Existence of orthonormal frame
In summary, an orthonormal framing of a surface with Riemannian metric exists if and only if the surface is orientable and admits a nowhere vanishing vector field. This can be justified by considering the definition of orientability and constructing an orthonormal frame using a nowhere vanishing vector field. On the other hand, given a global orthonormal frame, a canonical choice of orientation can be determined at each tangent space. It can be argued that if the surface is parametrized in $$\mathbb{R}^3$$ and orientable, then it is either an embedded surface or a submanifold of $$\mathbb{R}^3$$, which implies the existence of an orthonormal framing
semigroups
Let $$M$$ be a surface with Riemannian metric $$g$$. Recall that an orthonormal framing of $$M$$ is an ordered pair of vector fields $$(E_1,E_2)$$ such that $$g(E_i,E_j)=\delta_{ij}$$. Prove that an orthonormal framing exists iff $$M$$ is orientable and $$M$$ admits a nowhere vanishing vector field $$X$$.
Remark: It's obvious in $$\mathbb{R}^3$$, but how to formally justify it?
The definition for orientabily: $$M$$ is orientable if there exists an atlas $$(u_{\alpha},M_{\alpha})_{\alpha}$$ such that $$\mathrm{det}(\mathrm{d}(u_{\beta}\circ u_{\alpha}^{-1}))>0$$, for each $$(\alpha,\beta)$$ such that $$M_{\alpha} \cap M_{\beta} \neq \Phi$$
The idea here is that by definition, an orientation on M splits the basis at each tg space into 2 sets: the ones that are positively oriented and the ones that are not.
So start with a nowhere vanishing vector field X. You want to construct another one Y that is g-orthogonal to it. At each point, you have only two choices for Y, but one of those choices is canonical as only one of them makes (X,Y) a positively oriented basis.
Conversely, given a global orthonormal frame (X,Y), you get a canonical choice of orientation at each tg space: declare positively oriented those basis that share the same orientation as (X,Y).
I let you fill in the details.
Still, if the surface S is parametrized in R^3 (which I assume is the case) and
orientable, doesn't if follow that S is either an embedded surface or a submanifold of
R^3. Then the tangent space T_pS to S at p is a subspace of the tangent space
T_pR^3 , so the result would follow. Right?
Related to Existence of orthonormal frame
1. What is an orthonormal frame?
An orthonormal frame is a set of vectors that are mutually perpendicular and each have a magnitude of 1. In other words, the vectors in an orthonormal frame are both orthogonal (perpendicular) and normalized (unit length).
2. Why is an orthonormal frame important in mathematics and science?
An orthonormal frame is important because it provides a basis for vector spaces, making it easier to analyze and work with vectors. It also simplifies calculations involving dot products and projections.
3. How is an orthonormal frame different from an orthogonal frame?
An orthonormal frame is a special case of an orthogonal frame, where the vectors are also normalized. This means that while all vectors in an orthonormal frame are perpendicular to each other, they also have a magnitude of 1.
4. Can an orthonormal frame exist in any dimension?
Yes, an orthonormal frame can exist in any dimension. It is not limited to only two or three dimensions, but can be extended to higher dimensions as well.
5. What are some applications of orthonormal frames?
Orthonormal frames have various applications in mathematics and science, including linear algebra, quantum mechanics, and computer graphics. They are also used in fields such as signal processing, image reconstruction, and pattern recognition.
  • Differential Geometry
  • Linear and Abstract Algebra
  • Math Proof Training and Practice
