False vacuum and matter density
In summary, the false vacuum of the inflationary universe is a peculiar state of matter that is described as being like dark energy. It does not dilute with the scale factor, and its energy density decreases slowly due to the rapid expansion of the universe during inflation. Unlike the inflaton field, which decreases in energy due to moving towards a lower energy state, the false vacuum has a constant energy density until it decays. Currently, there is no way to determine if our vacuum is a false vacuum, but the fact that it has not decayed in 13 billion years suggests that it is not likely to happen anytime soon.
Ranku
420
The false vacuum of the inflationary universe is described as a 'peculiar state of matter'. We know that matter density in the big bang universe dilutes as ρMa-3. Is it possible to assign a dilution rate to the 'peculiar state of matter' of the false vacuum as well?
Space news on Phys.org
Who describes it that way where?
Without context it is hard to understand what is meant.
It is a state, not matter. Asking about its dilution will probably not make sense.
It's in the book The Inflationary Universe by Alan Guth (It's in the glossary as well).
The false vacuum is like dark energy - it does not dilute with the scale factor. That's what makes the expansion driven (solely) by either one of those - exponential.
One problem here is that there are two completely different definitions of "matter" at work.
One is the classical definition extended to cosmology: matter is stuff with mass. In this cosmology case, this is extended a bit to mean "stuff with mass that has low temperature" (low temperature in this case means most of its energy is mass energy: at high temperature, most of the energy is kinetic energy, such that high-temperature matter behaves like radiation).
Another definition of matter that can be used stems from quantum field theory: it is possible to consider matter to be any quantum field. With that definition of matter, electrons are matter, but so are photons and gluons. It makes a degree of sense there because all quantum fields behave in similar ways. There are differences, but it's not unreasonable to think of them all as belonging to one category of thing with lots of sub-categories. In this case, the inflaton, the quantum field that drives inflation, is considered matter just because it's a quantum field. But it's properties are quite alien to anything we experience as matter.
For driving the expansion, the quantum field that drives inflation does decrease in energy density over time. But it only does so slowly. They way it does this is that the inflaton field is stuck, early-on, in a high-energy state. It tends to move to a lower energy state over time, but the rapid expansion of the universe during inflation actually puts the brakes on that process, so that even though its energy density falls, the rapid expansion keeps it from falling too quickly. In fact, its energy density decreases slowly, it decreases slowly enough that the expansion of the universe is approximately exponential.
Side note: there's also a third definition of matter that is sometimes used: fermions and things made of fermions are matter, while fundamental bosons aren't, but I won't go into that here, as it's a bit off-topic.
Finally, on the point about a false vacuum, that's actually a different situation. The energy density of a false vacuum is actually constant, until it decays. The inflaton field drops in energy because it's moving towards a local energy minimum. The false vacuum is at a local energy minimum, so it just sits there. But it's a "false" vacuum because there are other ways to configure the vacuum that are lower in energy: it's just that there's no smooth way to get from here to there. So the false vacuum sits where it is with a constant energy density right up until there's a quantum tunneling event which causes it to decay. Then the universe is destroyed.
Likes eloheim and Ibix
Do we know, or expect to be able to figure out, if the current vacuum is false? Or do we just have to rely on checking every morning that everything still exists and hasn't been replaced with exciting new physical laws?
There's no good way to know right now. To understand whether or not our vacuum is a false vacuum, you'd first have to know the theory which determines the different vacuum states. We don't know what that theory is. And without that more fundamental theory, the possibilities for determining our vacuum state are limited.
As for checking that the vacuum hasn't decayed, well, if it happened we'd all wink out of existence with perhaps less than one second of warning that something was going on. Fortunately, the fact that it hasn't happened in some 13 billion years or so is a pretty good indication that it's not very likely to happen any time soon.
Thanks - so we may be able to know one day but we don't have a physical model today that will tell us.
That question was a bit tongue in cheek - as you say, billions of years of updating your Bayesian priors gives a fair degree of confidence even in the absence of a formal model. But, I understood that the change in "vacuum" state is expected to propagate at light speed, so no warning, a significant energy release associated with everything dropping into its new ground state, and quite likely new physics not necessarily supportive of carbon-based life. Or, indeed, carbon. But you seem to be offering a small warning - does the change propagate slower than light? Or is it expected to take a measurable time to take effect?
Related to False vacuum and matter density
1. What is a false vacuum?
A false vacuum is a theoretical concept in quantum field theory, where the vacuum state of a field is not the true lowest energy state. This can happen if the field is stuck in a local minimum of its potential energy, rather than the global minimum.
2. How does a false vacuum affect matter density?
A false vacuum can cause fluctuations in the energy density of the universe, which can affect the behavior of matter and energy. In some theories, a false vacuum can also lead to rapid expansion of the universe, known as inflation.
3. Can a false vacuum be observed or measured?
No, a false vacuum is a theoretical concept and cannot be directly observed or measured. However, its effects may be seen in the behavior of matter and energy in the universe.
4. What is the relationship between false vacuum and the Higgs field?
The Higgs field is a type of quantum field that gives particles their mass. In some theories, the Higgs field is responsible for creating a false vacuum state, which then affects the behavior of matter and energy in the universe.
5. Are there any potential consequences of a false vacuum for our universe?
Some theories suggest that a false vacuum could lead to the destruction of our universe, as the false vacuum state may not be stable and could collapse into the true lowest energy state. However, this is still a subject of ongoing research and debate among scientists.
  • Cosmology
  • Cosmology
