General Relativity - Circular Orbit around Earth
Recall that the correct expression for the light pulse is ds = 0, but ##dt \neq 0## and ##dr \neq 0##.But you just need to find ##\Delta \tau = \int d\tau## for the total round trip of the photon.In summary, we discussed finding the proper time in the rest frame of a particle, in the laboratory frame, and in a photon traveling from point A to point B in time P. We derived equations for the proper time in each frame and discussed the relationship between proper time and coordinate time for a light pulse traveling radially. We also found that the result for the proper time in the photon implies a relationship between the radius and the Schwar
unscientific
1,734
(a) Find the proper time in the rest frame of particle
(b) Find the proper time in the laboratory frame
(c) Find the proper time in a photon that travels from A to B in time P
Part(a)
[/B]
The metric is given by:
[tex] ds^2 = -\left( 1 - \frac{2GM}{c^2r} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2r} \right) dr^2 [/tex]
Circular orbit implies that ##dr^2 = 0##, so
[tex]ds^2 = c^2 d\tau^2 = -\left( 1 - \frac{2GM}{c^2R} \right) c^2 dt^2 [/tex]
[tex] \left( \frac{d\tau}{dt} \right)^2 = \left( 1 - \frac{2GM}{c^2R} \right) [/tex]
[tex] \frac{d\tau}{dt} = \sqrt { \left( 1 - \frac{2GM}{c^2R} \right) } [/tex]
Since the time between event A and B is ##dt = P##, the time experienced in the rest frame must be ## d\tau = \sqrt { \left( 1 - \frac{2GM}{c^2R} \right) } P ##?
I'm not sure how to approach parts (b) and (c)..
Does ##dx^2 + dy^2 +dz^2 = 0## for two neighboring points on the orbit?
They are at the same radius, so yes.
For general motion in the xy plane (z = 0), how would you express ##dx^2+dy^2## in polar coordinates ##(r, \theta)##?
[tex] r^2sin^2 \theta d\phi [/tex]
TSny said:
Oh I must have confused the r's. It should be:
[tex] ds^2 = -\left( 1 - \frac{2GM}{c^2r} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2r} \right) R^2 d\phi^2 [/tex]
Since for ##z=0## we let ##\theta = \frac{\pi}{2}##.
On the circular orbit of radius R, what is the value of little r?
r = R
Right.
[tex]ds^2 = -\left( 1 - \frac{2GM}{c^2R} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2r} \right) R^2 d\phi^2 [/tex]
Using ## d\phi = \omega dt = \frac{2\pi}{P} dt ##
[tex] ds^2 = -\left( 1 - \frac{2GM}{c^2R} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2 R} \right) R^2 (\frac{2\pi}{P})^2 dt^2[/tex]
Not quite. Does ##R^2P^2dt^2## have the correct dimensions of distance squared?
Using ## d\phi = \omega dt = \frac{2\pi}{P} dt ##,
[tex] ds^2 = -\left( 1 - \frac{2GM}{c^2R} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2 R} \right) R^2 (\frac{2\pi}{P})^2 dt^2 [/tex]
[tex] -c^2 d\tau^2 = -\left( 1 - \frac{2GM}{c^2R} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2 R} \right) R^2 (\frac{2\pi}{P})^2 dt^2 [/tex]
[tex] \left( \frac{d\tau}{dt} \right)^2 = \left( 1 - \frac{2GM}{c^2R} \right) - \left( 1 + \frac{2GM}{c^2 R} \right) R^2 \left(\frac{2\pi}{Pc}\right)^2 [/tex]
Looks good.
TSny said:
Looks good.
I am stuck on part (b) though..
What is ##dx^2 + dy^2 + dz^2## for a fixed point on the orbit?
For a fixed point, it is ##0##, so ##\frac{d\tau}{dt} = 1 - \frac{2GM}{c^2R}##.
...and ##ds^2 = ##?
TSny said:
...and ##ds^2 = ##?
Solving, we get ## \frac{d\tau}{dt} = 1 - \frac{2GM}{c^2R} ##.
For part (c), since beam of light travels at speed ##c## in all frames, is ##dr^2 = c^2 dt^2 = c^2 P^2##?
unscientific said:
For part (c), is ##dr^2 = c^2 dt^2##?
