Gravity and the speed of light
In summary, the conversation involves a discussion about the speed of gravity and the possibility of it being faster than the speed of light. There is mention of experimental evidence supporting the theory of relativity and the role of gravity as a fundamental force affecting all particles. The conversation also touches on the concept of gravitons and the challenges of developing a quantum theory of gravity. The participants express their opinions and ask for evidence to support their claims.
mintparasol
78
Hi folks,
Just a quick question:-
Relativity says that nothing, even the gravitational impulse can travel faster than the speed of light. Is there any experimental evidence available online that proves that gravity's 'pull' or 'force' acts thru space at the speed of light?
I believe it's faster, that gravity is an instantaneous interaction. But I'm just a lay nut so I might be imagining things! I believe that if 2 supermassive objects at great distance from each other start to interact gravitationally, that it's an instantaneous reaction, it doesn't take the time it would take for light or other radiation to cross the distance, it's instant.
How wrong am I? Am I seriously misunderstanding relativity/spacetime/gravitation?
Thanks in advance,
ad
Space news on Phys.org
The basic problem is that if you can send information faster than light, then you can send information back in time, and this is bad. This is not to say that it's impossible, but a) we don't know of any cases in which you can send information back in time and b) if we could then there would be a lot of explaining.
If you assume that gravity is purely Newtonian with an infinite velocity then this is clearly wrong since you end up with spacecraft motions that are clearly wrong. You can change your theory to fit current observations, but that does take a bit of doing.
Science works by process of elimination. I'm pretty sure that if you have a theory of gravity in which the gravity moves instantly, that there are experiments that you can use to disprove that. I'm also pretty sure that if you have a theory in which gravity moves 0.0001 m/s faster than light, that our measurements aren't good enough to exclude that. Whether there are experiments that rule out that gravity moves say 10% faster than the speed of light, I don't know, but I'm sure there is some review article out there.
I don't think it's possible to *prove* that gravity doesn't move faster than light. It is possible to that if gravity behaved in X manner, that it would be inconsistent with experiment.
Ok, there's some material here to get me learning, thanks!
What if gravity were a fundamental property of ALL particles?
What do you mean? As far as I know, gravity influences all particles. You can't "escape" from a gravitational field like you could "escape" from an electromagnetic field by putting your charge to 0. Everything which has energy or mass is influenced by gravity and exerts gravity. And that means [itex]\emph{everything}[\itex]: neutrino's, light, electromagnetic fields, elektrons, stars, etc. etc.
What experimental evidence do you suggest that supports this hypothesis? GR predicts weird effects like frame dragging. Gravity Probe B tested and confirmed these effects with great precision. What is left to be tested?
Ok, well what if just one particle was responsible for gravity? Say for argument's sake this particle is the neutrino but it could be any particle in the standard model or some particle yet to be discovered. It exerts gravity over all other particles and therefore is the cause of all gravitational fields. How would the math work then?
BTW, I'm just a lay nut trying to learn by throwing stuff out there!
I don't believe in the graviton. Show me one. I've no problem with broken symmetry and the demonstrable parts of the standard model but I think gravity is something else entirely and while the math of relativity seems to work perfectly with respect to gravity, I believe it's not understood at all on a quantum level, at least by me in any case!
Thanks in advance for any replies,
ad
I don't believe in the graviton. Show me one...I think gravity is something else entirely
reasons? Have you ever seen a photon? How about a quark?
Skepticism is always reasonable, but unless you have some facts to support you, it's unlikely anything here will be specific enough to satisfy you.
Never seen a photon but the mathematical theory behind them owes much to observation, the theory behind gravitons is pretty hypothetical in comparison is it not? It would be more of a mathematical extrapolation than anything approaching a law, no?
Have quarks not been detected in particle accelerators by now? I thought they had...
My bad, maybe
It works very badly, and you've hit at the reason why it's been so difficult to get a quantum theory of gravity.
The quantum theory of electromagnetism involves electrons tossing photons back and forth, and those photons are mathematically treated as a "small correction" to the vacuum.
