Does gravity affect quantum transition amplitudes?
In summary, the conversation discusses the effect of gravity on quantum phases and transition probabilities. The classic "COW experiment" showed that the gravitational potential affects quantum phases, and the paper attached to the conversation provides further details. The conversation also mentions the possibility of changes in transition probabilities due to gravity, and references a paper on the Unruh effect. However, it is noted that the COW experiment involved falling neutrons and not accelerating frames, so this may not be relevant.
Aidyan
180
I suppose the answer is no, since there is no reason to believe that it does. Or is there any? Has this been tested experimentally? Or is there an obvious reason that it does or does not?
It certainly does. The classic "COW experiment" used neutron interferometry to show that the gravitational potential affects quantum phases just as one would expect. The paper is attached.
  • COW_PhysRevLett.34.1472.pdf
Likes zonde and Mentz114
Hmm... sorry my question was ill posed. I mean the transition probability which should not depend from the quantum phase (squared modulus of the amplitude).
I am not quite sure what you mean, so I apologise if I have misinterpreted things.
An overall phase does not change the squared modulus, and thus is not observable, but a relative phase usually causes interference effects that are observable. The latter is the case in the famous paper that @phyzguy posted.
For example, if ##\psi' = e^{i\phi} \psi##, then ##\left| \psi' \right|^2 = \left| \psi \right|^2##.
If ##\psi' = \psi + e^{i\phi} \psi##, then
$$\begin{align}
\left| \psi' \right|^2 &= \left| \psi \right|^2 + e^{-i\phi} \left| \psi \right|^2 + e^{i\phi} \left| \psi \right|^2 + \left| \psi \right|^2\\
&= 2 \left( 1 + \cos \phi \right) \left| \psi \right|^2
\end{align}$$
and
$$\frac{\left| \psi' \right|^2}{\left| \psi' \right|^2_{\phi = 0}} = \frac 1 2 \left( 1 + \cos \phi \right) ,$$
which varies between 0 and 1.
Roughly, in the above paper, the relative phase in the above paper depends on relative gravitational potential (due to height difference) of two arms of a neutron interferometer, and change in gravitational potential is very much obsevable.
Not Beyond the Standard Model, though.
What I mean are the transition probabilities in QM, i.e. the probability between the initial and final state of a quantum system (atomic or nuclear transitions, scattering, etc.). That one that are calculated with time-dependent perturbation theory in the interaction picture which gives:
##P_{if}(t)=\left|\left<\Psi_{f}|\Psi(t)\right>_{I}\right|^2 = \left|\left<\Psi_{f}|\hat{U_{I}}(t,t_{i})| \Psi_{i}\right>\right|^2,##
which is the transition probability from an unperturbed initial state ##\Psi_{i}## to a final state ##\Psi_{f}## with ##\hat{U_{I}}(t,t_{i})## the evolution operator in the interaction picture. And, when expressed back in the Schrödinger picture it is:
##P_{if}(t)=|\left<\Psi_{f}|\Psi(t)\right>_{S}|^2 = |\left<\Psi_{f}|\sum_{n} c_{n}(t) e^{-iE_{n}t/\hbar}|\Psi_{n}\right>|^2 = |c_{f}(t) e^{-iE_{n}t/\hbar}|^2=|c_{f}(t)|^2,##
with ##c_{n}## an ##c_{f}## complex amplitudes which squared modulus gives the transition probabilities (which value can be calculated from matrix elements of the perturbing potential) and the latter equality showing that phases are irrelevant (I skipped lots of stuff here... please see every textbook on QM for more details).
Since this is classical QM, my doubt was that this does no longer hold in the presence of a curved spacetime background and needs extension (not just with SR, as in QFT of the SM, but with GR). If so, transition probabilities change in the presence of gravity, which means that the radiative transition spectrum of matter changes, for instance that of falling into a BH (it is not just redshift, it is about the structure of the spectrum). I suppose it is something already extensively analyzed (especially in quantum gravity theories) but could not find a reference to that. I ask because eventually that should not be too complicate to check experimentally. Or is there an obvious reason to dismiss this altogether?
Aidyan said:
What I mean are the transition probabilities in QM, i.e. the probability between the initial and final state of a quantum system (atomic or nuclear transitions, scattering, etc.).[]
The Unruh effect applies to accelerating frames and by the equivalence principle one could expect something similar for a system at rest in a gravitational field. This paper could be of interest
https://arxiv.org/abs/quant-ph/0509151
[ On reflection this is probably irrelevant. The neutrons in the COW experiment were falling, and the effect is attributed to the gravtational potential. No accelerations there.]
Related to Does gravity affect quantum transition amplitudes?
1. How does gravity affect quantum transition amplitudes?
Gravity affects quantum transition amplitudes by altering the spacetime curvature, which in turn affects the behavior of particles. This can cause changes in the probability of quantum transitions occurring.
2. Can gravity change the path of quantum particles?
Yes, gravity can change the path of quantum particles by curving the spacetime around them. This can cause the particles to follow a different trajectory than they would in a flat spacetime.
3. Is gravity a factor in quantum mechanics?
Yes, gravity is a factor in quantum mechanics. It is one of the four fundamental forces of nature and plays a role in determining the behavior of particles at a quantum level.
4. Does the strength of gravity affect quantum transition amplitudes?
Yes, the strength of gravity can affect quantum transition amplitudes. The stronger the gravitational force, the greater the curvature of spacetime, which can impact the probability of quantum transitions occurring.
5. Are there any experiments that have demonstrated the effect of gravity on quantum transition amplitudes?
Yes, there have been experiments that have demonstrated the effect of gravity on quantum transition amplitudes. For example, the Pound-Rebka experiment showed that the frequency of emitted photons from an atom changes when moving from a higher gravitational potential to a lower one, indicating a change in quantum transition probabilities.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
