Help Healpix: from data to map
  • Thread starter fineTuner
  • Tags
    Data Map
In summary: Plot mapplotMap end_proinit_healpix sets up the arrays to store the data. data holds the data for the sky region covered by the .txt file. AR holds the data for the sky region covered by the .txt file, and DEC holds the data for the sky region not covered by the .txt file. The .txt file is just a list of subroutines, so the user doesn't know which strategy to use.
fineTuner
Hi,
i've just installed Healpix on IDL, and I'm starting to try all the subroutines.
First of all, i learned how to make a dipole map with random numbers (it works!:) ). Now i'd like to plot a map using real data.
The .txt file is organized like this:
DEC(°) AR(°) DATA(uK) ERROR(uK)
(i don't need the ERROR column)
First of all, i need a to-do list, to draw a fast block diagram. The Healpix manual is just a list of subroutines, and i don't know which strategy i should use.
Can someone help me? I'm new either in Healpix or IDL.
Thanks in advance.
Space news on Phys.org
Does the data you got the source from offer their data in FITS format? Most full-sky astrophysical data sets do. Examples would be the Planck and WMAP data sets.
Note that most astrophysical images of individual objects really aren't very good for Healpix format. What data are you trying to visualize?
Hi Chalnoth and thank you,
unfortunately i don't have the data in FITS format, only .txt file. The data comes from a balloon experiment for CMB measurements, so it covers only a limited sky region (no objects on particular).
Should i convert the .txt file in FITS?
That's not an easy task.
Easier, I think, to read it into an array using the flat sky approximation and display it in IDL using the TV procedure.
If you *really* want to use Healpix, convert the coordinates on the sky to Healpix pixel indices using the following procedures:
http://healpix.jpl.nasa.gov/html/idlnode41.htm
(Specifically you'd want to use ang2pix_nest or ang2pix_ring, depending upon which pixelization you want to use)
Unfotunately i have to use healpix, even if i haven't a full-sky map!
So, i need to use the ring scheme. The manual (http://healpix.jpl.nasa.gov/html/intronode4.htm) says that with this scheme the Fourier transform is easy to implement (after the map i'll have to plot the angular power spectrum..).
The routine you mentioned is:
ang2pix_ring, nside, ipring, theta, phi
Where:
nside: resolution parameter.
ipring: the pixel number whose coordinates are theta and phi.
Now, how can i put the coordinates from the .txt file inside the theta and phi variables? Should i use two arrays called, for example, theta and phi, to store coordinates?
Thanks!
Where:
Thanks!
Yes. How are the coordinates stored in the .txt file? What is their format?
Here's an example:
78.002930 -40.033035 84.2312 60.1127
The order is AR, DEC, DATA (uK), dummy.
The 4th column isn't necessary.
I found this tutorial https://www.idlcoyote.com/tips/ascii_column_data.html
Now I'm going to work on this. I think it's an easy task (i'm starting to understand IDL logic).
Let me write some code and then i'll show you what I've done :)
To convert from RA/DEC, you can make use of NASA's Astro library, which includes the routine glactc.
Is coordinate change necessary? Can i produce the map with celestial one?
Here's my code:
Code:
pro makeMap
init_healpix
;From data file to 3 arrays
OPENR, lun, 'dati.txt', /GET_LUN
nLines = FILE_LINES('dati.txt')
data = FLTARR(4, nLines)
READF, lun, data
AR = data(0,*)
DEC = data(1,*)
TEMPERATURE = data(2,*)
;Degrees -> Radians
AR[*] = (AR[*]*!pi)/180.
DEC[*] = (DEC[*]*!pi)/180.
nPixel = nLines
nSide = npix2nside(nPixel)
;Map creation
ang2pix_ring, nSide, AR, DEC, map              ;map is the output (?)
map[*] = TEMPERATURE[*]                       ;associate pixel to data
WRITE_FITS_map,'Mappa.fits', map, /ring
mollview,'Mappa.fits',titleplot='Mappa'
end
And the error: % ANG2PIX_RING: Invalid Nside: -1
The problem is nPixel. I put nPixel = nLines, in this way each pixel has a data point...but it seems to be wrong!
Maybe because the number of lines/data points (28121) is not a power of 2?
