General Uncertainty Relation between 2 operators
B]\rangle^2Now you see why I advocated using Dirac notation. P.S. I am still at the beginner's stage as far as Dirac's notations are concerned. I think I will stick to the integral form till I get more comfortable will Dirac's conventions. :smile:I would have thought the integral form was the more complicated of the two. In any case, I'm not keen to continue the discussion in this format. There's no need to use Dirac notation, but at the very least you need to use expectation value notation correctly. Also, I don't know if you're using a special font or something, but you have some strange characters showing up in your post. In
Reshma
749
The general uncertainty relation between two observables A and B.
[tex](\Delta A)^2(\Detla B)^2 \geq -{1\over 4}<[A, B]>^2[/tex]
I have to prove the above relation using the definition of expection values etc.
The reference I use (Liboff) have this relation given as an exercise. But Gasiorowicz's book has given some useful hints on this relation. But I couldn't go all the way to prove this result.
Here is my attempt at it.
<Takes a deep breath>
[tex](\Delta A)^2 = <(A - <A>)^2>[/tex]
[tex](\Delta B)^2 = <(B - <B>)^2>[/tex]
Let U = A - <A> & V = B - <B> and consider [itex]\phi = U\psi + i\lamba V \psi[/itex]
The uncertainties in A & B would be correlated only if the two operators do not commute.
Let A & B be Herimtian so U & V will also be Hermitian.
[tex]I(\lambda) = \int dx \phi^* \phi \geq 0[/tex]
[tex]I(\lambda) = \int dx(U\psi + i\lamba V \psi)^*(U\psi + i\lamba V \psi) = \int dx \psi^* [U^2 + \lambda^2 V^2 +i\lambda[U,V]\psi[/tex]
Using the defintion of [itex]\Delta A & \Delta B[/itex]
[tex]I(\lambda) = \left((\Delta A)^2 + \lambda^2 (\Delta B)^2 + i\lambda<[A, B]>\right) \geq 0[/tex]
I have to get rid of [itex]\lambda[/itex] to get my result. Anyone has good idea here??
BTW, Happy New Year to all the hardworking homework helpers in PF. Keep up the great work!
Looks like there's a few [itex]\lambda[/itex]s gone missing. I see them in the source, though - you've omitted a "d" in "lambda". In the last line, you're missing a couple of expectation value brackets. Also, it's easier to do this whole thing in the Dirac notation (if you're familiar with that) - it avoids the need for unnecessary integrals.
First of all, I'd make one simplification, and write [itex]\phi = U\psi - \lambda V \psi[/itex], absorbing any factors of i into [itex]\lambda[/itex]. It reduces the possibility of making sign errors down the way.
Next, choose [itex]\lambda=UV*(V^2)^{-1} [/itex]. Plugging that in should land you with the correct form of the Cauchy-Schwarz inequality. And if you ask how you were supposed to anticipate this substitution, remember the goal - you want something that has a product of expectation values of the uncertainty (or variance) operators.
From there it's tricks with commutators and anti-commutators, noticing whether these are Hermitian or anti-Hermitian, and using the fact that you can write any operator as a sum of Hermitian and anti-Hermitian operators.
Thanks for the reply!
I tried the above integral using Dirac's notation. I retained the same function though.
[tex]I(\lambda) = \int dx \phi^*\phi \geq 0[/tex]
[tex]I(\lambda) = \int dx \phi^*\phi [/tex]
[tex]= <\phi|\phi> [/tex]
[tex]= <(U+ i\lamba V)\psi|(U+ i\lamba V)\psi>[/tex]
[tex]= <U\psi|U\psi> + <U\psi|i\lambda V\psi> + <i\lambda V\psi|U\psi> + < i\lambda V\psi|i\lambda V\psi[/tex]
[tex]= <U\psi|U\psi> + i\lambda<U\psi|V\psi> - i\lambda<V\psi|U\psi> + (i\lambda)(-i\lambda)<V\psi|V\psi>[/tex]
[tex]= <U\psi|U\psi> + \lambda^2 <V\psi|V\psi> + i\lambda<[U, V]>[/tex]
[tex]= (\Delta A)^2 + \lambda^2 (\Delta B)^2 + i\lambda<[A, B]>[/tex]
I think it's correct, I double checked it. The hint given in my text is: Minimise [itex]I(\lambda)[/itex] and substitute the value of [itex]\lambda[/itex] in the last equation.
So it means taking [itex]{{dI}\over {d\lambda}} = 0[/itex] right?
I find your notation unusual...
If [tex]| \phi \rangle \equiv U | \psi \rangle +i \lambda V | \psi \rangle [/tex]
then [tex] \langle \phi | =\langle \psi |U -i \lambda^* \langle \psi | V [/tex]
since U, V are Hermitian. This then gives me :
[tex] \langle \phi | \phi \rangle = \langle U^2 \rangle + | \lambda |^2 \langle V^2 \rangle -i \lambda ^* \langle VU \rangle + i \lambda \langle UV \rangle [/tex]
Do you understand where the requirement that [itex]\langle \phi|\phi \rangle \geq 0 [/itex] comes from?