No. ##dr/dt## for the radially traveling light pulse is just a "coordinate speed of light" and need not equal c.
But no matter what the coordinate speed of light, what is ##ds## for any two neighboring space-time events on the worldline of a light pulse?
TSny said:
No. ##dr/dt## for a light pulse is just a "coordinate speed of light" and need not equal c.
Time-like, no rest frame. so ##ds = 0##.
It's neither spacelike or timelike. It's "lightlike". Yes, ds = 0.
TSny said:
Yes.
So does this mean the equation is simply:
[tex] 0 = -\left( 1 - \frac{2GM}{c^2R} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2r} \right) R^2 d\phi^2 [/tex]
[tex] 0 = -\left( 1 - \frac{2GM}{c^2R} \right) c^2 dt^2 [/tex]
The light is traveling radially. So, what is ##dx^2 + dy^2 + dz^2## in polar coordinates?
But, you are interested in the proper time. How is ##ds## related to ##d\tau##?
Since it is only moving radially, ##d\phi = 0## so ##dx^2 + dy^2 = dr^2##.[tex] ds^2 = -\left( 1 - \frac{2GM}{c^2r} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2r} \right) dr^2 [/tex]
[tex]ds^2 = -c^2 ~ d\tau^2 = 0 [/tex]
OK, but you don't need the metric for part (c).
You know ##ds^2 = -c^2d\tau^2##. So, for an increment along the light path, what is the change in proper time ##d\tau##?
I don't understand why it isn't simply ## ds^2 = -c^2 ~ d\tau^2 = 0 ##
That's correct.
TSny said:
That's correct.
So the result doesn't really say anything other than:
[tex]0 = -\left( 1 - \frac{2GM}{c^2R} \right) c^2 dt^2 [/tex]
which means either ##dt = 0## which is not possible since ##dt = P##. Therefore it implies that ##R = \frac{2GM}{c^2}##, which happens to be the schwarzschild radius.
  • #31
Recall that the correct expression for the light pulse is [tex] ds^2 = -\left( 1 - \frac{2GM}{c^2r} \right) c^2 dt^2 + \left( 1 + \frac{2GM}{c^2r} \right) dr^2 [/tex]
##ds = 0##, but ##dt \neq 0## and ##dr \neq 0##.
But you just need to find ##\Delta \tau = \int d\tau## for the total round trip of the light. So, you don't need to worry about ##dt## or ##dr##.
  • #32
Yeah, but ##d\tau = 0## so ##\int d\tau = 0##. So from the light's perspective, no time has passed at all. Does this even make sense?
  • #33
That's right. Of course, no physical observer can travel at the speed of light. But, in a thought experiment, you can imagine the observer moving at 0.99999...c (add as many 9's as you wish). The time elapsed for this observer will approach zero. It's the ultimate "twin paradox" scenario where the traveling twin would not age at all!
It's strange, but it's a natural consequence of SR and GR.
Likes unscientific
Related to General Relativity - Circular Orbit around Earth
1. What is General Relativity?
General Relativity is a theory of gravity developed by Albert Einstein in the early 20th century. It explains how massive objects, such as planets and stars, create a curvature in spacetime which causes other objects to move in a curved path.
2. How does General Relativity explain circular orbits around Earth?
In General Relativity, the mass of Earth creates a curvature in spacetime which causes objects, such as satellites, to follow a curved path around it. This curved path is what we observe as a circular orbit.
3. Why is General Relativity important in understanding circular orbits around Earth?
General Relativity is important because it accurately predicts the motion of objects in the presence of strong gravitational fields, such as the Earth. It also helps us understand the effects of gravity on the flow of time and the bending of light.
4. How does the mass of the object affect the circular orbit?
The mass of the object affects the circular orbit by determining the strength of the gravitational force between the object and the Earth. The greater the mass, the stronger the gravitational force, and the faster the object will need to move to maintain a circular orbit.
5. Can General Relativity explain other types of orbits besides circular?
Yes, General Relativity can explain a variety of orbits, including elliptical, parabolic, and hyperbolic orbits. These orbits occur when the gravitational force is not strong enough to maintain a circular path, causing the object to move in an elliptical or open path around the Earth.
