Does dark energy or cosmic inflation explain flatness?
In summary: The 70 percent mass-energy contributed by dark energy is described as 'missing' in relation to the total mass-energy density of the universe.
  • #36
PeterDonis said:
If the only stress-energy in the universe is matter (##p = 0##) or radiation (##p = \rho / 3##), then the two concepts of "critical density" (expansion vs. collapse and zero spatial curvature) coincide. But in the presence of stress-energy with the equation of state of a cosmological constant (##p = - \rho##), they don't. What cosmologists call the "critical density" for our best current model of the universe, which includes a positive cosmological constant, is the "flatness" one, although many cosmologists are not clear about that and will refer to the "expansion vs. collapse" definition without clarifying that that definition doesn't really apply to our actual best current model of the universe. (Believe it or not, Wikipedia actually gets this right in its "critical density" article.)
Thanks for clearing this up. I’m reading ‘heart of darkness’ by Ostriker and Mitton which is in between popular science and actual physics, but closer to popular science - it is a fantastic historical account of the development of LCDM model of cosmology, but the chapter on dark energy is a bit of a dog’s breakfast and suddenly looses readability. Part if this is a sudden shift from focusing on expansion vs contraction critical density to the conditions needed for flatness.
Space news on Phys.org
  • #37
RogerWaters said:
exponential expansion of, say, a massive balloon may all but flatten local sections of it (to an observer living on the surface) but it won’t change the critical density needed for flatness
If we're talking about exact exponential expansion, i.e., a cosmological constant with nothing else present, the critical density and the actual density are already the same. Just look at the math I gave earlier. Note carefully that for exact exponential expansion, the Hubble constant ##H## is literally constant--it has the same value everywhere in the spacetime.
If we're talking about inflation, asuming the scalar inflaton field is not exactly constant with time (or our current dark energy-dominated universe, which is also driving itself towards exact flatness, though much more slowly than inflation did), then the Hubble "constant" ##H## is not literally constant; it does change with time. And that is equivalent to the critical density changing with time. Again, just look at the math: the critical density is the Hubble constant ##H##, with some multipliers that are just fixed numbers.
Perhaps it might be helpful to consider several different cases and look at how the Hubble value ##H## changes with time in those cases:
Closed universe, zero cosmological constant: ##H## starts out positive, decreases to zero, and goes negative (because the universe recollapses).
Open universe, zero cosmological constant: ##H## starts out positive and decreases forever, asymptotically approaching a finite positive value which is determined by the curvature term in the Friedmann equation.
Flat universe, zero cosmological constant: ##H## starts out positive and decreases forever, asymptotically approaching zero.
Flat universe, positive cosmological constant, nothing else present (de Sitter): ##H## is always constant, at the value determined by the cosmological constant.
Universe being driven towards flat; either inflaton scalar field, or positive cosmological constant (dark energy) with other matter/radiation also present: ##H## starts out positive and decreases forever, asymptotically approaching a finite positive value which is determined by the cosmological constant (or the inflaton scalar field in the inflation case).
Now let's rewrite the above in terms of the actual density vs. the critical density:
Closed universe, zero cosmological constant: actual density is always greater than critical density; actual density starts out positive, decreases until maximum expansion, then increases again.
Open universe, zero cosmological constant: actual density is always less than critical density; actual density starts out positive and decreases forever, asymptotically approaching zero.
Flat universe, zero cosmological constant: actual density is always exactly equal to critical density.
Flat universe, positive cosmological constant, nothing else present (de Sitter): actual density is constant, at the value determined by the cosmological constant. This is also the critical density, so actual density is always exactly equal to the critical density.
Universe being driven towards flat; either inflaton scalar field, or positive cosmological constant (dark energy) with other matter/radiation also present: actual density starts out positive and decreases forever, asymptotically approaching the density determined by the cosmological constant (i.e., everything that isn't cosmological constant (or inflaton scalar field in the inflation case) gradually dilutes to zero). Since that density is also the critical density, the actual density and the critical density are driven towards the same value.
Note that, while the flat universe with zero cosmological constant looks different in terms of ##H## than the de Sitter case, in terms of actual density vs. critical density they are the same.
  • #38
RogerWaters said:
Here is Krauss on page 86 of A Universe from Nothing: "[70 percent] is, remarkably, what is needed in order to make a flat universe consistent with the fact that only 30 percent of the required mass exists in and around galaxies and clusters". Here is Brian Greene in The Fabric of the Cosmos: "Since the early days of general relativity, physicists have realized that the total matter and energy in each volume of space - the matter/energy density - determine the curvature of space... for a very special amount of matter/energy density - the critical density - space will... be perfectly flat: that is, there will be no curvature". Here is Ostriker and Mitton in Heart of Darkness: Unravelling the Mysteries of the Invisible Universe:
Consider also reading Alan Guth's popular science publications:
Amazon carries the former listing in hardcover and paperback. As a professor Guth is quite readable.
Likes RogerWaters
  • Cosmology