Now what I've got here will look like what you've got*, only if you assume [itex]\lambda[/itex] is real. This requires that any [itex] \lambda [/itex] that you plug back in also better be real.
I'm not sure how it's going to go (I suspect it will lead to the weak form of the uncertainty relation) but go ahead and take the derivative.
* Your first two terms are still missing expectation value brackets. The way you've written it, these first two terms are operators while the third term is a scalar.
If [itex]\phi[/itex] is Hermitian, the object [itex]<\phi>[/itex] must be real and hence [itex]<\phi|\phi> \geq 0[/itex]
[tex]I(\lambda)= (\Delta A)^2 + \lambda^2 (\Delta B)^2 + i\lambda\langle[A, B]\rangle[/tex]
Minimum will occur when:
[tex]2\lambda(\Delta B)^2 + i \langle [A, B] \rangle = 0[/tex]
[tex]\lambda = \frac{-i\langle[A, B]\rangle}{2(\Delta B)^2}[/tex]
Substituting this value of lambda in my last equation:
[tex](\Delta A)^2 - \frac{\langle[A, B]\rangle^2}{4(\Delta B)^2} + \frac{\langle[A, B]\rangle^2}{2(\Delta B)^2} \geq 0[/tex]
[tex](\Delta A)^2(\Detla B)^2 \geq -{1\over 4}\langle[A, B]\rangle^2[/tex]
I seem to get my required result. :biggrin: But I am still unsure of the nature of [itex]\lambda[/itex]. Apart from being real, [itex]\lambda[/itex] has also been treated as a variable. Can you suggest an alternate technique for this proof?
You're still making the same mistake here. You need to use [itex]\langle \psi | \Delta A \cdot \Delta A | \psi \rangle = \langle ( \Delta A)^2 \rangle [/itex] by definition of the expectation value, [itex] \langle H \rangle \equiv \langle \psi | H | \psi \rangle [/itex]
So, your above line should actually read
[tex]I(\lambda)= \langle (\Delta A)^2 \rangle + \lambda ^2 \langle (\Delta B)^2 \rangle + i\lambda\langle[A, B]\rangle[/tex]
Note the important difference: [itex](\Delta A)^2 [/itex] is an operator, while [itex]\langle (\Delta A)^2 \rangle[/itex] is a scalar (a number).
Incorporate changes made above (division by an operator is not defined, but division by a scalar is).
Well, looks like [itex]\lambda [/itex] is actually imginary, not real.
Doesn't it look like the RHS has the wrong sign? You have a negative number in the RHS! Clearly the product of 2 positive reals must be greater than a negative real, so you've ended up with a trivial truth. I suspect the error comes from the assumption that [itex] \lambda [/itex] be real, which later didn't pan out.
https://www.physicsforums.com/showpost.php?p=692973&postcount=52
Use any of the following for the proof of the Cauchy-Schwarz inequality, that I skipped the steps of, in the above.
http://mathworld.wolfram.com/SchwarzsInequality.html
http://en.wikipedia.org/wiki/Cauchy-Schwarz_inequality
http://ccrma.stanford.edu/~jos/mdft/Cauchy_Schwarz_Inequality.html
Thanks for patiently replying to my queries. I will go through your post and all your links and correct all my mistakes.
Related to General Uncertainty Relation between 2 operators
1. What is the General Uncertainty Relation between 2 operators?
The General Uncertainty Relation between 2 operators is a mathematical principle in quantum mechanics that states that there is a fundamental limit to how precisely certain pairs of physical quantities, such as position and momentum, can be known simultaneously.
2. How is the General Uncertainty Relation derived?
The General Uncertainty Relation is derived from the Heisenberg Uncertainty Principle, which states that the product of the uncertainties in the measurements of two operators, A and B, must be greater than or equal to the absolute value of the commutator of the two operators. This relationship is known as the General Uncertainty Relation.
3. What is the significance of the General Uncertainty Relation?
The General Uncertainty Relation is significant because it places a fundamental limit on the precision of measurements in quantum mechanics. It also demonstrates the inherent uncertainty and unpredictability of quantum systems, which is a key aspect of quantum theory.
4. How does the General Uncertainty Relation impact scientific research?
The General Uncertainty Relation has a significant impact on scientific research, particularly in fields such as quantum physics and chemistry. It affects how measurements are made and the accuracy of experimental results. It also has implications for the development of new technologies, such as quantum computing.
5. Can the General Uncertainty Relation be violated?
No, the General Uncertainty Relation cannot be violated. It is a fundamental principle in quantum mechanics that has been extensively tested and verified through experiments. Any apparent violations of this relation are likely due to measurement errors or limitations in experimental techniques.
