velocity passes along a spring.
The graph below shows a graph of the displacement, d of a particle of the spring against time t.
Describe the direction of the particles displacement relative to the velocity of the wave and therefore state the type of wave and explain why you chose this:
It couldn't be SHM as we haven't covered that yet.
Uh OK - there's not enough information is there? How would you know if the displacement on the graph is measured along the velocity of the wave or perpendicular to it?
The particles could be oscillating side-to-side as the spring lies along the floor. Displacement to the left being positive and to the right being negative.
The only other information you're given is a couple of numbers on the graph but they're no help?
I looked at the next page and it says its actually a string, must be a misprint on the first page, so I'm going to say transverse and just hope its right.
Task requires a reason ... "I hope it's right" is a good enough reason?
Can strings not carry longitudinal waves?
But you have the right idea - the clue is probably in context rather than actually written down. What would be accepted as a reason? Is there anything in your course notes?
Ah found it now, it says the string is under a constant tension so that would stop a longitudinal wave being formed along it since the "pressure" (not sure what's the right word since its a string) difference can't be formed.
There you go - if the tension is uniform along it's length then compressions and expansions cannot be present. When you pull a guitar string, doesn't it stretch? Can you get a transverse displacement without stretching the string?
Related to Displacement v Time graph for a wave
1. What is a displacement v time graph for a wave?
A displacement v time graph for a wave is a visual representation of how the displacement of a wave changes over time. It plots the displacement of a wave on the y-axis and time on the x-axis.
2. How do you interpret a displacement v time graph for a wave?
To interpret a displacement v time graph for a wave, you can look at the shape of the graph. A positive slope indicates a wave moving in the positive direction, while a negative slope indicates a wave moving in the negative direction. The amplitude of the wave can also be determined by looking at the distance between the peak and the equilibrium position.
3. What is the relationship between displacement and time on a displacement v time graph for a wave?
The displacement of a wave is directly related to time on a displacement v time graph. As time increases, the displacement of the wave also increases. This relationship can be seen in the slope of the graph, where a steeper slope indicates a faster change in displacement over time.
4. How does the frequency of a wave affect the displacement v time graph?
The frequency of a wave, or the number of complete cycles per second, affects the displacement v time graph by changing the shape of the graph. A higher frequency wave will have more cycles in a given time period, resulting in a graph with a shorter wavelength and a higher amplitude.
5. Can a displacement v time graph for a wave show the speed of the wave?
Yes, a displacement v time graph for a wave can show the speed of the wave. The speed of a wave can be determined by dividing the wavelength by the period, which is the time it takes for one complete cycle. This value can be found by measuring the distance between two consecutive peaks or troughs on the graph and dividing it by the time between those points.
9K
