Find the torque on a bent pipe
In summary, the conversation discusses the necessary torque to rotate a pipe in a steady flow of liquid with given density and velocity. The approach involves using the equations for conservation of momentum and rotational forces, and the mass of the fluid is needed to calculate the torque. The distance from the axis of rotation to the point where the force is applied can be found using the radius of the pipe and the angle θ.
thshen34
Consider a steady flow of liquid with a density of 805 kg/m3 through a rotating tube as shown in the sketch. The flow speed is V = 5 m/s. If ω = 10 rad/s, find the torque necessary to rotate the pipe. Assume a uniform velocity distribution at the exit from the pipe, and that the
incoming fluid has no angular momentum.
Conversation of momentum and Rotational Forces
So I calculated the force of the fluid on the pipe, which is ρV(∏D^4)/4, which can be split up to y and x components, by multiplying cosθ and sinθ, respectively. However, this does not create any moment about the axis of rotation. So, my guess is that the x component of the force provides the centripetal force of the ω rotation. Given that F = mv^2/r, I'm thinking that the we can find the torque by Fr = mv^2, since we know v. Now, can someone help me find out what m ought to be? Is it just the mass of the bent pipe portion?
I think this is a valid attempt a solution, I only need a bit of concept cleared up. I hope someone will review this question please.
Thanks,
Dear ,
Your approach seems to be on the right track. To find the torque necessary to rotate the pipe, you can use the equation τ = F*r, where F is the force acting on the pipe and r is the distance from the axis of rotation to the point where the force is applied. In this case, the force acting on the pipe is the x component of the force you calculated, which is ρV(∏D^4)/4 * sinθ. The distance r can be calculated using the radius of the pipe and the angle θ.
However, the mass you are looking for is not the mass of the bent pipe portion, but rather the mass of the fluid flowing through the pipe. This can be calculated using the density and the volume flow rate, which can be found by multiplying the cross-sectional area of the pipe by the flow speed. Once you have the mass, you can use it in the equation τ = F*r to find the torque necessary to rotate the pipe.
I hope this helps clarify your approach. Let me know if you have any further questions.
Related to Find the torque on a bent pipe
1. What is torque?
Torque is a rotational force that is applied to an object. It can cause an object to rotate around a fixed point or axis.
2. How is torque measured?
Torque is typically measured in units of Newton-meters (Nm) or foot-pounds (ft-lb).
3. How does a bent pipe affect torque?
A bent pipe can change the direction or angle of the force applied to an object, thus affecting the torque. The amount of torque will depend on the degree and location of the bend in the pipe.
4. How do you calculate the torque on a bent pipe?
The formula for calculating torque on a bent pipe is T = F x d x sinθ, where T is the torque, F is the force applied, d is the distance from the force to the pivot point, and θ is the angle between the force and the lever arm.
5. What factors can affect the torque on a bent pipe?
The degree and location of the bend, the force applied, and the angle between the force and the lever arm are all factors that can affect the torque on a bent pipe.
  • Mechanical Engineering
