Eddy currents in Faraday's Law Experiment
In summary, the coil produces an alternating magnetic field which induces an emf in the secondary coil. The changing magnetic field of the primary coil weakens the emf in the secondary coil, and so the light bulb always stays on.
KDPhysics
74
23
Explain this experiment: https://www.youtube.com/watch?v=r21ybCwXMjo
minute 4:45 - 5:40
Faraday's Law
Lenz's Law
My explanation:
A circular coil is connected to an AC supply at a frequency of 30-50 kHz (radio frequency). Therefore, an alternate current will be running through this “primary” coil, producing an alternating magnetic field. This magnetic field periodically decreases in strength, alternating direction with the same frequency at which the current alternates.
A second circular coil is brought near the primary coil. Therefore, the changing magnetic field will induce an emf in the secondary coil. By Lenz’s Law, nature abhors any change in magnetic flux. So, due to the decreasing/increasing field, the secondary coil will have an induced emf such that its own magnetic field opposes the change in flux. If the magnetic field of the primary coil is decreasing, the induced emf will be in the direction to produce its own magnetic field in the same direction, “strengthening it”.
Therefore, alternate current will run through the secondary coil at a 30-50 kHz frequency. However, the light bulb physically can’t heat up and cool down at such a high frequency, and as a result all we see is a continuously lit up bulb. However, the induced current is still AC.
When the conductor is placed, eddy currents are formed within the sheet of metal. By Lenz’s law, the magnetic field produced by the eddy currents oppose the primary coil’s magnetic field. As a result, the change in flux through the secondary coil is very small, and so the induced emf will also be small.
Is this explanation correct?
Also, I still don't understand why the light bulb lights up at a certain distance, and when you put it closer to the primary coil it turns off. For example, see minute 5:11. Clearly, only at a couple centimeters away the coil is off, and then it is on again. But if the magnetic field is constantly changing, how is this possible?
I think your explanation is correct.
I think the bulb goes off at 5:11 because the secondary coil at that point goes a bit off to the side of the primary coil (and not exactly in front) and also the secondary coil axis is a bit tilted and is not perfectly aligned with the axis of the primary. So for those two reasons the magnetic flux through the secondary is reduced.
Ah that's right, the "tilt angle" also affects the magnetic flux.
Likes Delta2
This isn't always true is it? For example, when the primary coil's field is decreasing, then the field produced by the eddy currents will tend to "reinforce" (rather than oppose) the primary field. But, maybe you meant to say that the field produced by the eddy currents opposes the change in the primary coil's field.
That was a fun video to watch :oldsmile:
Likes Delta2
Related to Eddy currents in Faraday's Law Experiment
1. What are eddy currents?
Eddy currents are circular electric currents that are induced in a conductor when it is exposed to a changing magnetic field. They are also known as Foucault currents.
2. How are eddy currents related to Faraday's Law?
Eddy currents are a direct consequence of Faraday's Law, which states that a changing magnetic field will induce an electric field in a conductor. This electric field then causes the flow of eddy currents in the conductor.
3. What is the purpose of conducting the Faraday's Law experiment with eddy currents?
The purpose of conducting the experiment with eddy currents is to demonstrate the practical application of Faraday's Law in generating electricity. Eddy currents can be harnessed and used to power devices such as generators and motors.
4. How do eddy currents affect the efficiency of electrical devices?
Eddy currents can cause energy loss in electrical devices, as they produce heat due to the resistance of the conductor. This can decrease the efficiency of the device and lead to potential overheating issues.
5. What are some real-world examples of eddy currents?
Eddy currents can be found in many everyday objects, such as electric motors, transformers, and induction cooktops. They are also utilized in technologies such as magnetic levitation trains and metal detectors.
