Horizontal force by block on a beam
  • #36
hello478 said:
Are my answers correct?
box At A:
T= 6.37
Ty= 4.625
Tx= 3.88
Hx= 3.88
Hy= 16.625
I think you meant T=6.037N
(Always specify the units.)
Likes hello478
  • #37
yeah, it was a typo...
i meant 6.037
  • #38
i meant 6.037
Ok, so what next? Will you have a go at an answer to the question in post #1, or maybe first try the case of the block being at B?
Likes MatinSAR and hello478
  • #39
yeah sure, i will do it in the morning 💤
thank you for the guidance!
  • #40
box At A:
T= 6.37
Ty= 4.625
Tx= 3.88
Hx= 3.88
Hy= 16.625
We prefer you post your calculations, not just the results. But: 80% is correct. Only T is off ( ##T = T_y/\sin\bigl ( {50\over 180}\pi \bigr ) = 6.04## N ) [edit] ah, already noted and a typo
Well done.
:mad: Except you omitted the units -- a strict prof would give you 0 points.
[edit] haha, already noted too
Likes hello478
  • #41
hello478 said:
and why does tension change when the block is moved
Conceptual intermezzo:
This is a (practically massless) swing and you (with substantial mass) sit in the middle.
The tension in the two ropes is equal and each is half your ##mg## (you just hang there and don't swing).
What happens to these tensions when you shift towards the right rope ?
What happens when you move even further, to the other side of the rope ?
Catch my drift ?
(it was rather a long dinner -- again :rolleyes:)
Likes Lnewqban and hello478
  • #42
thank you for the explanation :)
when we shift towards right the tension in the right rope increases
and if we dang towards the left rope the tension in the left rope increase
am i right? or wrong?
  • #43
AN ATTEMPT TO THE ORIGINAL QUESTION:::::: is this correct?? 😶‍🌫️
The block is now moved closer to end A of the beam. Assume that the beam remains
horizontal.
State and explain whether this change will increase, decrease or have no effect on the horizontal
component of the force exerted on the beam by the hinge
so the answer to this question would be...
that the resultant tension in the rope decreases
and the horizontal component of the tension also decreases
before horizontal component is 10.9N and as it moves closer to A i decreases and at A it eventually becomes 3.88N
Likes Lnewqban and BvU
  • #44
AT B:
T= 21.7 N
Tx= 13.95 N
Ty= 16.625 N
Hx= 13.95 N
Hy= 4.625 N (acting downwards)
while at A Hy= 16.625 N acting upwards
Likes Lnewqban
  • #45
Bingo ! :dademyday:
And with units !
Likes hello478
  • #46
BvU said:
Bingo ! :dademyday:
And with units !
yesss finally!!:partytime:
