Electron-Phonon interaction
In summary: Q},\vec{P}} \frac{N^{2}}{W^{2}} \ |\vec{W}|^{2} \ \frac{\vec{W}}{|\vec{W}|}\cdot \left(\vec{Q} \cdot \vec{P} \right) \ b_{\vec{Q}} b^{*}_{\vec{P}}...\\&= \sum_{\vec{Q},\vec{P}} \frac{N^{2}}{W^{2}} \ |\vec{W}|^{2} \ \cos (\vec{\theta}_{1}) \ \cos (\vec{\theta}_{2}) \ b_{
kau
53
I am reading Frohlic's paper on electron-phonon interaction.
Frohlic.http://rspa.royalsocietypublishing.org/content/royprsa/215/1122/291.full.pdf
Here author has introduced the quantization for complex B field in this paper and claimed to have arrived at the diagonalized form of the hamiltonian. I didn't get the quantization part .I think there is some notational problem. He used w to denote wavevectors and at the sametime in the quantization W sits infront of it.. $$ \vec{B}=\frac{\vec{W}}{w}(2h/2\pi wnvs')^{1/2}\sum_{w} b_{w} e^{iw.r}$$ I think there also should be a creation operartor part as well and that's the reason we will get the kind of term author have claimed to get (only then we need to impose the commutation relation,if there is only this much in B then probably I don't need to impose that at all)..most likely I am missing something here..can anyone help me with it..
thanks.Edit: I have hamiltonian $$H= \int |{div\vec{B}}|^{2}nMs'.\, d^{3}r $$
Now We want to quantize it.
So Author have introduced following scheme $$ \vec{B}=\frac{\vec{W}}{w}(2h/2\pi wnvs')^{1/2}\sum_{w} b_{w} e^{iw.r}$$ Using this and writing the integration in the following form
$$ H=\int(div\vec{B}^{*}div\vec{B}+div\vec{B}div(\vec{B}^{*}) (nMs'/2).\, d^{3}r $$
and then substituting the B we get the following
$$ H=\sum \frac{hs'(\vec{W}.\vec{w})^{2}}{2w^{3}}[b_{w}^{\dagger}b_{w}+b_{w}b_{w}^{\dagger}]$$
Here w is the magnitude of $\vec{W}$... I need the following
$$ H=\sum_{w} \frac{hs'w}{2}[b_{w}^{\dagger}b_{w}+b_{w}b_{w}^{\dagger}]$$
First thing is how someone can decompose
$$ \vec{B}=\frac{\vec{W}}{w}(2h/2\pi wnvs')^{1/2}\sum_{w} b_{w} e^{iw.r}$$?? Why $$\vec{w}$$ should sit outside?
Is there anyone who can give some suggestion on this?
If w is the magnitude of ##\vec{W}##, then what is ##\vec{w}##. I don't have the article, so maybe you can explain the meaning of all the symbols.
As far as I can understand w is the magnitude of ##\vec{W}## ...and I think it should sit inside the sum...then it would look like usual plane wave decomposition ...but the way it's written here is not clear to me.. i have attached the file..thanks.
  • Frohlic hamiltonian.pdf
Yes, that's ok. As far as I can see, only ##\mathbf{w}## and w appear in the paper by Froehlich. This still leaves the question what you mean with ##\vec{W}##, ##\vec{w}## and w.
The expression I have written for the quantization of ##\vec{B}## is the same as written in the paper. I copied it from there... The capital ##\vec{W}## sitting in front of the sum over w s is not clear to me..$$ \vec{B}=\frac{\vec{W}}{w}(2h/2\pi wnvs')^{1/2}\sum_{w} b_{w} e^{iw.r}$$.I am trying to understand how someone can write something in that form.
I suppose you are right. The relations 2.3 and 2.4 should be formulated in Fourier space.
What is wrong in writing this?
