Distance between ships at 4 pm
  • MHB
  • Thread starter karush
  • Tags
    Ships
In summary, we use the Pythagorean theorem to find the distance between two ships at different times. By differentiating with respect to time, we can also find the rate at which the distance is changing. Using this method, the distance between the ships at 4:00 pm was found to be increasing at a rate of approximately 21.3933 kilometers per hour.
karush
MHB
3,269
wasn't sure but made the \(\displaystyle \frac{da}{dt}\) negative since the ships are drawing closer to each other at least before 4pm
Re: distance between ships at 4pm
Your answer agrees with the result I got when I recently worked this problem when it was posted at Yahoo! Answers. This was the reply I gave:
Let's orient our coordinate axes such that ship A is at the origin at noon, and so ship B is at $(150,0)$. Thus, we may describe the position of each ship parametrically as follows:
Ship A:
\(\displaystyle x=35t\)
\(\displaystyle y=0\)
Ship B:
\(\displaystyle x=150\)
\(\displaystyle y=25t\)
If we let $D$ be the distance between the ships at time $t$, we may use the distance formula to write:
\(\displaystyle D^2(t)=(35t-150)^2+(25t)^2=50\left(37t^2-210t+450 \right)\)
Implicitly differentiating with respect to $t$, we find:
\(\displaystyle 2D(t)D'(t)=50(74t-210)=100(37t-105)\)
Hence:
\(\displaystyle D'(t)=\frac{50(37t-105)}{D(t)}=\frac{\sqrt{50}(37t-105)}{\sqrt{37t^2-210t+450}}\)
At 4:00 pm, we have $t=4$, and so we find:
\(\displaystyle D'(4)=\frac{\sqrt{50}(37(4)-105)}{\sqrt{37(4)^2-210(4)+450}}=\frac{215}{\sqrt{101}}\,\frac{\text{km}}{\text{hr}}\)
Thus, at 4:00 pm the distance between the ships is increasing at a rate of about 21.3933 kph.
do you always use generally.
\(\displaystyle D^2(t)=x^2+y^2\)
with these triangle problems, it seems the book examples do the same. I guess its a nice template to use..
Yes, for right triangles, it follows directly from the Pythagorean theorem. :D
Related to Distance between ships at 4 pm
What is the distance between ships at 4 pm?
The distance between ships at 4 pm can vary depending on the location of the ships, the speed at which they are traveling, and any potential obstacles or detours they may encounter.
How is the distance between ships at 4 pm calculated?
The distance between ships at 4 pm is typically calculated using mathematical formulas that take into account the ships' coordinates, speed, and direction of travel. Other factors such as wind and current may also be considered in the calculation.
Why is the distance between ships at 4 pm important?
The distance between ships at 4 pm is important for navigation and safety purposes. It allows ship captains to maintain a safe distance from other vessels and avoid potential collisions. It also helps in planning routes and avoiding congestion in busy waterways.
Can the distance between ships at 4 pm change?
Yes, the distance between ships at 4 pm can change due to various factors such as changes in speed or direction of travel, weather conditions, and the presence of other ships or objects in the surrounding area. It is important for ships to regularly monitor and adjust their distance to ensure safe navigation.
Is there a standard distance between ships at 4 pm?
No, there is no standard distance between ships at 4 pm as it can vary depending on the specific circumstances and conditions of the ships and their surroundings. However, there are international guidelines and regulations in place to ensure safe distances are maintained between ships to prevent accidents and collisions.
Writing: Input Wanted Captain's choices on colony ships
