Electron Doping and Permittivity
In summary, electron doping in certain materials, such as Nb in TiO2, can lead to an increase in permittivity due to the extra electrons causing a higher polarizability. However, this effect is only significant at high doping levels, and at lower levels, the permittivity increase is counteracted by an increase in dielectric loss. This is due to the delocalization of the extra electrons, resulting in increased conductivity and higher dielectric loss.
citw
72
I've read that electron doping in certain materials can lead to higher permittivity (for example, Nb in TiO2). This is a little confusing to me, as permittivity decreases with conductivity (see http://en.wikipedia.org/wiki/Permittivity#Lossy_medium). Can anyone explain this to me?
P.S.: Both the dielectric constant and dielectric loss appear to increase with the case I mentioned above. I can understand the loss term increasing, but not the overall dielectric constant.
Which frequency range do you have in mind?
Any. I'd like to know how this would ever make sense.
Ok, so where did you read this:
Now, as you refuse to specify the situation you are really interested in, I can't give you but a very general argument:
There are some sum rules which make statements about the integral of the permittivity over frequency. Typically, these sum rules are proportional to the total number of electrons, so if that number increases, the permittivity will do so on the mean, too.
See, e.g.: http://www.atlas.uni-wuppertal.de/FP/anleitungen/fpI-10/paper_FPII2/pr128b.PDF
Now adding just some electrons won't change the permittivity by much on average, but there may be certain frequency ranges where the change is larger.
I didn't mean it too seriously ;-)
But from that link I infer that you are interested in the low frequency region as they talk about capacitors, and not about e.g. optics.
Alas, I don't have access to that article.
But: Is the doped TiO2 really conductive? If the electrons are just quite weakly bound, it is clear that they are very polarizable and that this increases the dielectric constant.
I think this is where I'm confused... if electrons are weakly bound, I'd take the material to be conductive, and isn't it true that increased conductivity reduces the dielectric constant (via the imaginary term, given for example in the Wikipedia article)?
No, the material won't be necessarily conductive. I guess that the electrons get a very large effective mass due to lattice distortions (polarons).
A criterion for electrons in a semiconductor to behave as a metal is that the Bohr radii calculated with the effective mass and dielectric constant of the background (TiO2) do overlapp. With a large mass, this requires quite some density.
Just to make sure I'm following, polarizability is described by relative permittivity (dielectric constant). The dielectric constant decreases with increasing conductivity, specifically from the imaginary (loss) term. Conductivity is inversely proportional to effective mass, and therefore the polarizability and dielectric constant will increase with larger effective mass.
If I'm following what you're saying correctly, the argument for doping would be that the effective mass of the impurity is larger than that of the intrinsic material, hence increasing the permittivity. Correct?
The binding energy (in the hydrogenic approximation), however, is proportional to the effective mass... so wouldn't a larger effective mass imply a higher binding energy and therefore more tightly bound electrons?
First I don't see why you thinkt that the conductivity decreases with increasing conductivity.
The conductivity makes an imaginary contribution to permittivity and therefore you cannot deduce from the minus sign that it decreases permittivity. On the contrary, its absolute value increases.
Second, this formula holds only for conductors and I was arguing that your doped system is probably not conductive.
At least at small doping levels, the extra electrons will remain bound to the niobium ions. These extra valence electron of the niobium will reside in an orbital whose size can be calculated approximately using Bohrs formula. Metallic behaviour requires that these orbitals overlapp strongly.
If you can't follow me, you should try to look out for "Wannier-Mott excitons" in a good book.
Basically, my understanding is that the effect of Nb doping is an increase in the relative permittivity, but also an increase in the dielectric loss due to delocalized electrons created by Nb.
I found a thesis (in German) on the properties of TiO2:Nb
http://www.gbv.de/dms/ilmenau/toc/685168492.PDF
As I suspected, the Mott criterion for metallic conductivity is fulfilled only for very high doping, at least in rutile (cf. Tab. 2.6).
Is the modification of TiO2 and doping level mentioned in the article you cited?
One case is VERY low - about 0.5%. Reportedly, the permittivity increased by an order of magnitude. However, dielectric loss was "mostly higher than 0.1".
In this case, the authors mention that "delocalized electron transport related interfacial polarization is probably responsible for the observed colossal permittivity behavior, given the obvious grain boundary effects..."
So with minor Nb doping, both permittivity and dielectric loss increase.
The authors also mention that "the electrons in such shallow donor energy levels are virtually delocalized, and can thus freely hop at room temperature, giving high electronic conductivity corresponding to the high dielectric loss observed..."
This sounds like what I was thinking with respect to the loss-conductivity relationship... can you explain what they're describing here if not what I was referring to earlier? It sounds like there is a competition between "interfacial polarization" increasing the permittivity and "high conductivity" increasing dielectric loss. Does this make sense?
DrDu said:
I did some reading and found the following article:
http://www.readcube.com/articles/10.1038/nmat3744?locale=en
It seems to confirm my view that conductivity is rather an unwanted side effect which can be further reduced by co-doping with indium.
This is one of the articles I was reading, and it's referring to the one I just quoted. So conductivity is detrimental to permittivity? I thought you were saying this wasn't the case. Sorry if I'm missing something...
I wouldn't say it is detrimental to permittivity, whatever that may mean. However it is certainly detrimental to the operation of a condensor, especially in the low frequency region at it will simply discharge. It might not be a problem e.g. in the megahertz region or above. Remember my first question about the frequency region you have in mind?
If I understood the abovementioned article correctly, they say that the high permittivity is due to the hopping of electrons inside clusters made from Nb and In without the material being metallic.
So this situation is certainly not being describable in terms of the Drude formula.
Likes 1 person
Related to Electron Doping and Permittivity
What is electron doping?
Electron doping is the process of introducing additional electrons into a material, typically a semiconductor, to modify its electrical properties. This can be done through various methods such as chemical doping, irradiation, or mechanical stress.
What is the purpose of electron doping?
The purpose of electron doping is to alter the electrical conductivity, resistivity, and other electronic properties of a material. This can be used to enhance the performance of electronic devices such as transistors, solar cells, and LEDs.
What is the relationship between electron doping and permittivity?
Electron doping can affect the permittivity of a material, which is a measure of its ability to store electric charge. By introducing additional electrons, the permittivity of a material can be increased, leading to changes in its dielectric constant and other electrical properties.
What are some applications of electron doping?
Electron doping has a wide range of applications in the field of electronics and material science. It is commonly used in the production of semiconductors, transistors, photovoltaic cells, and other electronic devices. It is also used in research to study the effects of electron transport in materials.
What are the challenges in controlling electron doping?
Controlling the amount and distribution of electrons in a doped material can be challenging. It requires precise control over the doping process and the ability to measure and monitor the resulting changes in the material's electrical properties. Additionally, unwanted side effects such as defects and impurities can affect the overall performance of the doped material.
  • Atomic and Condensed Matter
21K
  • Science and Math Textbooks
  • Electrical Engineering
15K
