Estimating the lorentz factor of a spaceship
In summary: Note (3):...ship time T' and the ship-frame distance d'.You have three equations and three unknowns. Try solving them simultaneously to get a value for gamma.
EmmaLemming1
ESTIMATE the Lorentz factor of a spaceship which travels to a nearby star 10pc from the solar system in 50 years spaceship time.
Lorentz factor: γ = 1/√(1 - v^2/c^2 )
Time dilation: Δt' = γΔt
Using the distance and time given, from the spaceship's point of view, it is traveling at a velocity of 0.65c.
I think I need to figure out the velocity from the point of view of Earth and then put that into the lorentz factor, however I don't know how to do that and that doesn't seem like an estimate to me.
I also thought that perhaps if I could work out the time it took to get there from the point of view of Earth I could rearrange the time dilation equation and get gamma from that.
I think my problem is I don't know what I can reasonably assume/estimate without getting this completely wrong.
Help :(
It takes 50years spaceship time to go 10pc in the Earth frame.
10pc is about 350ly so that is definitely relativistic.
estimate the relative speed by v=d/T=d'/T' (that's average speed right?)
observers on the spaceship and Earth agree about v and disagree about who is moving.
how is d related to d'?
how is v related to gamma?
d = γ(d' +Vt')
and v is related to gamma through the lorentz factor isn't it?
Where did that V come from? Electric potential?
I think you need to revise length contraction - make sure you know what the equations mean... but yep ... ##(v/c)=\sqrt{1-1/\gamma^2}##
Careful about which is the primed and unprimed coordinates ... if d is the proper length, what is d'?
The time in the ship is T', the ship sees objects in the Earth frame passing at speed v=d'/T'... if the ship speed is constant.
"From the spaceship's point of view", it isn't moving at all! The star is moving toward it at 0.65c.
Help :(
V is velocity of some sort, I think, not electrical potential.
I've just read up on length contraction. Proper length is the ship's length when it's at rest and in the reference frame where the spaceship is moving it will experience length contraction - Does this mean from the spaceship's point of view it travels less than 10pc?
d' = (1/γ)d - Where d is the proper length and d' is the length seen by the ship.
So d is 10pc because that is it's length at rest from the Earth's point of view.
What I still don't understand is how I can work out gamma only knowing the proper length and T'.
That is correct! Well done.
That's how the spaceship crew explain the fact that they got to the star in such a short time without the star having to go faster than light.
But you have three equations and three unknowns. Hint: simultanious equations.
This way - the only assumption is that the ship/earth relative speed is constant over the journey.
Note: if the speed v is verry close to c, then d' is very close to how many light-years?
Then you can use the length-contraction formula to estimate gamma.
Okay I've tried playing around with the equations;
1) (v/c)=1−(1/γ2)
2) d=d'γ
3) t' = γt
The question wants we to estimate the lorentz factor so I need to use these equations to calculate velocity, correct?
I tried dividing 2) by 3) to get (d/t') = 10/50 = 0.2 parsecs per year but that is just using the Earth's distance and the spaceship time so it seems I've gone through all this stuff only to go back to the beginning :(
What am I doing wrong?
You need to calculate gamma.
Spelling it out (and using a 0 subscript to indicate the frame in which the star is at rest.)
(1) ##(v/c)^2=1-1/\gamma^2##
(2) ##d_0=\gamma d##
(3) ##v=d/T=d_0/T_0## <---<<< you forgot...
>>>---> these simple relations still apply inside each reference frame; SR just relates frames to each other.
Note (1):
you can use the time dilation formula for #2 instead if you prefer.
Note (2):
vT is the distance to the star (in the ship-frame), cT is the distance light travels in the same time (same frame). If the relative speed v is very close to the speed of light, then these distances will be approximately the same. You could use this observation to get a back-of-envelope estimate for gamma using the length contraction formula (or the time-dilation formula) by itself.
Related to Estimating the lorentz factor of a spaceship
1. How is the Lorentz factor of a spaceship calculated?
The Lorentz factor of a spaceship can be calculated using the equation γ = 1/√(1 - v²/c²), where v is the velocity of the spaceship and c is the speed of light. This equation takes into account the effects of special relativity on the perceived time and length of the spaceship's journey.
2. What is the significance of the Lorentz factor in space travel?
The Lorentz factor is significant in space travel because it helps us understand the effects of high speeds on the passage of time and the size of objects. It also allows us to accurately calculate the energy requirements for space travel, as well as potential time dilation and length contraction.
3. Can the Lorentz factor of a spaceship exceed 1?
Yes, the Lorentz factor of a spaceship can exceed 1. In fact, the closer the spaceship's velocity gets to the speed of light, the higher the Lorentz factor will be. A Lorentz factor of 1 represents a stationary object, while a factor of 2 would mean the spaceship is traveling at half the speed of light.
4. How does the Lorentz factor affect the aging of astronauts on a spaceship?
The Lorentz factor can affect the aging of astronauts on a spaceship. As the spaceship travels at high speeds, time dilation occurs, meaning that time passes slower for the astronauts on board compared to those on Earth. This results in the astronauts aging slower than their counterparts on Earth.
5. Is the Lorentz factor the same for all spaceships?
No, the Lorentz factor can vary for different spaceships depending on their velocity. A spaceship traveling at a higher speed will have a higher Lorentz factor compared to a spaceship traveling at a lower speed. The Lorentz factor also depends on the reference frame of the observer, so it may be different for different observers.
