Forces in symmetrical construction
In summary, the problem involves determining the forces on the bolts and hook contact surface of a slab with a uniform distributed load on it. However, due to the presence of more constraints than necessary, it is not possible to precisely determine all the forces. Assumptions need to be made, such as perfect symmetry and uniform loading, in order to proceed with analysis. The stiffness of the slab and the alignment of the bolts also play a role in the distribution of forces. Overall, the problem requires further information and assumptions in order to be solved accurately.
Lisciu
38
We have a slab with uniform distrubuted load on it W. All dimensions.
[/B]
I'm looking for the force on the bolts and force on the hook contact surface.
My way to do it is to reduce the problem for 2D. But the problem is that I'm not sure how to solve this then. Because in 2D drawing we will be left with 6 bolts (3 each side) and 2 contact surface from hook).
The question I have:
1. The force that I will get is the half of the possible for this construction? Because I have other half of this construcion not calculated.
2. Is it not to many unknows? There is 6 force acting on each bolt and 2 pressure force acting on the bracket hook. How to find this forces? I know only dimensions and the pressure on the slab (the weigh of it is neglected)
Whenever there are more constraints than are necessary to provide rigidity, it is not possible to determine all the forces precisely. You will have to make assumptions like things being perfectly symmetric, which will not be exactly the case.
For the four brackets resting on the bars, you might as well assume the load is distributed uniformly. In practice, it depends how the stiffness compares with the imperfections in the shapes. If the structures are extremely stiff and a pair of diametrically opposite brackets is slightly lower than the other pair, they will take most of the weight.
For the bolts, one bolt at a bracket would not constrain it, two would. The third gets us into the same problem as above. To proceed, you have to assume some degree of perfection. In this case, however, it would not be appropriate to assume uniform loading over the three. There are moments to consider. What equations can you develop for those?
Thanks haruspex, for your introduction.
The problem i Getting here is that I'm not sure if I can do things like that :
1 . Find C.O.G. for UDL. Attached there Point Force. (if the UDL working on Width= 300 mm and Length 400 mm. I just multiply by 300 mm to get the distributed force on member that is on the middle with span of 400 mm length.)
2. I trying to take the equilibrium around Y- Axis. So there will be force acting on the bracket from the bar from left side end right. I shouldn't take a bolts as a supports. So the force acting on the bolts should be moment multiply by arm. The bolt with longer arm have biggest force and that the bolt that I should check. I don't know only how to get the specific force acting on this bolt. Because it always be more unknows in Moment equilibrium. It won't be if i will assume that the force from poin
I take back what I wrote about moments. Again, it will depend on the stiffness of the slab. If the slab is very stiff, and the bolts are perfectly aligned, there may be a nearly equal load on all bolts. In practice, I would expect the slab to bow a little. That would increase the load on the innermost bolts, and could even reverseload on the outermost bolts. Quite impossible to analyse without far more information.
So all I can suggest is to take the naive view and assume load is distributed evenly across the bolts, and likewise where the brackets rest on the bars. If you are expected to do anything more sophisticated, I do not understand how.
Related to Forces in symmetrical construction
1. What is the definition of symmetrical construction?
Symmetrical construction refers to the balanced arrangement of elements on both sides of a central axis. This means that the weight, size, and shape of objects are evenly distributed on either side, creating a sense of harmony and balance.
2. How do forces play a role in symmetrical construction?
In symmetrical construction, forces are used to maintain the balance and stability of the structure. These forces include tension, compression, and shear, which are distributed equally on both sides of the central axis to prevent any part of the structure from collapsing or tilting.
3. What are some examples of symmetrical construction in nature?
Symmetrical construction can be seen in many natural structures, such as snowflakes, butterfly wings, and flowers. These structures have a central axis and balanced elements on either side, providing strength and stability against external forces.
4. What are the benefits of using symmetrical construction in building design?
Symmetrical construction is not only aesthetically pleasing, but it also has practical benefits. By distributing forces evenly, it can withstand external forces, such as wind and earthquakes, more effectively. It also allows for efficient use of materials and can save on construction costs.
5. Are there any drawbacks to using symmetrical construction?
One potential drawback of symmetrical construction is that it may limit the design options and creativity of a structure. It also requires precise planning and execution to maintain perfect symmetry, which can be challenging and time-consuming.
  • Mechanics
