Help with graphical technique of adding 2 sinusoids
  • Thread starter p75213
  • Tags
    Sinusoids
In summary: Pi/2). Now you can see that the right hand side is the sum of two phasors of magnitudes A and A2, rotated by Pi/4 and -Pi/4. The sum of these two phasors is an ellipse. The long axis of the ellipse is oriented at an angle of Pi/4 with respect to the horizontal. In summary, the two equations (9.11) are being represented as a 2D vector (fig 9.4 a). The authors have used the phasor representation of the sinusoids and the diagrams represent the vector sums of the phasors. In general, the phasor representation can be used for arbitrary sinus
p75213
96
I have a problem understanding how equation 9.11 (see attached) works with Fig. 9.4 (a). Any help would be appreciated.
The two equations (9.11) are being represented as a 2D vector (fig 9.4 a).
The authors have used the phasor representation of the sinusoids and the diagrams represent the vector sums of the phasors. I'd have explained it a bit differently.
Basically, cosine and sine functions have a relative phase of π/2 - so you can use them as x and y axes. The amount each contributes to the result is it's amplitude, which is what is being plotted on the axis. This does not work if the sinusoids have other than nπ/2: n=0,1,2,...
In general - use the phasor representation for arbitrary sinusoids and add the phasor arrows head-to-tail just like vectors.
Try expanding the right hand side, you'll see that it works out :)
Edit: Oops beaten, cutthroat business this physics stuff :P
Thanks for that. Makes sense now that I realize they are vectors. Makes you wonder why they didn't make it clearer. Phasors is the subject of the next chapter.
Ah well, they are trying to be kind to you by building up to them.
I always just launch right into it. By now you've had vectors drilled into you so you see them in your sleep so you can handle rotating vectors no problem.
Never mind - skip ahead to phasors and you'll see it makes better sense.
Remember, wherever you see A.cos(wt) you can replace it by A.sin(wt+Pi/2) because this is an exact equivalence.
By similar reasoning, -cos(wt) = cos(wt+Pi) = cos(wt-Pi)
Related to Help with graphical technique of adding 2 sinusoids
What is the purpose of adding two sinusoids using graphical technique?
The purpose of adding two sinusoids using graphical technique is to understand the concept of superposition, where the resulting signal is the sum of the individual sinusoidal signals. This is a fundamental concept in signal processing and is used to analyze and manipulate signals in various applications.
What are the steps involved in adding two sinusoids using graphical technique?
The steps involved in adding two sinusoids using graphical technique are as follows:
  1. Plot the individual sinusoidal signals on a graph, with time on the x-axis and amplitude on the y-axis.
  2. Identify the amplitude, frequency, and phase of each sinusoid.
  3. Add the amplitudes of the two sinusoids at each point on the graph to obtain the resulting signal.
  4. Plot the resulting signal on the same graph.
  5. Analyze the resulting signal to determine its amplitude, frequency, and phase.
What are the advantages of using graphical technique to add two sinusoids?
Using graphical technique to add two sinusoids has several advantages, including:
  • It provides a visual representation of the resulting signal, making it easier to understand and analyze.
  • It allows for quick and easy manipulation of the individual sinusoidal signals to observe the effects on the resulting signal.
  • It is a simple and intuitive method, making it accessible to those without advanced mathematical knowledge.
What are some common applications of adding two sinusoids using graphical technique?
Adding two sinusoids using graphical technique is a fundamental concept in signal processing and has many practical applications, such as:
  • Audio and music production, where multiple sound waves are combined to create a desired sound.
  • Radio and communication systems, where different signals need to be combined and separated for transmission and reception.
  • Image and video processing, where multiple image or video frames are combined to create a final image or video.
  • Instrumentation and control systems, where multiple sensors or signals are combined to monitor and control a process.
What are some common challenges when adding two sinusoids using graphical technique?
Some common challenges when adding two sinusoids using graphical technique include:
  • Difficulty in accurately identifying the amplitude, frequency, and phase of each sinusoidal signal.
  • Distortion or interference caused by noise or other signals.
  • Difficulty in accurately plotting and analyzing the resulting signal due to large or complex signals.
  • Limitations of the graphing tool or software used.
