First order separable Equation ODE
In summary: You could do this from the beginning, looking for a solution y=5+De-sin(x) and ruling out the case D=-2. Or you could take -D as the new D and get y=5+De-sin(x) and rule out D=2. Or you could just use D as the new D and get y=5+De-sin(x) and rule out D=1/2. The point is that the absolute value is not needed. The general solution is y=5+De-sin(x) and the D you want is positive. If you let x=0 and y=7 you get D=2. But if you let x=pi
sanhuy
40
[tex] \frac{dy}{dx}\:+\:ycosx\:=\:5cosx [/tex]
I get two solutions for y however only one of them is correct according to my online homework
(see attempt at solution)
y(0) = 7 is initial condition
[tex]\int \:\frac{1}{5-y}dy\:=\:\int \:cosxdx\:+\:C [/tex]
[tex] -ln\left|5-7\right|\:=\:sinx\:+C [/tex]
[tex] \left|5-y\right|\:=\:De^{-sinx}\:where\:D\:=\:e^{-C} [/tex]
[tex] \left|5-y\right|\:=\:5-y\:,\:if\:5-y\:>\:0\:and\:\left|5-y\right|\:=\:-\left(5-y\right)\:if\:5-y<0 [/tex]
using initial conditions for both equations
[tex] y=5\:-De^{-sinx}\:\:and\:\:y\:=\:5+De^{-sinx}[/tex]
[tex] y=5\:-2e^{-sinx}\:\:and\:\:y\:=\:5+2e^{-sinx} [/tex]
however the first solution is incorrect I don't understand why
Did you mean 5 - y above? If you really meant 5 -7, I wouldn't substitute in the initial condition yet.
I'm not totally clear on what you're doing above. Since y(0) = 7, you can assume that y -7 < 0 for solutions near the initial condition.
[tex] y=5\:-De^{-sinx}\:\:and\:\:y\:=\:5+De^{-sinx}[/tex][/B]
Why don't you apply the initial condition on ##\left|5-y\right|\:=\:De^{-sinx}\,##? That gives ##\left|5-y\right|\:=\:2e^{-sinx} > 0##. Now check your signs again.
Since 2e^−sinx>0 you can drop the absolute sign correct?
then it becomes
y=5−2e^−sinx?
then it becomes
y=5−2e^−sinx?
No you can't, because inside the absolute sign can still happen both possibilities. Just consider the cases ##y(x) > 5## and ##y(x) \leq 5##.
Edit: Sorry, I think I made a sign error myself.
if y(x) > 5 then |y-5| = (y-5)
and if y(x) <= 5 we get |y-5| = -(y-5) ?
then we get two solutions that i posted above again? Am i missing something here
Now, that I've seen my sign error, I did what you should do as well with all of these kind of equations: check them by differentiation. (I think you were right in the first place.)
both solutions work, but my webwork says the first one is wrong
Maybe you've had a typo in your other solution. Or some additional information is hidden somewhere in your text.
They satisfy the differential equation, but I do not see how your negative multiplier solution satisfies the initial condition.
Likes fresh_42
I just noticed this as well. BTW I was just wondering the way I got rid of my absolute values was correct right, regardless of the general problem i stated?
I was not quite sure what you did. I would substitute x=0, y=7 with still |y-5| to find D=2. Then you get y=5+/-2e-sin(x), then reuse the initial condition to rule out the -2 case.
Related to First order separable Equation ODE
1. What is a first order separable equation ODE?
A first order separable equation ODE is a type of ordinary differential equation (ODE) that can be written in the form dy/dx = f(x)g(y), where f(x) and g(y) are functions that only depend on one variable. This type of equation can be solved by separating the variables and integrating each side separately.
2. How do you solve a first order separable equation ODE?
To solve a first order separable equation ODE, you must first separate the variables by moving all the terms involving y to one side of the equation and all the terms involving x to the other side. Then, you can integrate both sides with respect to their respective variables and solve for y.
3. What is the general solution to a first order separable equation ODE?
The general solution to a first order separable equation ODE is given by y = F(x) + C, where F(x) is the antiderivative of f(x) and C is the constant of integration. This solution can be found by integrating both sides of the equation and solving for y.
4. Are there any special cases for solving a first order separable equation ODE?
Yes, there are some special cases for solving a first order separable equation ODE. For example, if f(x) = 0, then the equation becomes dy/dx = 0, which can be solved by simply integrating both sides and solving for y. Additionally, if g(y) = 0, the equation becomes dy/dx = f(x)/0, which cannot be solved using this method.
5. What are some real-world applications of first order separable equation ODEs?
First order separable equation ODEs have many real-world applications, such as in population growth models, radioactive decay, and chemical reactions. They are also commonly used in physics and engineering to model various physical phenomena.
