Figuring out the sign of sinx given cosx
  • B
  • Thread starter Mr Davis 97
  • Tags
    Sign
In summary, you would need to know the quadrant that x is in to determine the sign of sine, as it will depend on the quadrant of the angle in relation to the unit circle.
Mr Davis 97
1,462
44
Given that ##\cos x = -0.4927##, ##\sin x = \pm \sqrt{1 - (\cos x)^2} = \pm \sqrt{1 - (-0.4927)^2} = \pm 0.8704##. How do I know which sign to choose for the correct sign?
Mathematics news on Phys.org
You don't. You will need some other fact to make that choice.
Likes symbolipoint
Oh. Like what extra information would I need?
That's too open-ended. What other informmation do you have? Or is this a generic question?
Likes symbolipoint
Just a generic question. Would I need to know what quadrant cosx is in? Since it could be in either II or III.
You need some way to determine whether x is in 2nd or 3rd quadrant, yes.
That gives two possible answers. Refer to the Unit Circle.
They BOTH are correct. You make a selection according to the situation you are solving.
You would need to know what quadrant x is in, not what quadrant cos(x) is in.
Both are correct because here sign of cosine is negative and cosine has negative values in 2nd and 3rd quadrant and sine has positive values in 2nd quadrant and negative values in 3rd quadrant. So here sign of sine depends on quadrant.
Related to Figuring out the sign of sinx given cosx
What is the relationship between sinx and cosx?
The sine and cosine functions are two of the most important trigonometric functions. They are related to each other through the Pythagorean identity: sin2(x) + cos2(x) = 1. This means that for any angle x, the square of the sine of x plus the square of the cosine of x will always equal 1.
How do you determine the sign of sinx given cosx?
To determine the sign of sinx given cosx, you need to know the quadrant in which the angle x lies. In quadrant I, both sinx and cosx are positive. In quadrant II, sinx is positive and cosx is negative. In quadrant III, both sinx and cosx are negative. And in quadrant IV, sinx is negative and cosx is positive.
What is the unit circle and how is it related to figuring out the sign of sinx given cosx?
The unit circle is a circle with a radius of 1 centered at the origin (0,0) on the coordinate plane. It is used to visualize the values of the sine and cosine functions for any given angle. By looking at the coordinates of a point on the unit circle, you can determine the sign of sinx and cosx for that angle.
Can the sign of sinx and cosx be the same?
No, the sign of sinx and cosx cannot be the same. This is because of the relationship between the two functions and the fact that their values are always between -1 and 1. So if one is positive, the other must be negative and vice versa.
How does the sign of sinx and cosx change as the angle x increases?
The sign of sinx and cosx will change as the angle x increases because the values of these functions oscillate between positive and negative as the angle increases. In general, as the angle increases from 0 to 90 degrees, the sign of sinx and cosx will change from positive to negative. As the angle continues to increase, the signs will continue to alternate between positive and negative.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
