- #36
Baluncore
2023 Award
- 14,561
- 8,453
The cable is a balanced twisted pair or coaxial transmission line. All the currents are balanced and internal. It is inside a steel wire armoured case. The seawater is quite irrelevant.tarakan said:Yet a signal cable that runs beneath the ocean experiences capacitance, acting as a capacitor "plate" surrounded by another capacitor "plate".
Because you are not accumulating charge. Capacitor charge is constant while the capacitance and voltage are changing. Charge is being pumped by the change of capacitance. The flow of charge takes place at two different fixed voltages.tarakan said:Why would resistance matter for the sea water if we are accumulating charge and not current?
A flow of charge is called a current.
The static voltages were measured in thousands of volts, the current was less than 1 mA. Resistance was not important as insignificant power was being handled, uneconomically.tarakan said:What about bottle capacitors that were used in Tesla era, where bottles were placed in a container of salt water and filled with salt water?
It should be sufficient.tarakan said:If we are talking about resistance, what is the thickness of the conductor?
It is irrelevant and unmeasurable.tarakan said:What is ocean water conductor's cross section?
