Fluid Statics (multiple choice question)
In summary, according to Archimedes' Principle, the buoyant force on a submerged object is equal to the weight of the volume of fluid displaced by the object. Therefore, if two objects of the same size are submerged, the buoyant force will be the same regardless of their densities. Additionally, the buoyant force on a boat is greater in salt water due to the higher density of the water.
Ariel P
#1 If you hold a block of lead and an identical size block of Styrofoam under water, the buoyant force will
a) be greater on the lead block.
b) be greater on the Styrofoam block.
c) be the same on both blocks.
d) depend on the depth that each block is held. #2 Salt water has greater density than fresh water. A boat floats in both fresh and in salt water. Where is the buoyant force greater on the boat?
a) in salt water
b) in fresh water
c) buoyant force is the same in both
d) not enough information given to determine the answer
I think this principle is relevant,
Archimedes' Principle:
A fluid exerts an upward buoyant force on a submerged object equal in magnitude to the weight of the volume of fluid displaced by the object.
#1 Well, what I can guess from that principle is that the buoyant force will be the same beacuse it depends on the "weight of the volume of fluid displaced" and both the lead block and styrofoam block are the same size.
#2 I got that the answer is (C) from somewhere but I'm unable to reason for that answer. From my experience, I assume the boat will float "more" in salt water than fresh water, which would differ the amount of volume of water displaced. Then, the answer cannot be (C). I'm not so sure,..thanks!
Your reasoning for the first part is right. For the second part use what you know,
For the second part the boat weighs the same so the "weight of the volume of fluid displaced" is the same but in one case the fluid is water and in the other it is more dense salt water. So the "weight of the volume of fluid displaced" is,
W = ρ_water*volume_water displaced =
ρ_salt water*volume_salt water displaced
Because the salt water is more dense the boat does not have to "displace" as much water.
Hope this was not too confusing.
I don't see how the buoyant force on the Styrofoam would be the same as the lead since they may be the same size, but their densities are far different
and the equation is
ρsubfluid = msub/mfluid
ρst<<ρPb
and for c) he is right because the boat is not being held at the same depth in salt water and water unlike the first question.
and the equation is
ρst<<ρPb
If the following is correct,
"Archimedes' Principle:
A fluid exerts an upward buoyant force on a submerged object equal in magnitude to the weight of the volume of fluid displaced by the object."
then I think I correctly translated the above into,
But I make mistakes all the time.
The buoyant force is a function of how much liquid is displaced and the density of the liquid. Any two objects of the same volume will have the same buoyant force if they are held entirely under the liquid's surface. Density of the object is not a factor.
Now if you were under water and you wanted to weigh 1 cubic foot of aluminum and one cubic foot of steel, naturally the steel would weigh more. But the buoyant force on each is the same.
Related to Fluid Statics (multiple choice question)
1. What is fluid statics?
Fluid statics is the study of fluids at rest, specifically focusing on the forces and pressure within a fluid that is not in motion.
2. What is the difference between fluid statics and fluid dynamics?
Fluid dynamics deals with fluids in motion, while fluid statics deals with fluids at rest.
3. What is hydrostatic pressure?
Hydrostatic pressure is the pressure exerted by a fluid at rest due to the weight of the fluid above it.
4. What is Pascal's principle?
Pascal's principle states that a change in pressure applied to an enclosed fluid will be transmitted equally to all parts of the fluid.
5. How is fluid statics used in practical applications?
Fluid statics is used in various fields such as engineering, meteorology, and oceanography to understand and predict the behavior of fluids at rest. It is also used in the design and construction of structures that are immersed in fluid, such as dams, ships, and submarines.
