Find the photon energy in the center of mass frame and vice versa
In summary, the given equations represent the general transformations for energy and momentum of particles between the laboratory frame and the center of mass frame, taking into account the sign of beta. These equations are useful for solving problems involving collisions in particle physics, regardless of the specific configuration (fixed target or not). They are a specific form of the Lorentz Transformation, which is a useful tool for understanding the behavior of energy and momentum in different reference frames. The invariant quantity ##E_T^2 - c^2P_T^2## is also important in these transformations.
lLehner95
In the process ##\gamma +p\rightarrow \pi _{0}+p##, in the lab frame the proton is the fixed target, and the photon has energy E_{\gamma }=144,7 MeV. Find the photon energy ##E_{\gamma }^{*}## in the center of mass frame.
##E^{*}_{\gamma }=\gamma _{cm}E_{\gamma }-\beta _{cm}\gamma _{cm}p_{\gamma }##
##p_{\gamma }=\frac{E_{\gamma }}{c}##
I tried to use the Lorentz transformation:
We have a photon, so it becomes:
##E^{*}_{\gamma }=\gamma _{cm}E_{\gamma }(\beta _{cm}-1)##
Unfortunately, the solutions say that the correct way is to use the inverse transormation:
##E_{\gamma }=\gamma _{cm}E^{*}_{\gamma }(\beta _{cm}+1)##
And the answer becomes:
##E^{*}_{\gamma }=\frac{E_{\gamma}}{\gamma_{cm}(1+\beta_{cm})}##
I already used the procedure to transform quantities (particles energy and momentum) from a reference to another, for example with the process ##p+\bar{p}\rightarrow \Lambda +\bar{\Lambda }##. Why it is not possible in this case?
I think the issue is the sign of the momentum. In your solution you have a negative energy. You have assumed that ##|p| = p##; whereas in this case ##E = |p|c = -pc##.
Alternatively, of course, you could have a negative value for ##v##, hence ##\beta##. In which case, if you take the modulus in your solution, you get the same as the book answer.
It looks like you have a sign error here. It should be ##E^{*}_{\gamma }=\gamma _{cm}E_{\gamma }(1-\beta _{cm})##.
You can get this to match the expression from the solutions:
\begin{align*}
E^{*}_{\gamma } &=\gamma _{cm}E_{\gamma }(1-\beta _{cm}) \\
&=\frac{\gamma _{cm}E_{\gamma }(1-\beta _{cm}^2)}{1+\beta_{cm}} \\
&=\frac{E_{\gamma }}{\gamma _{cm}(1+\beta_{cm})}
\end{align*}
Thank you, what a stupid error. I was so confused. Can you please confirm that, given a particle energy and momentum in the center of mass frame, the transformations to find the same quantities in the lab frame are (in natural units):
##E_{lab}=\gamma _{cm}E_{cm}+\beta _{cm}\gamma _{cm}p_{\parallel,cm}##
##p_{\parallel,lab}=\beta _{cm}\gamma _{cm}E_{cm}+\gamma _{cm}p_{\parallel,cm}##
##p_{\perp,lab}=p_{\perp,cm}##
And viceversa:
##E_{cm}=\gamma _{cm}E_{lab}-\beta _{cm}\gamma _{cm}p_{\parallel,lab}##
##p_{\parallel,cm}=-\beta _{cm}\gamma _{cm}E_{lab}+\gamma _{cm}p_{\parallel,lab}##
##p_{\perp,cm}=p_{\perp,lab}##
The ##\beta _{cm}## and ##\gamma _{cm}## are the same in both reference frames (only the sign of ##\beta ## changes):
##\beta_{cm}=\frac{|\sum p_{i,\parallel }|}{\sum E_{i}}##
Where ##p_{i,\parallel }## are the momentum components parallel to the boost, so you have to take into account the sign.
...and if the particle is a photon ##E_{\gamma}=p_{\gamma}##
(hope it will be useful for others in the future)
And viceversa:
What scenarios are covered by these equations?
I'm using these equations to solve problems about collisions in particle physics: switching from the laboratory frame to the center of mass frame and viceversa.
Okay, I can see that much. So, if I have two particles, A and B, and in the CM frame they have energies ##E_{A, cm}, E_{B, cm}## and momenta ##\vec{p}_{A, cm}, \vec{p}_{B, cm}##. Then, if we know the velocity of the CM frame in the lab frame, we can calculate the energy and momentum of the particles in the lab frame using your equations?
How are your equations different from the standard energy-momentum transformations?
Or, are we assuming one particle is at rest in the lab frame? Or, some other assumptions?
Yes. I wanted to find the most general transformations for energy and momentum of particles between the two reference frames. The energies and momenta are referred to a particle in a specific reference frame. I tried to solve some exercises and i got confused a little with signs. Then, solving more exercises, i understood the logic behind the transformations. The only difference is in the sign of beta. So, now i can say that these transformations are general, and for what concerne particle physics experiments, they hold in every configuration (fixed target or not).
Are you familar with four-vectors? Energy-momentum is a four-vector, hence its components transform according to the Lorentz Transformation.
What you have is one form of this Lorentz Transformation. This is covered here, for example:
https://hepweb.ucsd.edu/ph110b/110b_notes/node54.html
Note that as the sum of four-vectors is itself a four vector, then the total energy-momentum of a system of particles also transforms according to the Lorentz Transformation. This can be very useful. Note, however, that the invariant quantity ##E_T^2 - c^2P_T^2## is not the sum of the rest masses. It is sometimes called the "invariant" mass of the system (because it is the same in all reference frames). This is also very useful
Likes lLehner95
Related to Find the photon energy in the center of mass frame and vice versa
1. What is the center of mass frame?
The center of mass frame is a reference frame in which the total momentum of a system is zero. In this frame, the net energy of the system is equal to the rest energy of the system's center of mass. It is commonly used in particle physics to analyze the behavior of particles in collisions.
2. How do you find the photon energy in the center of mass frame?
To find the photon energy in the center of mass frame, you can use the formula E = pc, where E is the energy, p is the momentum, and c is the speed of light. In the center of mass frame, the total momentum of the system is zero, so the energy of the photon will be equal to its momentum times the speed of light.
3. What is the relationship between photon energy and frequency?
The energy of a photon is directly proportional to its frequency, according to the equation E = hf, where E is the energy, h is Planck's constant, and f is the frequency. This means that as the frequency of a photon increases, its energy also increases.
4. Can the photon energy in the center of mass frame be greater than the rest energy of the system's center of mass?
Yes, the photon energy in the center of mass frame can be greater than the rest energy of the system's center of mass. This is because the energy of the photon is not limited by the rest energy of the system, but rather by its frequency and momentum.
5. How do you convert between photon energy in the center of mass frame and the lab frame?
To convert between photon energy in the center of mass frame and the lab frame, you can use the Lorentz transformation equations. These equations take into account the relative velocities and the mass of the system to convert energies between frames. However, in the case of a photon, which has no mass, the energy in both frames will be equal.
