Fourier Series and orthogonality
In summary: And it depends on the interval. Just because ##\int_{-\pi}^{\pi} \cos(mx)\cos(nx)~dx = 0## if ##m\ne n## doesn't mean, for example, that ##\int_{0}^{\frac \pi 4} \cos(mx)\cos(nx)~dx = 0##.
Alec Neeson
Can someone explain the concept to me. Does it mean the the a's of n and b's of n are 90 degrees apart? I know the inner-product of the integral is 0 if the two are orthogonal.
I think you mean ##a_n## and ##b_n##. And I guess you are talking about the Fourier coefficients. They are just numbers and it doesn't make any sense to talk about numbers "being 90 degrees apart".
Orthogonality is a generalization of "perpendicular". Two nonzero vectors in 3D are perpendicular if their dot product is zero:$$
\langle a_1,a_2,a_3\rangle \cdot \langle b_1,b_2,b_3\rangle = a_1b_1 + a_2b_2 + a_3b_3 = 0$$This idea is generalized to functions by the definition: Functions ##f## and ##g## are orthogonal with respect to a weight function ##w(t)>0## on an interval ##[a,b]## if ##\int_a^b f(t)g(t)w(t)~dt = 0##. Often in classical Fourier series, ##w(t) = 1## Here the sum in the dot product corresponds to the integral of the two functions.
The fact that the functions ##\{\sin(\frac{n\pi x}{p}),\cos(\frac{n\pi x}{p})\}## are orthogonal on ##[-p,p]## is what allows you to get nice closed formulas for the coefficients ##a_n## and ##b_n## in Fourier series. Any text on FS will explain this in detail.
If that's a little wordy for you, maybe I can dumb it down. Just keep in mind I am only now learning this stuff myself.
Remember how you used {i, j, k} to represent orthogonal unit vectors? It's the same idea with {cos(x), cos(2x), ... , cos(Nx)}.
The same way you could represent any 3D vector as xi + yj + zk, you can represent any function as a sum of sines and cosines of varying frequency.
cos(1x) is orthogonal to cos(.9999x) -> meaning the slightest variation in frequency will result in a pair of orthogonal functions...
I think. Anyone in the know, please feel free to correct or confirm my suspicions.
EDIT: Cut out some stuff I wrote that was even confusing to me.
I think.
No. That isn't true. Orthogonality depends very much on the particular frequencies and the interval of definition.
We learned in class that {cos(x), cos(2x), ... , cos(Nx)} forms an orthogonal set... is this true?
Not to hijack the thread, but I'm trying to get some visual intuition on how orthogonality depends on the frequency.
And it depends on the interval. Just because ##\int_{-\pi}^{\pi} \cos(mx)\cos(nx)~dx = 0## if ##m\ne n## doesn't mean, for example, that ##\int_{0}^{\frac \pi 4} \cos(mx)\cos(nx)~dx = 0##. Also, that set of cosines are orthogonal to each other, not to other cosines with different frequencies. So you wouldn't expect, for example, that ##\int_{-\pi}^{\pi} \cos(x)\cos(.9999x)~dx = 0## as you mentioned.
Related to Fourier Series and orthogonality
1. What is a Fourier series?
A Fourier series is a mathematical concept that represents a periodic function as a sum of sinusoidal functions with different frequencies and amplitudes.
2. What is the significance of orthogonality in Fourier series?
Orthogonality is significant in Fourier series because it allows for the decomposition of a function into its constituent sinusoidal components. This simplifies the analysis of complex periodic functions and makes it easier to understand their behavior.
3. How do you determine the coefficients in a Fourier series?
The coefficients in a Fourier series can be determined using integration techniques, such as the Fourier series coefficients formula or the orthogonality property. These coefficients represent the amplitude and phase of each sinusoidal component in the series.
4. Can Fourier series be used for non-periodic functions?
No, Fourier series can only be used for periodic functions. However, there are extensions of Fourier series, such as the Fourier transform, that can be used for non-periodic functions.
5. What are some real-world applications of Fourier series?
Fourier series have many practical applications, such as signal processing, image and sound compression, and solving differential equations. They are also commonly used in fields like engineering, physics, and mathematics for analyzing and understanding periodic phenomena.
