- #36
Ibix
- 13,695
As noted by others, it depends. An easy thing to do is switch to a frame in which the A and B observers have equal and opposite velocities. If the grid pitches are equal in that frame then the observers age equally, obvious from symmetry. If the pitches are not equal then the observers in the finer pitched grid will age more than those in the coarser pitched grid. This is easy to see by imagining an extreme case of fine spacing where the coarsely spaced observers meet finely spaced ones almost continuously, but the finely spaced ones only meet coarsely spaced ones occasionally.Killtech said:Fine, basic question then: in the following setup in a flat open world
which grid-vertex ages more between two meetings with the others grid vertices? those in A or in B?Code:... ------ A1 ------ A2 ------ A3 ------ ... ... -----> B1 -----> B2 -----> B3 -----> ...
Note that the ratio of grid pitches is not frame invariant but the proper times between meetings is, so this analysis only works in this velocity-symmetric frame. In the particular case of symmetric aging, in the rest frame of either grid the other (moving) grid will be length contracted and hence more finely spaced than the rest grid.
