Finding the total energy of a Pi meson
In summary: Okay, but you may need to do more than one line of algebra at a time. I'm going off-line now, but maybe someone else can provide further help if you need it.In summary, a K meson with a rest mass of 500 MeV breaks into two Pi mesons with rest masses of 140 MeV each. One of the Pi mesons is left at rest. To find the total energy of the remaining Pi meson, conservation of energy and momentum are used. The energy equation (E=mc^2) and momentum equation (p=γmv) are applied to each particle, with the initial energy being equal to the sum of the final energies. Using the notation E0 for the initial energy
AsadaShino92
A K meson (an elementary particle with approximately 500 Mev rest mass) traveling through the laboratory breaks up into two Pi mesons (elementary particles with 140 Mev rest energies). One of the Pi mesons is left at rest. What is the total energy of the remaining Pi meson?
E=mc^2
KE=(γ-1)mc^2
My first step was trying to use energy conservation E(initial)=E(final)
The K meson is traveling so the total E at the start is E(rest mass of K)+KE(K meson)
E(initial)=500 Mev+(γ-1)mc^2
In the end, the K meson breaks into 2 Pi mesons, each with 140 Mev rest mass. One stops and the other keeps on moving.
So the total E at the end is E(rest mass Pi)+E(rest mass 2nd Pi)+(γ-1)mc^2
E(final)=140 Mev+140Mev+(γ-1)mc^2
E(initial)=E(final)
500 Mev+(γ-1)mc^2=140 Mev+140Mev+(γ-1)mc^2
But now I don't know what to do next. I don't have a value for gamma.
E=mc^2
KE=(γ-1)mc^2
E(initial)=E(final)
What about momentum?
Then I would use p=γmv but I don't think I have the value for those. I just know that momentum would also be conserved.
In general it's messy to use ##\gamma## in this sort of problem. Can you think of a way to tackle the problem without it?
P=E/C ?
AsadaShino92 said:
P=E/C ?
That's for a massless particle. Do you know:
##E^2 = p^2c^2 + m^2c^4##?
So am I using this equation to solve for momentum?
The general approach to these particle problems is:
1) Conservation of energy
2) Conservation of momentum.
3) For each particle: ##E^2 = p^2c^2 + m^2c^4##
Hint: stick with ##M## for the initial K meson mass and ##m## for the pi meson mass and leave the numbers out until the end.
The notation is up to you, but I would use ##E_0, p_0## for the Energy & Momentum of the initial K meson; ##E_1, p_1 (p_1= 0)## for the pi meson that ends up at rest and ##E_2, p_2## for the second pi meson.
You're trying to solve for ##E_2## of course.
Using the notation, I have the conservation of energy written as E0=E1+E2
Then using the energy equation for each particle
For the K meson
E02=P02C2+M2C4
For the Pi stopped
E12=m2C4 since P1=0
For Pi moving
E22=P22C2+m2C4
Momentum conservation
P0=P1+P2
Since P1=0
P0=P2
Do I just plug all this into E2=E0-E1?
Why not? You may want to square that equation first.
You mean instead I should use E22=E02-E12?
##(E_0 - E_1)^2 \ne E_0^2 - E_1^2##
My mistake. Then squaring both sides should be E22=(E0-E1)2
##E_2^2 = (E_0 - E_1)^2 = \dots##?
(E0-E1)2=E02-2E0E1+E12
Related to Finding the total energy of a Pi meson
1. What is a Pi meson?
A Pi meson, also known as a pion, is a subatomic particle that is classified as a meson. It is made up of a quark and an antiquark and is responsible for the strong nuclear force between protons and neutrons in an atom's nucleus.
2. How is the total energy of a Pi meson calculated?
The total energy of a Pi meson is calculated using the formula E = mc^2, where E is the energy, m is the mass of the Pi meson, and c is the speed of light. This formula is derived from Einstein's famous theory of relativity.
3. What factors affect the total energy of a Pi meson?
The total energy of a Pi meson is affected by the mass of the meson, as well as its velocity. As the mass increases, the energy also increases. The energy also increases as the velocity of the meson approaches the speed of light.
4. Why is calculating the total energy of a Pi meson important?
Calculating the total energy of a Pi meson is important in understanding the behavior and interactions of subatomic particles. It also helps in studying the fundamental forces and laws of the universe.
5. How is the total energy of a Pi meson measured?
The total energy of a Pi meson can be measured using particle accelerators, which accelerate the mesons to high speeds and then measure the energy using detectors. It can also be calculated using theoretical models and equations.
