- #36
TrickyDicky
- 3,507
- 27
Not entering into the photon position issue, your two examples are a hand-wavey form of saying the position delta function formalism is only possible in a time-independent setting like the tunneling zero size pinhole first example or the TISE ##H\Psi=E\Psi## second example. But again, the double slit experiment cannot be simplified in that form even in hand-waving: the wave function is perturbed in a time-dependent way in its time evolution by the slits. This makes it collapse to the measured dot at the screen. Ignoring this is keeping with the misleading picture of the experiment that so many sources perpetuate.Nugatory said:I'm going to try a non-QFT response, but please don't forget that there is some serious hand-waving in this answer - I'm just trying to convince you that cannot always trust first-quantization stuff when applied to photons.
Localizing something is not the same thing as saying that it is in an eigenstate of a position operator. When a particle passes through a pinhole, that narrows down the region of space in which it may be found, but the position is still uncertain because of the non-zero size of the pinhole itself. The only way to really nail the position down to that delta function that you're thinking of is if the pinhole is of size zero (that is, model the transmissability through the screen with a delta function). You can make this work with a point particle such as an electron - but you will get zero electromagnetic field passing through a size-zero hole, so no photon at all instead of a photon of precisely known position.
Another problem you'll find is that the entire formalism of position delta functions found by superimposing all possible momentum states and vice versa that you're suggesting we use comes from solving Schrodinger's ##H\Psi=E\Psi##. However, that's not a relativistic equation, so there's no particular reason to expect it to work for photons - and if you do try, you'll find yourself looking at a ##p^2/2m## term, a fairly strong hint that you shouldn't be applying this when ##m## is equal to zero.
