Finding a tangent line to a level curve - Don't understand solution
In summary, the gradient vector of f(x,y) = xy at (3,2) is <2,3>. This vector is perpendicular to the tangent line at (3,2), which can be represented as <x-3, y-2>. This is because the vector from (3,2) to any point on the tangent line is parallel to <x-3, y-2>. Additionally, the tangent line at (3,2) passes through the point (2,3) in order to be perpendicular to the gradient vector.
mrcleanhands
If f(x,y) = xy, find the gradient vector [itex]\nabla f(3,2)[/itex] and use it to find the tangent line to the level curve f(x,y) = 6 at the point (3,2)
[itex]f(x,y)=xy
\Rightarrow\nabla f(x,y)=<y,x>,\nabla f(3,2)=<2,3>[/itex]
[itex]\nabla f(3,2)[/itex] is perpendicular to the tanget line, so the tangent line has equation
[itex]\nabla f(3,2)\cdot<x-3,y-2>=0[/itex]... and so on
I understand that the dot product must be 0 if the two vectors are perpendicular.
What I don't get is how they pick the vector <x-3, y-2> given that the point were concered with is (3,2)
As opposed to doing: <2,3>.<x,y>=0 you mean?
The set of vectors that are perpendicular to <2,3> lie in a plane don't they?
yeah they're in a plane. But <x-3,y-2> is not a plane?
If it were [the plane perpendicular to <2,3>] then the dot product would be zero for every value of x and y so the relation would be useless.
It follows that just knowing that <2,3> is perpendicular to the tangent you want is not good enough - you need a way to select the one you want out of the whole plane. How would you go about that? What is special about this tangent?
hi mrcleanhands! :smile:
if (x,y) lies on the tangent plane, then the vector from (3,2) to (x,y) is a tangent at (3,2), and is parallel to <x-3, y-2> :wink:
I see, it has to lie on the point (2,3) which you get by taking a line from (3,2) to (x,y)
thanks to both of you!
Related to Finding a tangent line to a level curve - Don't understand solution
1. What is a tangent line?
A tangent line is a line that touches a curve at only one point and has the same slope as the curve at that point.
2. How is a tangent line related to a level curve?
A level curve is a curve on a surface where all points have the same value. The tangent line to a level curve is a line that is perpendicular to the gradient of the curve at a specific point, meaning it is also parallel to the level curve at that point.
3. What is the process for finding a tangent line to a level curve?
The process for finding a tangent line to a level curve involves finding the gradient of the curve at a specific point, which represents the slope of the tangent line. Then, using the slope and the point, the equation of the tangent line can be determined using the point-slope form or the slope-intercept form.
4. Why is it important to find the tangent line to a level curve?
Finding the tangent line to a level curve is important because it helps to understand the behavior of the curve at a specific point. It can also be used to approximate the curve and make predictions about its behavior.
5. What are some real-world applications of finding tangent lines to level curves?
Finding tangent lines to level curves has many real-world applications, such as in physics for calculating the velocity and acceleration of an object, in economics for determining the marginal cost and marginal revenue of a company, and in engineering for designing smooth and efficient curves for roads and bridges.
