Find the period of the following function
In summary, the period of the function f(x)= mod(sinx)/cosx + mod(cosx)/sinx is undefined because the modulus of tangent and cotangent cannot be taken if the values of cosine and sine are negative. Additionally, the formula for cos(x) is sign(cos(x))*|cos(x)| and sec(x)*sec(x)-1 equals tan(x) squared.
chaoseverlasting
1,050
I was asked to find the period of the following function:
Since modulus is defined as sqrt(x*x),
mod(sinx)/cosx= (sqrt(1-cosx*cosx))/ cosx
= sqrt(1/cosx*cosx -1) //Taking cosx into the square root
= sqrt(secx*secx-1)
= sqrt(tanx)
= mod(tanx)
and similarly, mod(cosx)/sinx = mod(cotx)
which is not possible because if either cosx or sinx are negative, then mod(cotx) or mod(tanx) will be negative.
Could someone point our where I am went wrong?
1. cos(x)=sign(cos(x))*|cos(x)|
2. sec(x)*sec(x)-1 equals tan(x) SQUARED.
Related to Find the period of the following function
1. What is the period of a function?
The period of a function is the length of one complete cycle of the function. It is the distance, measured along the x-axis, between two consecutive points on the graph where the function has the same value and the same direction of change.
2. How do you find the period of a function?
To find the period of a function, you can use the formula:
Period = 2π / b
where b is the coefficient of x in the function's equation.
3. Is the period of a function always the same?
No, the period of a function can vary depending on the equation and the type of function. Some functions, like trigonometric functions, have a constant period, while others may have a variable period.
4. Can you determine the period of a function by looking at its graph?
Yes, you can determine the period of a function by examining its graph. The period is equal to the distance between two consecutive peaks or valleys of the function's graph.
5. What is the difference between period and frequency?
The period is the length of one complete cycle of a function, while the frequency is the number of cycles per unit time. They are inversely related, meaning that a larger period corresponds to a smaller frequency and vice versa.
