Elephant toothpaste per cubic meter
In summary, the best formula for elephants toothpaste without using yeast involves using potassium iodine and hydrogen peroxide (30%) with soap. To fill 100m cubed, you would need to calculate the number of moles of hydrogen peroxide needed using the decomposition reaction. The reaction time, safety limits and precautions, heat produced, and legality in the UK can all be researched online. This is a simple decomposition reaction and does not require extensive chemistry knowledge, making it accessible for non-chemists.
alewisGB
what is the best formula for elephants toothpaste not using yeast using potassium iodine and hydrogen-peroxide(30%) and of course soap.
how much reactants would i need to fill let's say... 100m cubed (im not going to do that much but its easier to work with)
* how long would the reaction take?
* what would be the safety limits of reactants and precautions?
* how much heat will it produce?
* is it illegal in the UK?
Chemistry news on Phys.org
Start with the reaction equation.
im not a chemist I am more of a physician?
This is not difficult. Reaction that is responsible for the observed effect is hydrogen peroxide decomposition. You know volume of oxygen, calculate how many moles it is, use decomposition reaction to calculate how many moles of hydrogen peroxide you need.
You should be able to google details.
I am happy to provide a response to your inquiry about the formula and safety considerations for creating elephant toothpaste using potassium iodine and hydrogen peroxide.
The best formula for elephant toothpaste without using yeast would be to mix 100mL of 30% hydrogen peroxide with 50mL of 10% potassium iodine solution. This should be mixed in a large container to allow for expansion of the foam. The addition of a small amount of dish soap will also help to stabilize and create a larger foam.
To fill 100m³, you would need to multiply the volume of the reaction by the density of the foam. The density of foam can vary, but on average it is around 0.02 g/cm³. This means you would need approximately 2000 kg of foam to fill 100m³.
The reaction between hydrogen peroxide and potassium iodine is very fast and typically takes less than a minute to produce a large amount of foam. However, the reaction may continue for several minutes as the foam expands and stabilizes.
When working with chemicals, safety is always a top priority. Both hydrogen peroxide and potassium iodine can be hazardous if handled improperly. It is important to wear protective gear such as gloves, goggles, and a lab coat when handling these chemicals. It is also important to work in a well-ventilated area and to avoid inhaling any fumes. In addition, it is important to follow proper disposal procedures for any leftover chemicals and to thoroughly clean any equipment used in the experiment.
The reaction between hydrogen peroxide and potassium iodine is exothermic, meaning it produces heat. The amount of heat produced will depend on the amount of reactants used, but it is important to be cautious and avoid touching the foam until it has cooled down.
As for the legality of creating elephant toothpaste in the UK, it is not illegal as long as proper safety precautions are taken and the experiment is conducted in a safe and responsible manner. However, it is always important to check with local laws and regulations before conducting any chemical experiments.
Related to Elephant toothpaste per cubic meter
1. What is "Elephant toothpaste per cubic meter"?
"Elephant toothpaste per cubic meter" is a scientific measurement used to describe the volume of foam produced from the reaction between hydrogen peroxide, dish soap, and potassium iodide.
2. How is "Elephant toothpaste per cubic meter" measured?
"Elephant toothpaste per cubic meter" is measured by collecting the foam produced from the reaction and measuring its volume in cubic meters using a graduated cylinder or other volumetric measuring device.
3. What factors affect the amount of "Elephant toothpaste per cubic meter" produced?
The amount of "Elephant toothpaste per cubic meter" produced can be affected by the concentration of hydrogen peroxide used, the amount of dish soap added, and the presence of a catalyst such as potassium iodide.
4. What is the purpose of using "Elephant toothpaste per cubic meter" in scientific experiments?
"Elephant toothpaste per cubic meter" is often used in science experiments as a visual demonstration of a chemical reaction and to teach concepts such as catalysis and rates of reaction.
5. Is "Elephant toothpaste per cubic meter" safe to handle?
The chemicals used to create "Elephant toothpaste per cubic meter" can be hazardous, so caution should be taken when handling them. It is important to wear protective gear such as gloves and goggles and to properly dispose of any leftover materials.
  • Chemistry
  • Other Physics Topics
22K
  • General Math
9K
  • Aerospace Engineering
9K
