Fixed Stars Moving Faster Than Light? Problem?
In summary, in the conversation it was discussed that in a rotating frame, the stars appear to be moving faster than the speed of light, but this is only a result of the coordinate system and not a violation of the cosmic speed limit. In general relativity, it can be more complex to determine relative velocities between objects, but in flat spacetime, it is still limited by the speed of light. It is recommended to use simpler coordinate systems, such as Cartesian or Minkowski, unless there is a specific reason not to.
KingSnackMan
If I spin around in an open field at night and look up to the stars they appear to be moving relative to me. Additionally, they are very far away and trace out a giant arc length in a very short time (S=rθ). With respect to me, these stars are moving faster than light. Is this a problem? Has the cosmic speed limit been broken? Do I have to abandon relative motion?
To summarise, your rotating frame is not an inertial frame. The coordinate speed of light is only limited and fixed in inertial frames.
The physical relative velocity between two objects is a different matter. It is bounded by c regardless of the coordinates you use. It also gets slightly more complicated in GR.
The speed of light is invariant and cannot be exceeded locally. If you use a simple Cartesian coordinate system then this concept is simple to express everywhere just by dropping the word "locally" (at least for SR).
If you use a more complex coordinate system, such as rotating polar coordinates, then this concept is not simple to express in general. You find that the speed of light expressed in these coordinates is different at different points and in different directions. However, all the additional complexity is down to a silly choice of coordinates. You are still expressing the same notion of the invariance of light speed, just hiding the invariance behind a layer of complicated maths.
There can be good reasons to do this (see GR for one). But don't if you don't have to, would be my advice.
This is very interesting, specifically that it is only local speeds that need to be c. Is this in any well known books? Carroll? Wald?
Any text covering general relativity will mention it, I should imagine. In curved spacetime it isn't necessarily possible to make an unambiguous comparison of velocities (or any other vector) at one point with velocity (or whatever) at another point. So you can only insist that local relative speeds cannot exceed c bcause you can't really define relative speed between spatially separated objects.
You can define relative speed for spatially separated objects in flat spacetime (i.e. in special relativity), and hence insist that it must be less than c. If you choose a complicated set of coordinates, you can hide that simple statement quite thoroughly.
Let me add that this is very similar to using curvilinear coordinates. Unless you have a special reason not to, using Cartesian coordinates is almost always the easiest. In the same fashion, using Minkowski coordinates in SR is most often the easiest.
Related to Fixed Stars Moving Faster Than Light? Problem?
1. What are fixed stars moving faster than light?
Fixed stars moving faster than light is a theoretical concept in astrophysics that suggests the existence of objects in the universe that can travel faster than the speed of light, which is believed to be the maximum speed possible according to Einstein's theory of relativity.
2. Is there any evidence of fixed stars moving faster than light?
There is currently no evidence to support the existence of fixed stars moving faster than light. All current scientific observations and experiments have confirmed that the speed of light is the ultimate speed limit in the universe.
3. How is it possible for fixed stars to move faster than light?
The concept of fixed stars moving faster than light goes against our current understanding of the laws of physics, specifically Einstein's theory of relativity. It is considered to be a theoretical possibility, but there is no known mechanism or explanation for how it could occur.
4. What would be the implications if fixed stars were able to move faster than light?
If fixed stars were able to move faster than light, it would fundamentally change our understanding of the laws of physics and the nature of the universe. It could lead to a re-evaluation of many scientific principles and potentially open up new possibilities for space travel and exploration.
5. Could fixed stars moving faster than light explain the expansion of the universe?
No, the expansion of the universe is not related to fixed stars moving faster than light. The expansion of the universe is primarily driven by the force of dark energy, which is a completely separate phenomenon from the speed of light or the movement of stars.
