Dropped from a hot air balloon
In summary, a hot-air balloon ascending at 11 m/s and 53 m above the ground drops a package. The package will take time to reach the ground, which can be calculated using the equation 53 = -11t + 4.9t^2. The positive root of this quadratic equation will give the time for the package to hit the ground. The speed at which it hits the ground can be calculated using the equation v = u + at, with the initial velocity (u) being -11 m/s (since the balloon is ascending) and the acceleration (a) being -9.8 m/s^2 (due to gravity). The displacement (s) in this equation should be the same as the
AlKaiser
1. A hot-air balloon is ascending at the rate of 11 m/s and is 53 m above the ground when a package is dropped over the side. (a) How long does the package take to reach the ground? (b) With what speed does it hit the ground?
2. v = u + at
s = ut + 1/2 a t^2
v^2 = u^2 + 2as
3. s = 53m
u = 11 m/s
v =
a = -9.8 m/s^2
t =
So far I've tried v = u+at, but stoppped when i realized I had 2 unknowns.
( v = 11 + -9.8 t )
I've also tried s = ut + 1/2 at^2 to no avail
( 53 = 11t + 1/2 (-9.8) t^2 )
Also tried v^2 = u^2 + 2as but I got something like -1000 so it didn't make sense to me.
I've hit a mental block, and it doesn't look like i's going to move any time soon, which isn't helpful since this thing is due in 10 hours. Sorry if I've put this in the wrong place or with the wrong title, because right now I'm not sure what it is, oher than a torture device. The answer will probably turn out to be easy to get, but right now it isn't working for me. Any and all help would be greatly appreciated.
Hi AlKaiser,
2. v = u + at
s = ut + 1/2 a t^2
v^2 = u^2 + 2as
3. s = 53m
u = 11 m/s
v =
a = -9.8 m/s^2
t =
( v = 11 + -9.8 t )
I believe this equation will give you the time for the package to hit the ground.
Your displacement is not quite right here. If the package falls from the balloon and hits the ground, the displacement is not 53 m; what would it be?
Ok, so if it's not 53 metres, does that mean that the crate travels up before it travels down? Or is it -53m? I'm sorry, but I honestly am stumped on this one. I'm going to need a bigger hint because I really don't see how it isn't 53. (I'm not askin for the answer, just a bit more of a hint, as I'm not getting any closer atm)
AlKaiser said:
... , does that mean that the crate travels up before it travels down? Or is it -53m?
Depends on where 0 is.
If ground is 0 and you drop it from 53 then your Yo is 53. Otherwise if you drop it from 0, then it lands at - 53. Your choice, but once chosen stick to it like glue.
The displacement includes the direction, and so since the displacement is in the same direction as the acceleration (downward), it would need to have the same sign as the acceleration.
(For these 1-dimensional problems, everything in the same direction has to have the same sign, and things in opposite directions have to have opposite signs.)
That's certainly true of course, but the form of his equation had the displacement instead of the initial and final position.
I think you'll have to take u as negative because baloon is traveling up.When it goes down, g is not -9.8m/s^2, but +9.8 m/s^2, because it is positively accelerating.
53=-11t+1/2*9.8*t^2.
53=-11t+4.9t^2
Its a quadratic equation!
4.9t^2-11t-53=0
Youll have to take the positive root.
Now, you can calculate v.(v=u+at)
Its simple, hope I am not wrong.
Can someone say whether I am correct or not?
Right you are. I just never use S.
Btw, good to see you back.
Look at it this way; the balloon and its contents are ALL ascending at 11 m/s therefore, at the very instant that the package is released, it must slow from its 11 m/s ascent to its apex prior to being able to free-fall back to earth. You have this ascent time as well as the free-fall time from the apex as your total time.
Thanks! A few cruel turns in life had conspired to keep me from spending time at this wonderful place (I'm sure you can imagine how hard staying away from here would be). I've got a few more trips that will interfere in the near future, but I hope to be visiting here daily again very soon.
Related to Dropped from a hot air balloon
1. How high can a hot air balloon be dropped from?
The maximum height a hot air balloon can be dropped from is determined by the type of balloon and the weight of the basket and passengers. The average height for a safe drop is around 800-1000 feet.
2. What happens to the temperature inside a hot air balloon when it is dropped?
The temperature inside a hot air balloon will remain relatively constant when it is dropped. The balloon will not suddenly become cold or hot, as the temperature inside is regulated by the burner.
3. Can a hot air balloon be safely dropped from any altitude?
No, it is not safe to drop a hot air balloon from any altitude. The balloon must be dropped from a safe height to ensure the safety of the passengers and the integrity of the balloon.
4. How does a hot air balloon drop safely?
A hot air balloon can drop safely by gradually decreasing altitude using the burners to release hot air and control the descent. The pilot must also take into consideration wind speed and direction to safely land the balloon.
5. What are the potential risks of dropping from a hot air balloon?
The potential risks of dropping from a hot air balloon include injury to passengers if the drop is not controlled or if the landing is rough. The balloon may also sustain damage if it lands in a rough terrain. It is important for a trained and experienced pilot to handle the balloon during a drop.
