Equillibrium of electrostatic forces of 2 charges on a 3rd
In summary, the third particle must be located to the left of the origin with a negative charge, and the coordinates of the third particle are approximately -4 cm and 26 cm. The distance between the third particle and the first particle must be 1.4 times greater than the distance between the third particle and the second particle in order for the net electrostatic force to be zero.
afulldevnull
Two particles lie on the x axis. The first particle is at the origin with a charge of +1.6uC and the other has a charge of -3.1uC and is +10.5cm away. If particle 3 of unknown charge q3 is to be located such that the net electrostatic force on it from particles 1 and 2 is zero. what is the coordinates of the third particle?
Coloumbs Law: F = k (q1 q2) \ r^2
Since the charges of the particles are opposite, and because particle 1 has a smaller magnitude, then the third particle must go to the left of particle 1 and must have a negative charge. This is because for the net to be 0, then the strong force at a distance must repel as strongly as the small force nearby attracts. If the net force is to be 0, then the forces must have the same magnitude. So: k(1.6q)/d^2 = k(3.1q) / (10.5+d)^2.
I get the 26 cm, but that can't be right. Any thoughts?
You said that d was on the left of the origin - so is negative.
The solution of the quadratic equation yields approx 26 and also around -4.
Perhaps it is the "-4" you are after.
Also, the charge of q3 can be either positive or negative.
d is a distance, so it cannot be negative, and because we are solving for d then -4 cannot be an answer either
edit: 26 is the right answer
Points taken.
Your answer of 26 actually sounds pretty good - if unexpected.
had the two given charges been 1.6 and 3.2, then the "charge contribution" to the attractive/repulsive forces would be "doubled"
That means the "distance contribution" has to be 1/2
The distance is squared in the formula, so the distance to the larger charge is approx 1.4 times the distance to the smaller charge. we don't really need sqrt(2) = 1.414213... since this is an approximation anyway.
so d + 10.5 is about 1.4 * d
When the extra 10.5 cm represents 0.4 of d, which gives a d value around 26?
Your approach to the problem is correct. The third particle must have a negative charge and be located to the left of particle 1 in order for the net electrostatic force to be zero. However, the distance d in your equation should be the distance between particle 1 and particle 3, not between particle 2 and particle 3. This distance can be represented as (x-d), where x is the distance from particle 1 to particle 2.
Using Coulomb's Law, we can set up the equation:
k(1.6uC)(-q3) / d^2 = k(3.1uC)(q3) / (x-d)^2
Solving for d, we get:
d = x(0.8q3) / (1.5q3 + 1.6q3)
Simplifying, we get:
d = x / 2.3
Therefore, the coordinates of the third particle would be located at (-x/2.3, 0).
Related to Equillibrium of electrostatic forces of 2 charges on a 3rd
1. How do you calculate the equilibrium of electrostatic forces between two charges on a third?
In order to calculate the equilibrium of electrostatic forces between two charges on a third, you must first calculate the Coulomb force between each pair of charges. Then, you can use vector addition to determine the net force on the third charge. If the net force is zero, then the system is in equilibrium.
2. What is the significance of the equilibrium of electrostatic forces between two charges on a third?
The equilibrium of electrostatic forces between two charges on a third is significant because it represents a stable state where the forces acting on the third charge are balanced. This can be useful in predicting the behavior of electrically charged systems and in designing devices that utilize electrostatic forces.
3. How does the distance between the two charges affect the equilibrium of electrostatic forces on a third charge?
The distance between the two charges has a direct impact on the equilibrium of electrostatic forces on a third charge. As the distance between the two charges increases, the Coulomb force between them decreases, resulting in a weaker net force on the third charge and potentially disrupting the equilibrium.
4. Can the equilibrium of electrostatic forces between two charges on a third ever be unstable?
Yes, the equilibrium of electrostatic forces between two charges on a third can be unstable. This can occur when the two charges have the same sign, resulting in a repulsive force that can lead to the third charge being pushed away from the equilibrium position.
5. How does the charge of the third particle affect the equilibrium of electrostatic forces between two charges?
The charge of the third particle can greatly affect the equilibrium of electrostatic forces between two charges. If the third charge has the same sign as one of the other charges, the net force on the third charge will be greater, potentially causing the system to become unbalanced. However, if the third charge has the opposite sign, it can help to stabilize the equilibrium by counteracting the force from the other two charges.
