Hi,Can anyone explain why in field theory we require [f*(x),f(y)]
In summary, the existence of antiparticles allows for a non-zero expectation value <0|f*(x)f(y)|0> while still maintaining causality due to the cancellation of influences.
LearningDG
Hi,
Can anyone explain why in field theory we require [f*(x),f(y)] = 0 for space-lkie intervals x,y; but not <0|f*(x)f(y)|0> = 0?
Thanks!
LearningDG, You're right to call attention to this. It's the miracle that makes quantum field theory work! <0|f*(x)f(y)|0> ≠ 0 expresses the fact that a particle cannot be confined to a single point, that the Green's function extends outside the light cone a distance given by the Compton wavelength. And yet [f*(x),f(y)] = 0 expresses the fact that this apparent nonlocality does not destroy causality, saying that influences cannot propagate faster than light. And it's all due to the existence of antiparticles. The influence caused by emitting a particle is exactly canceled by the influence caused by the absorption of an antiparticle.
Related to Hi,Can anyone explain why in field theory we require [f*(x),f(y)]
1. Why do we use field theory in science?
Field theory is a mathematical framework that allows us to describe physical phenomena in a consistent and elegant manner. It is particularly useful in fields such as physics, chemistry, and engineering, as it helps us understand the behavior of complex systems and make predictions about their properties.
2. What is the significance of [f*(x),f(y)] in field theory?
The bracket notation [f*(x),f(y)] represents the commutator of two operators f*(x) and f(y) in field theory. This commutator is important because it helps us understand the relationship between these operators and how they affect each other.
3. How does field theory differ from other mathematical approaches?
Field theory differs from other mathematical approaches, such as calculus or linear algebra, in that it focuses on describing physical systems as a whole, rather than breaking them down into smaller components. It also takes into account the interaction between different components of a system, rather than considering them separately.
4. Can you provide an example of how field theory is applied in real-life situations?
One example of field theory in action is in electromagnetism, where the behavior of electrical and magnetic fields is described by the equations of Maxwell's theory. This allows us to make predictions about the behavior of electromagnetic waves, which are used in technologies such as radios, televisions, and cell phones.
5. Are there any limitations to using field theory?
While field theory is a powerful tool for understanding physical phenomena, it does have its limitations. For example, it may not be able to accurately describe systems at very small scales, such as in quantum mechanics. Additionally, field theory often relies on simplifying assumptions, which may not hold true in all situations.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
