Finding the critical point and its nature. With solid attempt
In summary: So what's your conclusion?In summary, the critical points of the function f(x, y) = y sin x + cos x are (-pi,0), (0,0), (pi,0), and (2pi,0). These points correspond to the x-value being any integer multiple of pi, and the y-value being 0. The nature of these critical points can be determined by finding the second derivatives, fxx, fyy, and fxy, and using the second derivative test.
tamintl
74
Finding the critical point and its nature. With solid attempt!
Find all critical points of the function
f(x, y) = xy2 - 2xy - 2x2 - 3x +7
and determine their nature.
none
I know that to find the critical points you must set fx = 0 and fy=0
Doing this I get:fx = -4x + y2 - 2y - 3 = 0
and
fy = 2xy - 2x = 0
Thus, fx = fy
-4x + y2 -2y - 3 = 0
-4x + (y+1)(y-3) = 0
I don't really know how to proceed? Any help would be great.
Factor the fy equation first. What conclusions can you draw from that?
fy = 2xy - 2x = 2x(y-1)
Thus, x=0 and y=1
SO, critical point is (0,1)...
So is that the only critical point or do I sub this back into fx to get another?
Thanks Dick!
Thus, x=0 and y=1
Thanks Dick!
Careful! 2x(y-1)=0 if x=0 OR y=1. Not necessarily both. Put those two possibilities back into fx and see what happens.
Silly me!
Okay subbing back into fx gives me: (0,-1), (0,3), (-1,1)
Assuming these are correct do I now find fxx, fyy, and fxy
to determine the nature (using theorem) ??
On a side note how do you find fxy? I'm confused about that particular instance.
Thanks Dick! I really appreciate your help
tamintl said:
Silly me!
Sure, now use the second derivative test on those three critical points. fxy isn't hard to to find, just take your fx and differentiate with respect to y, OR take fy and differentiate with respect to x. You'll get the same thing.
Got it thanks!
Now I have anther question:
Find all critical points of the function: f(x, y) = y sin x + cos x and determine their nature.
So we have fx = ycosx - sinx and fy = sinx
hence, for
fx we have y = sinx/cosx = tanx
and
fy we have sinx = 0
Therefore we have x=0... when we sub this into y=tanx we get y=0
Hence critical point is (0,0)
Would this be reasonable?
Regards
tamintl said:
Got it thanks!
hence, for
and
fy we have sinx = 0
Regards
x=0 isn't the only solution to sin(x)=0. What are the others?
∏, 2∏
Now what :/
edit: x=∏(n) for all n ε Z
tamintl said:
∏, 2∏
Now what :/
Put x=pi*n into fx. What does that tell you about y?
As you put it into fx, sinx = 0... therefore you have fx = -y for odd n and fx = y for even n..
Hence y=0 again for x=n*∏
Fine. So your critical points are (-pi,0), (0,0), (pi,0), (2pi,0)... right? (n*pi,0) where n is any integer.
Related to Finding the critical point and its nature. With solid attempt
1. What is a critical point in scientific research?
A critical point in scientific research refers to a specific value or condition where a system undergoes a significant change or transition. This change can be in physical, chemical, or biological properties and is often associated with a critical point in a phase transition.
2. How do scientists determine the critical point of a system?
Scientists use various techniques such as experimentation, data analysis, and mathematical modeling to determine the critical point of a system. This involves identifying specific parameters or variables that can influence the system and analyzing their relationship to determine the critical point.
3. What is the importance of finding the critical point in scientific research?
Finding the critical point is crucial in understanding the behavior and properties of a system. It can provide valuable insights into the underlying mechanisms and help predict how a system will respond to different conditions. This knowledge can also be applied in various fields, such as material science, chemistry, and environmental studies.
4. Can the critical point of a system change over time?
Yes, the critical point of a system can change over time, especially if there are external factors that can influence the system. For example, the critical point of a material may change due to changes in temperature or pressure. In some cases, the critical point may also shift due to internal changes within the system.
5. How does the nature of the critical point affect the behavior of a system?
The nature of the critical point can significantly impact the behavior of a system. For instance, a first-order phase transition will have a sharp change at the critical point, while a second-order phase transition will have a smoother transition. The nature of the critical point can also affect the stability and critical behavior of a system.
