Dual mass flywheel clutch - How does it make a difference?
In summary: en/departments/technology-equipment-engineering-and-standardization/research/dynamic-clutch-inertia-and-clutch-power
k.udhay
160
I was going through these two documents:
https://www.schaeffler.com/remoteme...effler_2/symposia_1/downloads_11/4_DMFW_1.pdf
http://www.partinfo.co.uk/docs/140
My primary interest was to understand why and how Dual Mass Flywheel (DMF) is superior over the conventional Single Mass Flywheel (SMF) clutch.
DMF undergoes three major differences in construction:
1. Flywheel mass is split into two pieces - Primary mass and Secondary mass
2. Damper springs are fitted to the primary mass
3. Clutch plate is assembled to secondary mass
These are my two questions:
1. What difference does it make by doing the above changes?
2. If I just increase the transmission input shaft inertia, is it not mathematically equivalent to the DMF construction? Because, the core change in DMF is that there is a mass after dampening. Pl. help.
You may have noticed that the damper springs in the DMF are much longer than in the SMF. Also in the DMF, most of the flywheel mass is in the second flywheel.
This allows a much lower spring constant (higher compliance) of the damper springs, and consequently better decoupling the engine rotational variations from the flywheel/drive train.
EDIT: As an example consider a jug of water suspended from you hand with a rope (the SMF damper springs) versus suspended with a long rubber band (DMF damper springs). If you rapidly jiggle your hand up and down using the rope, the jug will follow. If you use a rubber band, the jug will not move as much.
end edit:
Likes k.udhay
You basically move the mass moment of inertia (MMoI) from the engine side to the transmission side.
The engine rpm is varying, but what you really care about is that the transmission rpm is stable. Increasing the transmission MMoI will do that. Transferring mass from the engine side to the transmission side, means you don't have to increase the total mass.
Inertia is more than mass; You have to consider the radius too. The further the mass is from the center of rotation, the greater the MMoI.
So, to increase the MMoI of the transmission by increasing the input shaft mass (close to center of rotation), you would have to have a greater mass than what you would remove from the engine flywheel (located at a larger radius). This would result in an increase in total mass.
  • Love
Likes k.udhay
end edit:
Lovely example, Tom! So glad that I posted the question here. Thanks a ton!
Likes Tom.G
Thanks for giving a detailed answer, Jack. So we prefer to add inertia in clutch side instead of T/m as clutch can allow mass addition at a higher radius practically.
Our department of technological equipment, engineering and standardization at Karaganda State Technical University deals with these researches http://www.kstu.kz/
Likes Tom.G
Related to Dual mass flywheel clutch - How does it make a difference?
1. What is a dual mass flywheel clutch?
A dual mass flywheel clutch is a type of clutch system that is composed of two rotating masses connected by a series of springs. It is designed to reduce vibrations and improve smoothness in the transmission system of a vehicle.
2. How does a dual mass flywheel clutch work?
The two rotating masses in a dual mass flywheel clutch are able to absorb and dampen vibrations from the engine, which helps to reduce wear and tear on the transmission system. The springs in the system also help to isolate the engine from the transmission, resulting in smoother gear changes.
3. What are the benefits of using a dual mass flywheel clutch?
Using a dual mass flywheel clutch can provide several benefits, including reduced noise and vibrations, improved fuel efficiency, smoother gear changes, and increased longevity of the transmission system.
4. Can a dual mass flywheel clutch be repaired or replaced?
In most cases, a dual mass flywheel clutch cannot be repaired and must be replaced if it becomes damaged or worn out. However, it is important to have a professional mechanic diagnose the issue before replacing the clutch, as there may be other underlying problems causing the issue.
5. Are there any downsides to using a dual mass flywheel clutch?
One potential downside of using a dual mass flywheel clutch is that it can be more expensive to replace compared to a traditional clutch system. Additionally, some drivers may find that the system feels different than a traditional clutch, which may take some getting used to.
