Finding partial pressure at equilibrium
The partial pressure of nitrogen oxide at equilibrium can be calculated by subtracting the sum of the partial pressures of nitrogen and oxygen from the total pressure. In summary, the question asks for the partial pressure of nitrogen oxide at equilibrium given the partial pressures of nitrogen and oxygen at constant temperature and pressure.
haha0p1
46
Misplaced Homework Thread
In the coursebook the question says:
The reaction below was carried out at a pressure of 10×10⁴ Pa and at constant temperature.
N2 + O2 ⇌ 2NO
the partial pressures of Nitrogen and Oxygen are both 4.85×10⁴ pa
 Ccalculate the partial pressure of the nitrogen(ll) oxide, NO(g) at equilibrium.
In this question the partial pressure of nitrogen oxide is given at equilibrium or it is initial partial pressure. Also will the answer be 10.00×10⁴ - 4.85×10⁴ ?
I would assume that all pressures are at equilibrium.
No. How is the total pressure decomposed into partial pressures?
DrClaude said:
I would assume that all pressures are at equilibrium.No. How is the total pressure decomposed into partial pressures?
Ohkk. Then will the question be resolved in this way:
Partial pressure of nitrogen and Oxygen at equilibrium: 10×10⁴-4.85×10⁴= 5.15×10⁴
Partial pressure of Nitrogen oxide= ??
Take a look at Dalton's law
Likes haha0p1
I have understood the question now. 10×10⁴-(4.85×10⁴+4.85×10⁴) = Partial pressure of NO. right ?
Correct.
Related to Finding partial pressure at equilibrium
1. What is partial pressure at equilibrium?
Partial pressure at equilibrium refers to the pressure exerted by a single gas in a mixture of gases at equilibrium. It is the pressure that the gas would exert if it were the only gas present in the same volume and temperature as the mixture.
2. How is partial pressure at equilibrium calculated?
Partial pressure at equilibrium is calculated by multiplying the mole fraction of the gas by the total pressure of the mixture. The mole fraction can be determined by dividing the moles of the gas by the total moles of all gases in the mixture.
3. What is the significance of partial pressure at equilibrium?
Partial pressure at equilibrium is important because it helps to determine the concentration of a gas in a mixture and its contribution to the total pressure. It also plays a crucial role in understanding gas laws and gas reactions.
4. How does temperature affect partial pressure at equilibrium?
According to the ideal gas law, an increase in temperature will result in an increase in the volume of the gas and therefore an increase in its partial pressure. This is because the total pressure of the mixture remains constant, but the volume of the gas increases, leading to a higher mole fraction and partial pressure.
5. Can partial pressure at equilibrium be manipulated?
Yes, partial pressure at equilibrium can be manipulated by changing the temperature, volume, or number of moles of the gases in the mixture. This can be done to shift the equilibrium towards the desired product in a chemical reaction or to control the concentration of a gas in a mixture.
