Enthalpy of Formation of ZnO lab
cutielollipop
I'm having trouble understanding whether q stays constant? If it does, then for part b) does q stay the same?
q = mcdeltaT
Experiment equation: Zn(s) + 2HCL(aq) -> 2ZnCl(aq) + H2(g)
a) If the the mass of zinc solid used was doubled, what effect would this have on temperature change?
Answer: if mass of zinc increases, there will be an increase in zinc particles which increases the collisions between particles and increases the average kinetic energy therefore giving higher temperature change
b) What would have been the number of joules evolved (q)?
c)What effect would this have on delta H?
delta H would increase by a factor of 2 since the mass is doubled, so the number of mols has also doubled.
Question is a bit poorly worded or you posted it incomplete, as the answer depends on several other factors - mainly on what is the limiting reagent in the setup.
Amount of heat produced is directly proportional to the amount of zinc that reacted.
Q is not much different from ΔH in that regard (see your answer to c.) - assuming there was a sufficient excess of acid.
Likes DeBangis21
Thx for your reply. I have figured out the answer as I realized that zinc was the limiting reagant.
Yes, q is an extensive property.
Related to Enthalpy of Formation of ZnO lab
1. What is the purpose of the Enthalpy of Formation of ZnO lab?
The purpose of this lab is to determine the enthalpy of formation of zinc oxide (ZnO) by measuring the heat released during the reaction between zinc metal and hydrochloric acid.
2. What is enthalpy of formation?
Enthalpy of formation is the amount of heat released or absorbed when one mole of a compound is formed from its constituent elements in their standard states at a given temperature and pressure.
3. Why is it important to know the enthalpy of formation of a compound?
The enthalpy of formation is an important thermodynamic property that can provide information about the stability and energy content of a compound. It is also used in various calculations, such as determining the heat of reaction for a chemical reaction.
4. How is the enthalpy of formation of ZnO calculated in this lab?
The enthalpy of formation of ZnO is calculated by measuring the heat released during the reaction between zinc metal and hydrochloric acid, and using the heat capacity and mass of the reactants to determine the change in enthalpy for the reaction. This value is then divided by the moles of ZnO produced to obtain the enthalpy of formation per mole.
5. What are some potential sources of error in this lab?
Some potential sources of error in this lab include incomplete reaction between zinc and hydrochloric acid, heat loss to the surroundings, and measurement errors. It is important to carefully control and measure all variables in order to minimize these sources of error and obtain accurate results.
18K
  • Biology and Medical
11K