The problem with doing the same trick to gravity is that you assume that gravity occurs by exchanging "gravitons" you run into the problem that since everything produces gravity, then gravitons produce gravitons which produce more gravitons, and when you add everything up, you get infinities all over the place.
One reason that people are interested in string theory is that when you get to high enough energies, the gravitons become strings that presumably don't produce more gravitons, and so by cutting things off, you get finite answers. However, you run into a problem in that you can cut things off any which way, so instead of getting finite answers, you get any answer that you want, which is also bad.
Nature doesn't care what you believe. :-) :-)
Show me one. I've no problem with broken symmetry and the demonstrable parts of the standard model but I think gravity is something else entirely and while the math of relativity seems to work perfectly with respect to gravity.
The trouble is that you really can't have two completely separate theories of the universe, because you run into situations in which both theories are active.
Well... No one has ever gotten a theory involving gravitons to actually work. Now you could say at that point "why bother?" and just say that things are run by GR. The trouble is that in some situations that we can imagine, GR just stops working. Unfortunately, those situations are extreme enough so that we just can do something like make a black hole and see what happens.
We have seen things for which quarks is the most straightforward explanation that anyone has come up with.
research the higgs mechanism, gravity is not a force with infinite speed
The higgs mechanism might be totally wrong.
The current situation is
1) we have no observations that indicate that gravity travels at faster than light (and people have tried to explain that to Tom Van Flattern without success, but that's his problem)
2) if gravity did travel faster than light, then there would be a lot of theoretical problems
OK, thanks. Quarks would still have a firmer basis in observable reality than the graviton, then, no?
Planetary motion studies rule out superluminal gravity. See also:
Aberration and the Speed of Gravity
http://xxx.lanl.gov/abs/gr-qc/9909087
"The observed absence of gravitational aberration requires that ``Newtonian'' gravity propagate at a speed $c_g>2\times10^{10}c$. By evaluating the gravitational effect of an accelerating mass, I show that aberration in general relativity is almost exactly canceled by velocity-dependent interactions, permitting $c_g=c$. This cancellation is dictated by conservation laws and the quadrupole nature of gravitational radiation."
Related to Gravity and the speed of light
What is the relationship between gravity and the speed of light?
The relationship between gravity and the speed of light is described by the theory of general relativity. This theory states that gravity is the curvature of spacetime caused by the presence of mass or energy. The speed of light, which is a fundamental constant in the universe, is a key factor in this theory as it determines the maximum speed at which information and matter can travel through spacetime.
Why is the speed of light considered to be the fastest speed possible?
The speed of light, denoted by the symbol c, is considered to be the fastest speed possible because it is a fundamental constant in the universe and is a limit imposed by the laws of physics. This means that nothing can travel faster than the speed of light, as it would require an infinite amount of energy. Additionally, as an object approaches the speed of light, its mass increases and it becomes increasingly difficult to accelerate it any further.
How does gravity affect the speed of light?
Gravity can affect the speed of light in a phenomenon known as gravitational time dilation. This means that time appears to pass slower in regions with stronger gravitational fields. As a result, light traveling through these regions will also appear to slow down and its wavelength will appear to increase. This effect has been observed in experiments and is an important factor in the theory of general relativity.
Does gravity travel at the speed of light?
Yes, according to the theory of general relativity, gravity travels at the speed of light. This means that when a massive object moves or changes, the distortion in spacetime that creates gravity will also change and this change will propagate outward at the speed of light. This is consistent with the principle that nothing can travel faster than the speed of light.
How does the speed of light affect our understanding of the universe?
The speed of light is a fundamental constant in the universe and plays a crucial role in our understanding of the universe. It determines the maximum speed at which information and matter can travel, which has implications for the behavior of objects in the cosmos. Additionally, the speed of light is used in many astronomical calculations, such as determining the distance to objects in the universe, and is a key factor in the theory of general relativity.
  • Cosmology
  • Cosmology
  • Classical Physics
