Electrochemical Cells (involving partial pressures and pH)
In summary, the voltaic cell utilises the following reaction:4 Fe2+(aq) + O2(g) + 4 H+(aq) ---> 4 Fe3+(aq) + 2 H2O(l)The emf of the cell is 1.3 M, the reduction potentials are +0.77 V and +1.23 V, and the pH of the solution in the cathode is 3.5.
miniradman
196
A voltaic cell utilises the following reaction:
What is the emf of this cell when [Fe2+] = 1.3 M, [Fe3+] = 0.010 M, PO2 = 0.51 bar and the pH of the solution in the cathode is 3.5.
The standard reduction potentials for each half-reaction.
Fe3+(aq)+ e- ---> Fe2+(aq) Eored = +0.77 V
O2(g) + 4 H+(aq) + 4 e- ---> 2 H2O(l) Eored = +1.23 V
## E = E^o - \frac{RT}{nF}ln|Q| ##
Q=[Products][Reactants]
I'm not exactly sure how to incorporate the pH and Partial pressure of oxygen into this equation, but I had a go.
## \frac{P}{RT} = C ##
## \frac{51}{(8.314)(298)} = C ##
## {0.027M = C} ##
C being the concentration of Oxygen:
Then proceeded to find the concentration of hydrogen
## pH = -log_{10}|[H^+]| ##
## 3.5 = -log_{10}|[H^+]| ##
## 10^{-3.5} = [H^+] ##
## 0.00032M = [H^+] ##
Then I found the half reactions for the redox reaction:
## 4Fe^{2+} \rightarrow 4Fe^{3+} + 4e^- ## ---- Oxidation (+0.77V)
## 4e^- + O_2 + 4H^+ \rightarrow 2H_2O ## ---- Reduction (+1.23V)
Hence,
## E^o = E_{reduction} - E_{oxidation} ##
## E^o = (1.23) - (0.77) ##
## E^o = 0.46V ##
Now to find Q (I think this is where my error could be, I'm not sure what to do with the water, but I figured the concentration may be 1?).
## Q = \frac{[products]}{[reactants]} ##
## Q = \frac{[Fe^{3+}]}{[H^+]^4[O_2][Fe^{2+}]^4} ##
## Q = \frac{(1*10^{-8})}{(0.00032)^4(0.027)(1.3)^4} ##
## Q = 1250 ## (rounded, obviously)
Now using the equation:
## E = 0.46 - \frac{(8.314)(298)}{(4)(96485)}ln|1250| ##
## E = 0.46 - 0.0457 ##
## E = 0.41V ##
however, this is incorrect. The correct answer is:
0.37V
What is the Nernst equation for the formal potential of this half cell?
Ok...
## E = E^o - \frac{RT}{nF} ln| Q | ##
## Q = \frac{[H_2O]}{[O_2][H^+]^4} ##
## Q = \frac{1^2}{(0.00032)^4(0.027)} ##
## ln|Q| = 35.8 ##
so:
## E = (1.23) - \frac{(8.314)(298)}{(4)(96485)} (35.8) ##
## E = (1.23) - 0.230 = 1 ##
Hmm, and If I did the same with the other half cell?
I get ## E = 0.801 ##, but I digress...
Q should use partial pressure of the gas, not the concentration.
Righto, I converted it to a Kpa, I just has a feeling that Bar is not a the correct unit of measurement.
## Q = \frac{1}{(51)^4(0.027)} ##
## ln|Q| = -11.9 ##
## E = 1.23 - \frac{(8.314)(298)}{(4)(96485)}(-11.9) ##
## E = 1.306V ##
Quick question, why do I use the partial pressure of Oxygen as opposed to concentration (## M ##), doesn't the ##Q## have to be dimensionless?
To confuse you further, is Q for
HA <-> H+ + A-
dimensionless?
Q should be constructed using not concentrations, but dimensionless activities. Activity of a substance - for a diluted solution - is approximately equal its concentration, so we typically omit the activity coefficients assuming it equals 1 - but in effect we also introduce dimensionality into the equation.
I see, I always assumed it to be dimensionless (as a ratio of concentration), since it's analogous to equilibrium constant.
I'm still not sure exactly sure how to calculate ##Q##
Standard state of a gas is 1 bar, so just putting 0.51 as a partial pressure of oxygen should work.
Related to Electrochemical Cells (involving partial pressures and pH)
What is an electrochemical cell?
An electrochemical cell is a device that converts chemical energy into electrical energy. It consists of two half-cells, each containing an electrode and an electrolyte solution. The two half-cells are connected by a wire and a salt bridge, allowing the flow of ions between them.
How do partial pressures affect electrochemical cells?
In an electrochemical cell, the partial pressures of the reactants and products can affect the direction and rate of the chemical reactions taking place. Changes in partial pressures can alter the concentration of ions in the electrolyte solutions, thus affecting the potential difference and current produced by the cell.
What is the relationship between pH and electrochemical cells?
pH is a measure of the acidity or basicity of a solution. In electrochemical cells, changes in pH can affect the concentration of ions in the electrolyte solutions, which in turn can alter the potential difference and current produced by the cell. pH can also affect the rate of chemical reactions taking place at the electrodes.
How do electrochemical cells work?
Electrochemical cells work by converting chemical energy into electrical energy through a redox reaction. In a galvanic cell, the spontaneous flow of electrons from the anode to the cathode produces a potential difference and current. In an electrolytic cell, an external power source is used to drive a non-spontaneous redox reaction.
What are some real-life applications of electrochemical cells?
Electrochemical cells have a wide range of applications in our daily lives, including batteries for electronic devices, fuel cells for vehicles, and corrosion protection for structures. They are also used in chemical sensors, electroplating, and wastewater treatment. In medicine, electrochemical cells are used in devices such as pacemakers and glucose meters.
9K
