Gravitational Wave Propagation
In summary, the speed of gravitational waves traveling through space-time at the speed of light would not be affected by the curvature and are independent. The spinning of a binary pulsar causes a gravitational wave due to the loss of photon energy, even though there is no change in mass. However, the position and orientation of the pulsar pair would affect the oscillation felt by an object positioned 4 light minutes away. In the case of a black hole, a gravitational wave would pass through it without interference. Two black holes approaching each other at a high speed would create a gravitational wave that could not escape the space-time curvature. It is not possible to verify the speed of gravity using the spring tide effect on Earth, as the changes are too small
jlangdale
Would gravitational waves propagating through space-time at the speed of light be affected by the curvature? Or are they independent?
Why does the spinning of a binary pulsar cause a gravitational wave when there is no change in mass other than the loss of photon energy? Doesn't this object look like a point particle with a mass at the center of gravity?
What would be the source of an oscillation of gravity felt by an object C positioned 4 light minutes from a rotating binary binary pulsar? The position or orientation of pulsar pair?
Imagine a black hole curving space-time to the point that light cannot escape. Would a gravitational wave pass through the black hole or would it interfere?
Wouldn't two black holes have to combine fast enough, say approaching the speed of light, to create a sudden change in mass to create a gravitational wave?
Imagine two black holes approaching each other near the speed of light, would their combination generate a gravitational wave that could not escape the space-time curvature?
If gravitational waves travel at the speed of light and light cannot escape a black hole, are gravitational waves similarly trapped?
In the famous Sun disappearing 8 minute thought experiment, since it's impossible for the Sun to disappear without violating the conservation of energy, is it possible that an instantaneous change in the curvature of space is combatible with the 1/r^2 law?
If the Sun went supernova and a massive core was left along with an expanding mass/energy blast wave, wouldn't the Earth remain in position until 8+ minutes simply because the matter/energy cannot reach a new configuration outside the Earth's orbit faster than the speed of light?
Is it possible to verify the speed of gravity using the spring tide affects on Earth when the Moon and Sun are aligned? Would there be a significant difference in the position of the tide if the Sun was out of alignment by 8 minutes (true position)?
Would this effect be greater on the Moon if you could measure a controlled tidal affect when the Sun and Earth were in alignment?
If two objects were 10 light-seconds apart, and it takes 10 seconds for changes in gravity to travel, then another 10 seconds for the change in true mutual position to be reflected between the objects, would it then take 20 light-seconds to see the affects of gravity?
If gravity was instantaneous, would it only take 10 seconds to see the affect of changes to gravity?
If gravity travels at the speed of light through gravitational waves, it is possible that both waves meet half way in the middle at 5 light-seconds, interact and reflect back to their source for a total interaction of 10 light-seconds equaling the time it takes for light?
Thanks for your replies.
Jonathan Langdale
Astronomy news on Phys.org
Thanks I'll check it out. Forgive my laziness for not searching for it (:
This is a good reference, but it doesn't address the idea of measuring the speed of gravity using the Moon & the Sun, and spring tides, or maybe some tidal detection on the Moon.
The http://en.wikipedia.org/wiki/Gravitational_radiation" should measure fractional distance changes of 10-20). The change in radius of the Earth-Moon system is about 8.9 trillion times smaller than that of the Earth-Sun system (it is ~3.93x10-26m/yr.).
I do not know enough about general relativity to know how to calculate the tidal effects numerically. However, since they are essentially "static field" effects, they would be affected by the "leading" of the "gravitational force" (i.e., they are not produced via gravitational radiation so they will follow where the velocity and acceleration of the system 8 minutes (1.25 sec.) ago would predict them to be). To estimate the deviation, one could take the jerk (time derivative of acceleration) and determine how far a projectile with constant jerk would get in the light travel time, it turns out to be ~2.5cm for the Earth (wrt the Sun), and ~2.3nm for the Moon (wrt the Earth) (these differences are approximately 1 billionth and 1 trillionth of the distance the objects move over the light travel time from the Sun and the Moon respectively). So, while there may be some effects on the Sun, Moon, and tides, I don't think any of the effects are measurable with today's technology.
Related to Gravitational Wave Propagation
1. What are gravitational waves and how are they produced?
Gravitational waves are ripples in the fabric of space-time that are created when massive objects, such as black holes or neutron stars, accelerate. This acceleration causes a distortion in the space-time continuum, which propagates outward as a gravitational wave.
2. How are gravitational waves detected?
Gravitational waves are detected using specialized equipment called interferometers. These instruments use lasers to measure tiny changes in the distances between two mirrors caused by passing gravitational waves. The first successful detection of gravitational waves was made in 2015 by the LIGO interferometers in the US.
3. What is the speed of gravitational waves?
According to Einstein's theory of general relativity, gravitational waves travel at the speed of light, which is approximately 3 x 10^8 meters per second. This has been confirmed by numerous experiments and observations.
4. Can gravitational waves be used for communication?
No, gravitational waves cannot be used for communication as they are extremely weak and difficult to detect. Additionally, they are easily distorted by intervening matter, making it nearly impossible to transmit a clear signal. Gravitational waves are primarily used for studying and understanding the universe.
5. How do gravitational waves affect the objects they pass through?
Gravitational waves cause objects to stretch and compress as they pass through them, similar to how ripples in a pond cause objects to move up and down. However, the effect of gravitational waves is incredibly small, and it is only noticeable when passing through massive objects, such as planets or stars.
  • Astronomy and Astrophysics
