How Do You Calculate Forces in a Truss Using the Method of Joints?
In summary, the conversation is about a truss with four straight pieces, split into two triangles and attached to another triangle. The person has already found the moment of the reactions and the reaction forces. They are trying to use the method of joints to calculate the forces on the different members of the truss. The triangles are all 45° 45° and 90° angles. The conversation also includes a diagram of the truss.
naruto631
i am trying to figure out the forces of the different members of this truss in which looks like a a square that is split into two triangles and is affixed to another triangle the same size I have already found the moment of the reactions and already found the reaction forces as well.
Code:
  A -500lbf  C -500lbf
                              2ft           2ft
                            --------l----------- l Pin Reaction E
                              \         l          /     l
                                \       l        /       l   2ft
                                  \     l      /         l
                                    \   l    /           l
                                      \ l  /---------l Roller reaction D
                                        B
sin
cos
tan
Efx=0
Efy=0
Em=0
more or less it is a question about the method of joints but I am not exactly sure how you do it. Also the triangles are all 45° 45° and 90°
It is not clear, is your truss is made of 4 straight pieces, or 7? To what do the lbf refer?
If you wish to use ASCII art (and I don't recommend it), then you must include it within [code] [/code] pair. Otherwise the forum software squashes strings of spaces into a single space. You'll find it easiest if you also use Courier fixed-size font.
Code:
 [font="courier new"]
                                   [/font]
thank you and your picture is pretty much accurate without that line extending after B though
Point B is unsupported and in mid-air, is it?
What and where are points A and C?
I would suggest using the method of joints to solve for the forces in the truss. This method involves analyzing the forces acting at each joint in the truss and using the equations of equilibrium (Efx=0, Efy=0, and Em=0) to solve for the unknown forces.
First, identify all the joints in the truss and label them with letters (A, B, C, D, E). Then, start at a joint with only two unknown forces and use the equations of equilibrium to solve for those forces. Continue this process at each joint until all the unknown forces in the truss are solved for.
Additionally, since all the triangles in the truss are 45° 45° and 90°, you can use the trigonometric functions (sin, cos, tan) to help solve for the forces.
It is also important to note that the moment of the reactions and the reaction forces have already been found, so they can be used as known values in the equations of equilibrium.
Overall, the method of joints is a systematic and reliable way to solve for the forces in a truss. Good luck with your calculations!
Related to How Do You Calculate Forces in a Truss Using the Method of Joints?
1. What is a truss?
A truss is a structural framework that is made up of interconnected elements, usually consisting of straight members that are connected at their ends by joints. It is designed to bear loads and distribute them evenly to its various points of support.
2. What are the forces acting on a truss?
The forces acting on a truss include tension, compression, and shear. Tension is a pulling force that occurs along the length of a member, while compression is a pushing force that occurs along the length of a member. Shear is a force that occurs perpendicular to the length of a member.
3. How do you find the forces of a truss?
To find the forces of a truss, you will first need to determine the external loads acting on the truss. Then, you will need to analyze the truss using the method of joints or the method of sections to determine the internal forces in each member. Finally, you can use equilibrium equations to calculate the forces acting on each member.
4. What is the method of joints?
The method of joints is a structural analysis technique that is used to determine the internal forces in the members of a truss. It involves analyzing the forces at the joints of the truss by considering the equilibrium of forces acting on each joint.
5. What is the method of sections?
The method of sections is another structural analysis technique that can be used to determine the forces in the members of a truss. It involves cutting the truss into smaller sections and analyzing the forces acting on each section using equilibrium equations.