[tex]
\vec{B} = \frac{\vec{k}}{|\vec{k}|} \ N \sum_{\vec{k}} b(\vec{k}) \ e^{i \vec{k} \cdot \vec{r} }
[/tex]
[tex]
[/tex]
The question is how the k vector outside the sum is related to the k vector inside the sum. Admittedly, the expression makes no sense as it stands. I suppose Froehlich had something like this in mind:
[tex]
\vec{B} = \ \ N \sum_{\vec{k}}\frac{\vec{k}}{\omega}b(\vec{k}) \ e^{i \vec{k} \cdot \vec{r} }
[/tex]
You also have to read carefully: the denominator is ##\omega##, which is constant, and not the absolute value of ##\vec{k}##.
Summation label is a dummy index.
[tex]
[/tex]
Since you seem to know what Froehlich had in mind, can you use this expression of yours to derive equation (2.5) of Froehlich?
I didn’t read it, let alone “read carefully”.
Can you tell me what is your dispersion relation here?
Finally, for your information, I do not post in this part of PF. I just responded to a PM from Kau.
1) [itex]\vec{W}= \pi \vec{n} / V^{1/3}[/itex], [itex]\vec{n}=(n_{1},n_{2},n_{3})[/itex], [itex]n_{i}= 0, \pm 1 , \pm 2, \cdots[/itex] is the wave vector.
2) [itex]W = |\vec{W}|[/itex] is the wave number. This is clear from (2.5) [tex]H = \sum_{\vec{W}} \hbar W s \ b^{*}_{\vec{W}} \ b_{\vec{W}} .[/tex] For this to have unit of energy, [itex]Ws[/itex] must be an angular frequency [itex]\omega[/itex]. Since [itex]s[/itex] is the speed of sound, [itex]W[/itex] has to be the wave number [itex]|\vec{W}|[/itex].
3) Since the field [itex]\vec{B}[/itex] point in the same direction of the wave vector [itex]\vec{W}[/itex], we can write [tex]\vec{B} = \frac{\vec{W}}{W} B(\vec{r}),[/tex] and hence [tex]\vec{\nabla} \cdot \vec{B} = \frac{1}{W} \vec{W} \cdot \vec{\nabla} B(\vec{r}) .[/tex]
4) The summation labels are dummy indices [tex]\sum_{\vec{P}} = \sum_{\vec{Q}} = \cdots .[/tex]
5) Write
[tex]B(\vec{r}) = \sum_{\vec{Q}} N \ b_{\vec{Q}} \ e^{ i \vec{Q}\cdot \vec{r}} .[/tex]
Then
[tex]\vec{\nabla}B = \sum_{\vec{Q}} N \ ( i \vec{Q}) \ b_{\vec{Q}} \ e^{ i \vec{Q}\cdot \vec{r}}.[/tex]
So,
[tex]\vec{\nabla} \cdot \vec{B} = \sum_{\vec{Q}} \frac{N}{W} \left(i \vec{W} \cdot \vec{Q} \right) \ b_{\vec{Q}} \ e^{ i \vec{Q}\cdot \vec{r}} ,[/tex] and
[tex](\vec{\nabla} \cdot \vec{B})^{*} = \sum_{\vec{P}} \frac{N}{W} \left(-i \vec{W} \cdot \vec{P} \right) \ b^{*}_{\vec{P}} \ e^{ -i \vec{P}\cdot \vec{r}} .[/tex]
6)
[tex]
\begin{align*}
\int dV |\vec{\nabla}\cdot \vec{B}|^{2} &= \sum_{\vec{Q},\vec{P}} \frac{N^{2}}{W^{2}} \ (\vec{W}\cdot \vec{Q}) \ (\vec{W}\cdot \vec{P}) \ b_{\vec{Q}} b^{*}_{\vec{P}} \int dV e^{i (\vec{Q} - \vec{P}) \cdot \vec{r}} \\
&= \sum_{\vec{Q},\vec{P}}\frac{N^{2}}{W^{2}} \ (\vec{W}\cdot \vec{Q}) \ (\vec{W}\cdot \vec{P}) \ b_{\vec{Q}}b^{*}_{\vec{P}} \ V \ \delta_{\vec{Q},\vec{P}} \\
&= \sum_{\vec{Q}} \frac{N^{2}V}{W^{2}} \ (\vec{W}\cdot \vec{Q})^{2} \ b^{*}_{\vec{Q}} \ b_{\vec{Q}}
\end{align*}
[/tex]
7) Contributions to energy come from oscillations in the [itex]\vec{Q} = \vec{W}[/itex] directions
[tex]
\begin{align*}
H &= \frac{1}{2} n M s^{2} \sum_{\vec{W}} N^{2}VW^{2} \ b^{*}_{\vec{W}} \ b_{\vec{W}} \\
&= \frac{1}{2} n M s^{2} \sum_{\vec{W}} (\frac{2\hbar}{nMVWs}) \ V \ W^{2} \ b^{*}_{\vec{W}} \ b_{\vec{W}} \\
&= \frac{1}{2} \sum_{\vec{W}} \hbar \ W \ s \left( b^{\dagger}_{\vec{W}} b_{\vec{W}} + b_{\vec{W}} \ b^{\dagger}_{\vec{W}} \right) .