Yes. Right ascension isn't measured in degrees, but in hours. Your map will be very distorted with your code as it stands. It's really easiest to use a library somebody else has written for this, so you don't make simple errors.
Nside does need to be a power of two.
Npix = 12 * Nside^2
I'd suggest starting with nside=1024. This is a reasonably high resolution. If you see a lot of empty spots in the resulting map, you can reduce the resolution.
Ok, i'll make a coordinate transformation using that routine!
Npix = 12 * Nside^2
Using this formula (writing before that nside = 1024), it reports this:
Code:
WRITE_FITS_MAP: Non-Healpix data set
 npix =        28121 nside =       -1
 *** file NOT written ! ***
Mappa.fits not found
(28121 is the number of lines in the .txt file)
Maybe I'm using the wrong routine to draw the map? I used this for the dipole, quadrupole, etc.. maps and it worked well.
That's wrong. Either set nside, or set npix to be 12 * nside^2. Npix should not be the number of lines in the .txt file.
I set nside = 1024. Now i don't calculate npix because ang2pix_ring needs only nside to work (i also took a look to the source code).
So, here's the new code (now I'm using degrees for coordinates), but the error remains the same:
Code:
pro makemap
init_healpix
READF, lun, data
LAT = data(0,*)
LON = data(1,*)
;Degrees -> Radians
LAT[*] = (LAT[*]*!pi)/180.
LON[*] = (LON[*]*!pi)/180.
;Map creation
nSide = 1024
map = FLTARR(nLines)
ang2pix_ring, nSide, LAT, LON, map              ;map is the output
end
You're never creating the map.
The following line:
...fills the array "map" with the indices of the pixels corresponding to the latitude and longitude. A better name for it would be "pixel indices".
You then need to create a new map of the appropriate nSide, and fill its values with the temperature at the corresponding pixels. Does that make sense?
No, that's why i decided to use the write_fits_cut4 routine, that uses the pixIndex array and the original TEMPERATURE array. Then i plotted the map with mollview (it works!).
Code:
;Map creation
nside=512
ang2pix_ring, nside, AR, DEC, pixIndex
WRITE_FITS_CUT4,'Mappa.fits', pixIndex, TEMPERATURE, Coordsys = 'Q', nside=nside, /ring
MOLLVIEW,'Mappa.fits', COORD='Q'
The problem is that the data square is located in the wrong place on the sphere (i use mollcursor to check it). It is located in [214,-53] instead of [80,-45]...i know that the coordinates are equatorial (letter Q). It's really strange, i didn't convert the coordinates, i only made a transformation from degrees to radians...
Code:
;Map creation
nside=512
Oh, I see. That makes sense.
You might want to check the latitude coordinate. Note that in degrees, latitude goes from 90 degrees at the north pole to -90 degrees at the south pole, while in radians is goes from 0 at the north pole to pi at the south pole.
Likes 1 person
You're right!
I used this formula:
Code:
THETA = (!pi/2.)*(1.-THETA/90.)
I solved all the problems, the map is correct!
Thank you Chalnoth :)
Related to Help Healpix: from data to map
1. What is Healpix?
Healpix is a software package used for analyzing data from astronomical surveys. It is specifically designed for working with data that is mapped onto a sphere, such as images of the sky.
2. What types of data can Healpix handle?
Healpix can handle various types of data, including images, spectra, and catalogs. It is commonly used for analyzing data from telescopes and satellites that observe the sky.
3. How does Healpix convert data into a map?
Healpix uses a pixelization method known as Hierarchical Equal Area isoLatitude Pixelization (HEALPix) to divide the sky into equal-area pixels. The data is then assigned to these pixels and a map is created based on the values within each pixel.
4. Can Healpix be used for other types of data analysis?
Yes, Healpix is a versatile tool that can be used for a variety of data analysis tasks, not just in astronomy. It can be used for analyzing data in other fields such as geography, climate science, and even social sciences.
5. Is Healpix open-source?
Yes, Healpix is an open-source software package, meaning that the source code is freely available for anyone to use, modify, and distribute. It is maintained by a community of developers and is constantly being updated and improved.
  • Cosmology
  • Astronomy and Astrophysics
  • STEM Educators and Teaching