\end{align*}
[/tex]
8) Why are you reading this old paper?
samalkhaiat said:
1)
There is a problem, here: ##|\vec{W}|## is a function of r, while ##\omega## in (2.5) can't be a function of r.
Let's try this:[tex]H_f=\frac{1}{2} \int (M \dot{\mathbf{P}}^2+Ms'^2(\nabla \cdot \mathbf{P})^2)n d\mathbf{r}[/tex]
[tex]=\frac{1}{2}nM \sum_\mathbf{W} ( \mathbf{\dot{P}}_{-\mathbf{W}}(t) \mathbf{\dot{P}}_{\mathbf{W}}(t)+s'^2_\mathbf{W}(-i\mathbf{W}\cdot \mathbf{P}_{-\mathbf{W}})(i\mathbf{W}\cdot \mathbf{P}_\mathbf{W}))[/tex]
[tex]=\frac{1}{2}nM \sum_\mathbf{W}s'^2_\mathbf{W} |(i\mathbf{W}\cdot (\frac{1}{i s'_\mathbf{W}\omega}\mathbf{\dot{P}}_\mathbf{W}+ \mathbf{P}_\mathbf{W}))|^2[/tex], as ##\mathbf{\dot{P}}_\mathbf{W} || \mathbf{W}## as it is a longitudinal vector field. We set ##\omega = |\mathbf{W}|##.
So we find that ##B_\mathbf{W}(t)= \frac{1}{i \omega s'_\mathbf{W}}\mathbf{P}_\mathbf{W}+\mathbf{P}_\mathbf{W}##
Related to Electron-Phonon interaction
What is electron-phonon interaction?
Electron-phonon interaction refers to the interaction between electrons and phonons, which are quantized vibrations or waves in a crystal lattice. This interaction plays a significant role in various physical phenomena, such as electrical conductivity and thermal conductivity.
How does electron-phonon interaction affect electrical conductivity?
Electron-phonon interaction can lead to scattering of electrons, which in turn affects the electrical conductivity of a material. In some cases, it can enhance the conductivity, while in others it can decrease it. This depends on the strength and type of interaction and the properties of the material.
What is the role of electron-phonon interaction in superconductivity?
Electron-phonon interaction plays a crucial role in the phenomenon of superconductivity. It is responsible for the formation of Cooper pairs, which are two electrons bound together by phonon exchange. These Cooper pairs are what allows superconductors to conduct electricity with zero resistance at low temperatures.
How do phonons affect the thermal conductivity of a material?
Phonons play a significant role in thermal conductivity by carrying heat energy through a material. The interaction between phonons and electrons can also affect thermal conductivity, as it can lead to scattering of phonons. This is why materials with strong electron-phonon interaction tend to have lower thermal conductivity.
What experimental techniques are used to study electron-phonon interaction?
Various experimental techniques are used to study electron-phonon interaction, including angle-resolved photoemission spectroscopy, inelastic neutron scattering, and Raman spectroscopy. These techniques allow researchers to probe the electronic and vibrational properties of a material and understand the strength and type of electron-phonon interaction present.
  • Atomic and Condensed Matter
  • Quantum Physics
  • Quantum Physics
